Question about Panasonic Microwave Ovens
Panasonic model NN S959WC microwave ....the face and door has yellowed over the years. How do I get it white again?
MicrowaveSvc
  • 9047 Answers
SOURCE: MICROWAVE TURNS ON WHEN DOOR IS OPENED.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food
/ grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Need door assembly diagram to
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: door does not latch close
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Posted on Sep 02, 2008
  • 178 Answers
SOURCE: Can't open microwave door
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Posted on Sep 13, 2009
Testimonial: "Thank you for replying! You really seem to know what you are talking about!"
SOURCE: Panasonic microwave model NN-2959: can't open door.
Your DOOR LEVER probably is broken. To open the door remove the filter (2 screws at the top) then remore the control panel by removing the screw holding it in place UNPLUG THE MACHINE. then unlatch the door. BUT I am trying to find a door lever and find they are no longer availabel.
Posted on Dec 21, 2009
Door button does not function for panasonic microwave=need to know how to take the face off so that I can fix it
Take side panels off and press the button through from the back, my husband has just done this tonight on our Panasonic microwave model NN-ST477 as the door would not open. He found a piece of plastic like a hook had snapped off. The door now opens and functions normally. Took about 30 minutes to do . If and when it becomes stuck again we know that we will need a new replacement button. Hope this helpskind regardsChristine
Sep 14, 2011 | Panasonic NN-H275 Microwave Oven
Have a Panasonic Microwave Mod. # NN-P294BF. The Door opener (push button type) became detatched from the door latch. It is mounted over the stove. Do I have to take it down to be able to take the...
Here you can find what you need for a very similar model
http://www.searspartsdirect.com/partsdirect/part-model/Panasonic-Parts/Microwave-Parts/Model-NNSD297SR/0789/0123370/50036271/00001?blt=06&prst=0&shdMod=NN-SD297SR
Yes, to take down the face you must have the unit fully accessible - the bolts are accessible only from the rear.
Apr 13, 2011 | Panasonic NN-P295SF Microwave Oven
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
Panasonic microwave nn-6372awm memory codes
I HAVE A PANASONIC MICROWAVE,MODEL NN-6372AWM,SOMEONE WAS GOING TO USE IT AND I DON'T KNOW WHAT THEY PUNCHED,BUT IT NOW SAYS LOCK ON THE SCREEN,THE DOOR WILL OPEN BUT YOU CANNOT USE THE TIMER.HAVE HAD IT ABOUT 10 YEARS,WORKS FINE,LOST THE BOOK ON IT.CAN ANYONE TELL ME HOW TO UNLOCK IT.I AM SURE IT HAS A CODE.
Apr 21, 2010 | Panasonic Microwave Ovens
Panasonic NN-P794SFR microwave unit that spins not rotating
there is a switch to turn it on or off. the turntable is replaceable
Feb 07, 2010 | Panasonic NN-P794SF Microwave Oven
Hi! if the parts is to much expensive i think it is not worth it. considering the years it has serve you.
Sep 11, 2009 | Microwave Ovens
Cracked door on Panasonic S753 combi microwave oven
Hi I have a Panasonic combi oven in between the glass door is misting up should I be worried
Jan 07, 2009 | Panasonic NN-S753 Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
