Question about Stihl Fs75/fs80r/fs85r Air Filter Housing
Starter pawl Replace Starter Pawl
  • Stihl Master
  • 1,807 Answers
The recoil starter on my stihl br420 backpack blower doesn't engage.
Replace the entire starter assembly on both sides...
May 02, 2017 | Cars & Trucks
Pull string is stuck....very difficult to pull.
Yep, starter pawl spring or pawl itself. I don't know what trimmer you have but most are set up like this. Something engages the flywheel so you have to start there.
Sep 07, 2014 | Garden
Repairing a Briggs and Stratton Quantum 35 mower engine. How do you replace the metal starter pawls in an older Briggs & Stratton mower engine
take cap off drive the pin out the bottom from the top replace starter pawls and springs put back to gether drive the pin back in checking making sure not to thight if it is drive pin back some until it spins freely
Aug 22, 2014 | Garden
Yardworks 270-1241 battery full charge, sound like fan runs no motor, blade goes around, help
sounds like your starter pawl is stripped. remove your starter and inspect the pawl (gear). also check your flywheel teeth for chipping. this is usually a replacement part. If your flywheel is good just change the pawl on the starter itself
Jun 29, 2014 | Yard Machines Garden
The pull cord hasn't snapped it just wont recoil! is this an easy fix?
Sounds like the starter spring has broken, remove the three torx screws securing the starter and remove the starter, prise off the r clip holding the pulley and pawl on ( note the orientation of the clip on the pawl ) remove the pulley, the spring is in a cassette, remove the cassette and replace with new, refit the pulley, make sure the pulley locates properly into the hook on the starter spring, re fit the pawl and r clip, enter the cord into the cut a way in the side of the pulley, now wind the pueey around to tention the spring.
Apr 17, 2013 | Stihl Concrete Cutoff Saw Rewind Recoil...
Will the starter cover from a 2100 husky fit a 480 husky
No, the 2100 has a three pawl starter pulley, but the 480 only has a two pawl pulley
Feb 23, 2013 | Husqvarna Garden
I ned new starter pawl ratchet for 125l
HandymanJ has the perfect solution. I did it and it worked great. Thanks.
Sep 24, 2012 | Husqvarna 531004153 Starter Pawl/Ratchet
I just put a new starter pral in and it pulled once and now it won't catch again when you pull it.
The wire clip that secures the pulley also acts as a clutch, as the pulley turns the wire clip tries to stay still, and in doing so pushes the plastic pawl out, so you either do not have enough tention on the clip around the centre post, or the wire clip is not around the plastic dowel on the starter pawl.
Feb 13, 2011 | Stihl MS 290 Chain Saw include 20" 50cm...
Bosch Hedge Trimmer AHS 4-16 Starts now and
sounds like you will need to replace starter pulley in the starter cover assy and check that the starter pawls are free to move and the pawl springs are no broken or the pawls are frozen
but your problem is most likley starter pulley
remove the starter cover and check the starter pulley
worn or damage teeth on pulley may be quite evident
cheers pauly46
Sep 19, 2009 | Garden
Stihl Fs75/fs80r/fs85r Air Filter Housing Logo
104 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
