Question about Garden
Scotts e3009000 not getting any spark
Random missfire
I hope you used AC Delco plugs. Make sure the spark plug gaps are correct. Also, make sure you torque the spark plugs to manufacturer's specification. This would be a good start. Scott
Jan 28, 2013 | 2002 Chevrolet TrailBlazer
Scott, 95 GMC 5.7L keeps fouling plugs
Hi Dale,
Several factors can contribute to spark plug fouling:
- The air/fuel ratio may be too rich as a result of incorrect carburetor adjustment or a poorly performing fuel injection system.
- Worn piston rings or valve seals may allow too much oil to leak into the combustion chamber, leading to oil fouling.
- The ignition system may not be performing properly.
- Prolonged idling or continuous low-speed driving may keep the spark plug from reaching its optimum operating temperature. Using too cold a spark plug can lead to the same problem.
- A dirty air cleaner can create a too-rich condition which can lead to fouling.
Have each of the above checked and corrected.
Fuel, oil and carbon fouling can all be the result of different causes but, once a spark plug is fouled, it will not provide adequate voltage to the firing tip and that cylinder will not fire properly.
In many cases, the spark plug cannot be cleaned sufficiently to restore normal operation. Hence, I always recommend that a plug be replace, once it becomes fouled.
Cheers,
Scott
"If this has helped you in any way, please be kind enough to rate this solution"
Nov 02, 2011 | 1995 Chevrolet K1500
Scotts by john deere riding mower - 220 hours, 17.5 HP, 42" cut, Briggs & stratton engine -- New Strarter, new battery, good fuel... will turn over but engine will slow down then stop, will not...
Very high likelihood you have fuel line problems. Disconnect primary fuel line from bottom of fuel filter and blow compressed air back up the fuel line to the gas tank. This will clear the line of any trash. Reconnect fuel line to filter. Then remove spark plug and spray a couple of sprays of WD-40 into the cylinder.. Re-install spark plug and then restart. WD-4- will act as a starter fuel and will start the engine for enough rounds to get fuel pump to working to normal run.. Good luck.
May 15, 2011 | Briggs & Stratton Garden
I bought a Scott 76121 mini speader but lost the instruction. Where can I go online to get them
I'm sorry the Scotts Mini Edgeguard Label is not available online. Please contact the Scotts Help Center at 800-543-8873, we would be happy to email or mail you a copy. Stacey@scotts
Apr 19, 2011 | Scotts Company 76121 Scotts Turf Builder...
Scott bonnar lawn mower service manual model 520
i have a scott lawn mower,i have run it dry of fuel went to refuel.now it won't start.have cleaned the spark plug and poured fuel thru the carb any clues
May 17, 2010 | Garden
Stihl FS85R stops when hot and won't restart
scott have the shop replace the ignition coil and problem should be solved. jd
Oct 22, 2009 | Garden
Electrical problem with my 1999 Scotts Riding Lawnmower
If the motor is trying to start but won't try removing the engine shroud and cleaning the magnets on the fly wheel and the two little prongs close to the fly wheel. They might just be rusted and not getting a good electric pulse to the spark plug. Also clean the spark plug wire end that goes on the plug. I use fine sand paper or emery cloth. Your choice.
Good luck and let me know if this works.
thanks
roundo4
Sep 02, 2009 | Garden
Spark plug
Get a spark plug socket with the hex head on the top. Put it on the plug and use a wrench to turn it. You should purchase a deep 5/8" spark plug socket. Those are a pain you know where! Try not to let the plug wires sit on the exhaust manifold either or your will be replacing them again soon.
Good luck .....Scott
Sep 14, 2008 | 1987 GMC Safari
94 explorer, no spark
The starter has power only if the battery is good.The ignition coil gives the engine spark.
Aug 25, 2008 | 1994 Ford Explorer Limited
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
