Question about Philips DVDR3390/37 DVD Recorder
Philips DVDR 3390/37
Whenever I try to open the tray to insert disk I get the same message BLOCKED????? I have tried unpluging device to reset still the tray wont open?
Hi. Look underneath (bottom) of unit, right under the DVD drive. There is a open narrow slot. Take a PLASTIC, or non-metal, instument, like a chop-stick, etc., & insert into slot. Start from the very right of open slot & move the instrument to the left. You will be moving a plastic slider that will open the dvd drive, Simple. Also, keep a dummy disc in drive & it will open all the time, but the drive will constantly spin & spin, overheat & no longer work. It only shuts down when no disc is inserted. I have rebuilt dozens of these models. What I do is after viewing disc, I remove right away, because when you switch to view from hdd or cable/sat., the inserted disc will spin all the time & wear out drive very soon. By keeping a disc out, the drive will last a long time. It is so easy just to manually!! open the dvd drive, each time. Better than replacing with a PC internal IDE dvd burner. Then you have to cut hole on top for IDE cable & power cable & the dvd burner/drive sits on top of unit because it will NOT fit inside. Plus, if you do this, remember to put plastic button on master slot seen on the back of new dvd burner. Also, another tip, if you save a show, ect, on HDD, burn onto disc right away, if you want to save program onto a disc. Another tip, you can hold onto stop button on remote, a few seconds, & dvd drive door will open. Hold again & it will shut.
Posted on Mar 24, 2010
  • 58 Answers
Press the open/close button for 10sec until it shows unblock/unlock. Someone has press that button to lock or block. Thats a protection to open it accidentally. Good luck Hope this may help you
Posted on Aug 07, 2007
Smash the above the tray as soon as you hit the open close button, seems to work for me.
Posted on Aug 09, 2008
So far the above seems correct. Keep it full. What is wrong I can only guess. Mine quit writing but reads. I disassembled and pressed firmly on the disc spin mechanism from the top while disassembled. I bought another and switch parts. has them at 13.html in the parts page.
I'm trying to get replacements as we read.
Posted on Jun 11, 2008
I had the same problem. It is likely to get worse. The problem is one of design of the R/W unit. What is "causing" the "blockage" is the stabilization idler mounted on a plastic piece spanning the top of the recorder. It is a plastic disc with a metal ring embedded in it. It clamps down on the dvd once its loaded. It is supposed to release when the eject sequence starts. The read/write head assembly is supposed to rise up to read a dvd or cd and drop back down to a rest position when its time to eject the disc. The head assembly is encased in a metal shell, which is already magnetized or has become magnetized, because mine is. The mechanism pulling the head down is too weak to pull the head all the way down. It moves just a little bit, you hear some noise and the "blocked" message appears on the display. If you take the cover off, you see the dvd still in the "mounted" position, but it has moved a little bit, but the clamp effect of the stabilizer is still engaged.
There are 2 ways I know to get around it, neither is kosher. First, before you go inside, tap the area of the philips case right where you imagine the dvd center to be, if one was loaded. Tap AND hit open, you may break the magnetic link that way, the head drops, the tray slides out. Then always keep a dvd in the player to give the release motor a little help, use a scratch disc you were going to throw away anyway.
Second, you need to open the case, pry the stabilizer up as high as you can, or tap on the plastic near its edge while pressing the "open" button. You may need a pc type screw driver to remove the very small screws that the stabilizer assembly is mounted on. This way you can at least get the disc without further damage to it..You might as well leave the screws off, if you plan to keep using the recorder. I did until I now, 6 months later, have the unknown disc problem. What a shame, it is a good unit, read and wrote to old dvd-rw discs my other recorders refused to touch . Having no real luck finding the drive unit as a sale item, it is really easy to replace, just like a pc drive..that would be under 40 dollars. I would buy another philips, but unless I can find a couple replacement drives to put in the closet it doesn't make sense. I dislike throwing out all those electronics because of a little problem with the R/W unit. Just the words of an old, country network/pc technician.
Posted on Mar 01, 2008
My Technika DVDr 2005 drawer will not open and has a DVD in place - how can I retrieve the DVD?
turn it off then unplug the dvdr then after a while plug it again and turn on, now press the play button after a while press the stop button then next is the eject button. if still the tray won't eject unplug the dvdr use a philip screw driver unscrew to open the cover. look for the plastic motor gear then manually turn it with your finger to eject the tray now you can get your dvd. place back the cover and plug the unit and then turn on to check if its working again and eject the tray. thanks i hope it will help you good luck.
