Maytag m3x05f2a-d on/fan speed dial spindle broke need replacement switch and front dial - I see two different part #'s - CA122 and 0343 - which is it and where can I order?
5 Suggested Answers
SOURCE: Maytag M3X05F2A
Your unit is 515 Watts using 115V (line to ground.)
Maytag M3X05F2A
Specifications:
• Volts 115
• EER 9.7
• Amps 5.0
• Watts 515
• Plug cap. amps 125/15
• Pints per hour 1.4
• Room air (CFM) 160
Room Size:
• 10' x 15'
• 150 sq. ft.
If you plan on using it in the Philippines the electrical power supply is 220V line to ground. You can use an Auto Voltage Regulator (AVR) which has an internal winding with a servo that moves a carbon brush across the winding. I would recommend that you use at least a 1500 Watt AVR as the longer you use it the hotter it will get. Hopefully you can find an AVR with 3 pronged outlets. I currently use 3 ea. SIEG models SVC-888-1000 VA (600 Watts) for most electronics and 1 SVC-888-1500VA on a small 11 Cu Ft. freezer. The Freezer is 626W but uses almost 700W during the defrost cycle. The AVR failed after 3 years due to overheating. (STINK!) I also have a 4th SEIG model SVC-888-3000VA on my 21 Cu Ft 115V Refrigerator. There are other AVR manufacturers here and the cost vary greatly by manufacturer. (P3300 - P6500 depending on model) I have has all of my AVRs in countinous service for almost 6 years.
Posted on Jan 13, 2008
SOURCE: Maytag Model M3X05F2A
just pul lit up dont be affraid, i got a ac same like yours
Posted on Jun 03, 2008
SOURCE: Where does water drain on an M3X05F2A Maytag air
There is a hole in the bottom near the left side that takes
care of that.
Posted on Jul 29, 2010
Nomadfeet
  • 59 Answers
SOURCE: Fan is 5 months old.
If this looks like your switch then yes, it's a generic part available pretty much anywhere ceiling fans/parts are sold (I've seen them in Wal-Mart). You will probably need small wirenuts or a line splice to replace with this part, but as it it a SPST which wire goes where does not really matter.
Posted on Sep 25, 2011
Fan blower is on full and can't switch it off
The Blower Resister Unit Needs Replacing It Sounds Like. The Resister Is Located On The Passenger Side Kick Panel By The Blower Motor.
May 17, 2013 | 2006 Hyundai Santa Fe
Triton ivory 4 power dial keeps turning not turning off
It happened with mine, the dials each work differently on their spindles and my main power switch dial broke. If your careful you can switch the dials over (remove them from the cover and swap them around). This worked for me until now as it's broken a second time. So now I have to order a complete front cover assy for 21 pounds.
Hope this works.
Jan 16, 2011 | Home
3-speed fan switch broke on Hunter model 28072, cat. 300 fan. Found replacement switch at Lowes, but wiring colors are completely different from manual. What color wires go into L, 1, 2, 3 positions...
My Hunter fan uses a Zing-Ear ZE-268S6 switch. This is NOT a standard switch! It connects L to 2 AND 3 for medium speed. It is best to order the exact switch if possible. Hunter wants to sell you the entire bottom assembly (probably expensive). I found the exact switch online at:
http://www.kenselectronics.com/lists/switches.htm#Pull%20chain
for $6.80 plus $4.95 shipping. I bought an extra which didn't increase the shipping - worked great. Hunter ZE-268S6 ceiling fan connection colors: L=black; 3=green; 1=grey; 2=brown. If you need a different switch on their page, just click the Edit menu, then Find, type your part number in the box, and click Next.
Nov 30, 2010 | Hunter Ceiling Fan Control Switch
care of that.
Jun 17, 2010 | Maytag M3X05F2B Air Conditioner
Fan will not work on high (5)
http://www.physics.sjsu.edu/becker/physics51/images/27_01_Resistors_in_series_and_parallel.JPG
Ok i know this might be a little difficult to understand. BUt If you click on the link above. Find Diagram (a), That picture represents your switch, not complete but in theory. each Resistor means a Different speed. As you turn the Dial it applys current to all the resistor depending on which one it points to. As you can see the (i) represents current and lets say R3 represents "speed 5" Well in theory the less resistors the fast the speed. So the at low speed the dial will be pointing to R1 at medium fan speed the dial will point at R2 and at high Speed "speed 5" the Dial points to R3. Less Resistance More Current More Current more Speed. Now You have No R3...
This basiclly means that the who switch wihich includes Warm and cold and 1,2,3,4,5 and Defrost etc need to be replaced for 5 to work again.
No solution Replace switch
Jul 15, 2009 | 2003 Chevrolet Avalanche
Only have 2 speeds on a 3 speed ceiling fan- replaced switch, no
no no the problem is with the switch u need to re programm the wires check the old switch
and make the same conection.
Feb 08, 2009 | Monte Carlo (5LCR52MW) Fan
May 28, 2008 | Maytag M6Q10F2A Air Conditioner
Heating & Cooling Logo
128 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
