Question about xheli 9053 Outdoor Volitation Metal Helicopter
Erratic speed control
As a result of unintentionally reversing polarity to the helicopter (don't ask), a small puff of smoke emitted from the control board. Replaced with a new one and flew okay for about 15 seconds and then the throttle control via LH stick became erratic. Would lose complete power for a second then be okay. When shutting down power, completely off via stick, it would continue running. Control functions via RH stick all okay, just power control problems. Sent panel back, and new one did same thing. Transmitter okay as used another one I have with same freq and same problem with heli operation. Any comments before I go back and try convincing vendor I have two bad control boards in a row?
5 Suggested Answers
SOURCE: When I increase the throttle
It's possible that the heli battery is too weak and needs recharging. It's only good for about 8-10 minutes of flying time.
Posted on Jun 23, 2011
SOURCE: Hi, Ihave the exceed madhawk
Is the shaft for the tail rotor connected? Its more difficult to do this with the fusalage models.
Andre.
Posted on Dec 19, 2010
  • 133 Answers
SOURCE: Throttle is operating servo on
It sounds like you just got it. Be sure your battery is fully charged. Its probably a "Lipo / ?". They put out very high current but drain quickly. On the larger copters, some functions will work partially or stop completely before other functions when they are low on charge. If its RTF out of the box and you just got, give the battery at least a 3 hour charge and try it again. If that doesn't work then, I would take it back for a replacement. If its not new and we need to trouble shoot, I have a lot of writing to look forward to. I fly an AH-64 attack chopper and a dual tower sky crane. I just finished repairing my crashed sky crane this morning. No more plastic for me. Let me know when you are ready. Today or whenever. We will get it done. Also. you will need a volt meter, small diameter Philips screw driver and a logic probe would be easiest to use if we need to check any PC boards. Good luck with the battery! I'm here if not. Roger
Posted on Apr 20, 2011
SOURCE: my helicopter 9053 will not connect to my controller
Hi my volitation has not iam very sad I check all but its not use
Posted on Feb 14, 2013
Engine gives off a little puff of smoke on startup
What size motor? Older engines will start to have valve guide wear and this can cause a small amount of oil to seep into the cylinder after the engine shuts off. This will cause a small puff of smoke on start-up. If the smoke clears up immediately, there is really no major problem. Be advised that on the GM motors, it is the back two cylinders on the v-6 and v-8 engines that this usually occurs. As the condition worsens with age, the oil can cause plug fouling resulting is misfiring. Changing or cleaning the affected plugs will remedy the issue for a while.
Aug 05, 2014 | 1999 Chevrolet Silverado 1500
Will not fly lift . Seem to run well but will not lift off the ground
The batteries on the Helicopter need to be fully charged to take off.
And important: to recharge the helicopter fully it needs really good base unit batteries.
I find all this a waste so - I used a wall power supply to supply suitable power to the charging bases of these helicopters give more consistant results than using batteries.. Just make sure you are using a 9V DC wall transformer (6 1.5v batteries = 9v) and that the polarity is correct.
manual is here
http://www.brookstone.com/webassets/pdf/651307p_manual.pdf
Dec 18, 2013 | Brookstone uControl Cloud Force RC...
3CH Falcon- X Radio Controlled Helicopter With Gyro
Hi Erik first off check the cof centre of gravity buy holding or hanging your helicopter from the balance bars if it hangs to much on tail end and not level this could be first problem , this means u need to put small weight in nose to balance lvl .
Mar 13, 2013 | Falcon Radio Rc Helicopter
Puff of smoke from air vents.
You have a better idea than us, you saw and smelt the smoke.
Nov 01, 2017 | 2000 Ford Taurus
Occasional heavy smoke on tickover, but not using oil and oil clean.
HI do you now the color of the smoke
if engine emits white smoke its not burning the fuel
it could be water mixing with fuel = head gasket even tho you
dot have water in the oil
if engine emits black smoke - that's excessive fuel to air ration
check air filter & air inlet to see if clogged
if engine emits blue smoke - excessive oil consumption
cloud be valve seals
Jun 28, 2011 | 1996 Volvo 850
Brand new unit forward and reverse seems very slow moves a little then just hovers.
Make sure you're charging fully, until the light on the charger doesn't get ANY brighter when you unplug the helicopter. Also, battery must be allowed to cool 10 minutes after flying AND another 10 minutes after charging.
Most crucial is that you must never fully discharge battery. Fully draining a Li/Po even once (especially when it's new) can cripple or ruin your battery. As soon as you are unable to maintain altitude, land copter and power it off. Also, there is a button on the remote, labelled "tail motor speed switch" located near the trim control. With it in the "off" or up position the tail motor is much slower allowing for more precise control. When button is pushed to the down or "on" position, tail motor moves faster giving more tilt, and thereby much more forward/reverse 'thrust'. Verify that tail rotor is moving when right joystick is actuated (and that it reverses when right stick is pulled in opposite direction) and that it isn't loose on it's shaft... this can be tested by verifying tail rotor spin in one direction then reversing joystick... tail rotor should instantly start spinning in the other direction with NO hesitation, if it slows and then starts spinning in other direction or anything like that then it's loose. Turn helicopter upside down then VERY CAREFULLY apply a small drop of super glue where the shaft meets the tail rotor, be very cautious to not get any glue near where the shaft comes out of the motor, and do not turn right side up until glue is fully dry.
Hope this helps,
r
Jan 07, 2011 | SYMA Toys industrial Syma S032 Ready to...
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
Big puff of white smoke at start up after sitting for several hours.
white smoke is water
blue smoke is oil.
nest time try and smell the white smoke see if it smells sweet?
if it does its antifreeze.
and also black smoke is fuel (like a leaky injector )
hope this helps
paul
Sep 19, 2008 | 2007 Nissan Altima 3.5 Sedan
xheli 9053 Outdoor Volitation Metal Helicopter Logo
46 people viewed this question
Top xheli Toys Experts
MeAndMyBrain
Level 1 Expert
Tom Chichester
Rani wadia
Rani wadia
Are you a xheli Toy Expert? Answer questions, earn points and help others