Jun 13, 2011 | Televison & Video
The disc is block inside
Try unplugging and when you plug in again press stop at the same time.
Feb 25, 2010 | Philips DVDR 3355 DVD Recorder
Philips dvdr 3480 disc draw refuses to open
This usually happens when you close the drawer with no disc in it. There is a strong magnet inside the DVD-drive that keeps the spinning disc in the correct position. But when the drive is empty, the magnet is connected to tough to its counterpart (no disc in between) and the worn out motor and/or transmission (belt) is not able to pull them apart in order to open the disc tray.
How to fix - "brute-force-attack":
Press OPEN and give the disc draw a couple of decent slaps (or snap at the tray cover with your forefinger) until it opens. Repeat procedure, if motor stops before drawer is open.
How to fix - "high-tech-approach":
Disconnect power chord. Locate the slot provided at the bottom of the device, near the smaller, left clip holding the front panel. Insert a screwdriver into it at the far right (when viewing from the front), so you can push a small white plastic-lever-thingy (can be seen thru the slot) to the far left. Now the tray is partly opened and can be pulled out completely.
Future outlook:
Don't you never ever close your old machine with no disc in the tray - or just start over again...
Jul 26, 2009 | Philips Televison & Video
Dvdr tray
You have one of the following problems:
  • The device freezes and does not react anymore to the remote control commands.
  • The DVD is stuck in the tray. Sometimes the message BLOCKED appears.
  • A feature is not available in the menu without any logical reason.
  • A feature of the device does not work (for example start install).
  • There is some problem with the device you cannot solve.
Reset the DVD recorder.
  1. Unplug the mains cord from the mains wall outlet.
  2. Press the POWER/ON button on the DVD recorder itself.
  3. While keeping the POWER/ON button pressed connect the main power cord to the wall outlet again. A message IS TV ON? or a demo message will appear in the display.
  4. Start the first installation process.
    1. The settings of the DVD recorder will return to their default settings. Install the DVD recorder as if it came out of the box.
    2. The data on the hard disc will not be affected.
Apr 28, 2009 | Philips DVDR7260H DVD Recorder / HDD...
Philips DVDR 3370h dvd tray stuck
hi there, if you found solution to problem please e-mail to
Mar 08, 2009 | Philips DVDR3370H DVD Recorder/HDD...
PHILIPS DVDR 75/17 error code C003 TRAY BLOCKED
jim, try to open the tray manually open the cover rotate the motor or the belt manually.
Dec 13, 2008 | Philips DVDR755/17 Burner
DVD drive will no longer open
I went to look at getting it fixed and wit was going to cost as much as a new device, so I pulled it to bits and found that the rubber band in the DVD player was frail. This meant it didn't have enough strenght to load the disk completely.
I went to a stationary shop and brought a new one the same size and it is perfect.
Cost. 10c.
You will need to be careful and confident pulling it to bits and some of the screws are no standard. good luck.
Alternatively there is a slot under the unit that you can force the DVD mechanism open or closed. A hassle though.
Nov 22, 2008 | Philips DVDR3455H/37B
The solution for this problem is on this forum here
Apr 13, 2008 | Philips DVDR 3355 DVD Recorder
Have a phillips DVDR model#3455H.Inserted dvdrw disc recorded with videos recorded on it in my computer. Disc works fine in my pioneer dvdr but when I put it in the phillips it will not load and it will...
The electronic procedure:
Switch off the unit at the wall plug. On the front panel, hold in the <RECORD> and <EJECT> buttons at the same time, and keeping them held, switch on the power at the wall again. Keep holding the buttons until the disc tray opens.
Apr 03, 2008 | Televison & Video
The DV-S5450 may use a belt-loading mechanism. The belt is typically black rubber band with a diameter of approximately 2 cm. It is commonly found in front-loading CDROMs for computers also. Often, as a result of age, usage, humidity, etc the belt snaps, rendering the loading impossible. The loading motor doesn't just pop the tray in or out. It also engages a clutch assembly that raises an inserted disk or lowers a disk to be ejected; this explains why you can't simply force out the tray. Clearly in your case all the electronic signals are there and the loading motor does turn.
Solution: switch off and unplug the unit and then open it up. Do a quick inspection to see if you can locate the broken rubber band. If you can, remove it and take it along with you to the nearest repair shop for exact replacement. If you are finicky around technical work, simply a competent person do it for you. Good luck.
Jan 18, 2008 | Yamaha DV-S5450 DVD Player
Philips DVDR3390/37 DVD Recorder Logo
1,856 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
