Question about Garden
Weedeater repair It will start,but not stay running. Replaced fuel lines, cleaned carb. Is it the diaphram?
  • 7,482 Answers
Hi Sam..
I think you still have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 28, 2013
  • 3600 Answers
SOURCE: the primer bulb does not draw fuel thru carb
you need to buy a primer bulb kit and replace it cost about $8.00 and is easy to put in, the check valve is damaged.
Posted on Jul 18, 2009
SOURCE: RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Posted on Aug 02, 2009
jdlipscomb41
  • 157 Answers
SOURCE: Primer bulb stays in after depressing it.
sounds as though fuel lines are incorrectly hooked up
Posted on Sep 18, 2009
Testimonial: "Echo GT 200R Grass Trimmer.Fuel lines were correct.I had purge base gaskets on wrong side of carb.I replaced gaskets but still won't start.Carb cleane"
rycgl
  • 1545 Answers
SOURCE: weedeater starts, then dies.
The symptom indicates a fuel delivery problem, which is usually the case...but I'm not so sure it is. I presume the fuel filter, air filter, and muffler are in good working order and the spark arrestor on the muffler isn't clogged with carbon. If this is an ignition issue, the machine would struggle to start and idle unless...
While idling is when the problem arises and it seems that the ignition may be shorting out at some point if there are no fuel delivery issues. You didn't say how long the machine would idle before stopping. Maybe check the small wire to the coil that goes to the ON/OFF switch for fraying and maybe grounding itself out while the machine is running/vibrating.This wire comes very close to the flywheel and normally has a female spade-connector on it, so check it's connection on the coil and at the switch. Check the flywheel to coil air gap also. Please post back if you find any of the above with issues.
Posted on Aug 15, 2010
rycgl
  • 1545 Answers
SOURCE: i need the fuel/oil mixture
The fuel/oil mixture is 40:1. That is 3.2 oz. oil/US gallon. Now for the fuel lines:
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Posted on Jan 11, 2011
Echo Chainsaw will not stay running? has been used a few times in the last 6 months!
Because the unit fires and runs for about 6-8 seconds the issue sounds to be fuel delivery problem. If you changed the fuel lines and checked the diaphragm, was the old lines bad? The carburetor could have sucked up some of the old fuel lines. You may need to change the carburetor.
Feb 13, 2017 | Echo Garden
I have a husqvarna128 weedeater already cleaned the carb not the prob it will only stay running if the choke is halfway and you pump the throttle any suggestions?
Its definitely the carb. "cleaning" the carb usually is not a fix alone on those 2 cycle carbs. You should rebuild and clean it. The small diaphrams in those get tiny holes, and the fuel now days plays havoc on them.
Carb kits are inexpensive, just make sure you re-assemble everything in correct order.
Apr 13, 2016 | Husqvarna 128 LD Weedeater
Craftsman trimmer 25cc
Diaphrams can be tricky sometimes...seating can be irritating. If carb disassembled and cleaned out...might have to check adjustments. Make sure screw didn't get loose. I had one do that before when governor broke.
Apr 21, 2014 | Craftsman Convertible 25cc. Gas Line...
WeedEater FL 1500
if the choke needs to stay on to run it then there is a plugged jet in the carb
Aug 11, 2012 | Weedeater Garden
Husquvarna weedeater starts and runs fine but bogs down when flipped to edge.
Check the fuel tank vent, and fuel lines for air leaks. could also be a problem with carb diaphram.
Jun 12, 2012 | Husqvarna Garden
Weedeater blower GBI-22v starts then shuts off already cleaned carb,replaced fuel and filter and cleaned plug
see if it will run with the choke on, if so then looks like the carb needs new diaphram and needle
Sep 27, 2011 | Garden
I have a te400 poulon weedeater,it will start only if i put fuel in the carb port.wont stay running
Check the fuel filter in the tank, inspect fuel lines and then clean the carburetor and replace the diaphrams.
Aug 31, 2011 | Garden
Have a LT160. won't stay running. replaced filter, external fuel pump, all fuel lines. cleaned carb, jets....?????
did you check the primer bulb to make sure it was full of gas if it isn't the try to prime it if it doesn't fill up the theres a little diaphram in the carb. that might be ripped or broken & needs replaced
Nov 08, 2009 | Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
