Question about Poulan Garden
Poulan pd17542lt
Battery voltage
  • Poulan Master
  • 2,478 Answers
12-121/2 v
Posted on Apr 28, 2013
Where is carburetor on poulan 17.5 hp 42 inch cut riding mower
Under air filter. First check battery voltage. Should be 12-12 1/2 V
Mar 15, 2016 | Poulan Garden
Kohler ch740-0101 engine will not start unless assisted with charger booster. when attempting to start unassisted voltage drops to below 11.5 v and will not start. replaced batteries but problem still...
this sounds as if you have a bad cable/connection or starter relay has some dammaged contacts to be responsible for voltage drop
sometimes the wire comes loose from back of connector
Jul 14, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Key start engine when key is turned nothing happens
Have the battery load checked at a local auto store. If its good, then check the voltage at the starter when the key is turned to the start position. It should be twelve volts DC. If you have no voltage there at the starter that you may have a bad key switch. Check all the safety switches before making a ruling on a bad switch.
Sep 02, 2013 | Poulan Pro " Pro" Self Propelled Mower
Poulan 38" riding mower.
Battery is likely dead - or has built a sediment bridge - shorting the anode and cathode.
Jump-start the tractor with your vehicle - or another battery to check.
Or - use a multimeter to ensure your battery is not draining to 0V when you attempt to start.
This also indicates a failed battery. It may have a decent float charge - but when the load starter) is applied - the voltage will drop right out.
Thanks for using FixYa!!
Aug 03, 2011 | Garden
I need a starter .i have a poulan 15.5 hp ohv i/c rider mower briggs& stratton how much does it cost
Before you shell out a bunch of money for a starter, unless you are sure that is what's wrong, there are a few things to check out first:
1. Safety switches
2. Starting solinoid
3. Ignition switch
4. Battery
Those are for if you have no response whatsoever. If it turns, but barely, check the following:
4. Battery (could have one bad cell and still hold some voltage, try jumpstarting the motor)
5. For over head valve (OHV) engines, adjust the intake and exhaust valves.
I hope this helps.
Aug 02, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have a brand new battery in my Poulan garden tractor. When trying to start, the flywheel will go around slowly and try to start but won't fully crank. When I put a battery charger on the battery it...
Bad battery, I know that you said that you have a new battery, try to borrow one from a neighbor and test it. Yours could be insufficient in cranking amps or your battery is bad. I have had a battery that would show the proper voltage, but as it had aged the cranking amps had fallen off and it could not do it anymore. This condition is not so common as a bad cell, but it does happen, it did to me.
I hope this helps.
Jul 22, 2011 | Poulan Pro Garden Tractor 2005 and Older...
ENGINE HAS SO MUCH COMPRESSION STARTER WILL NO TURN IT. HAVE RESET VALVES TURNS FINE WITH PLUG OUT
I would get the battery checked. It may have the full voltage available (dash and head lights may work) but as batteries age they loose their cranking amps. Depending on what type of battery it is you may be able to get it tested at an Auto-Zone, O'Reileys or similar store under load to see what cranking amps are available.
Mar 24, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
My poulan pro riding mower clicks but wont turn over?
Check the battery voltage with a multimeter. It is possibly low. If so, you can try to charge it. At your own risk, you can attempt to "jump" the mower battery with a car battery. I don't advise this as a common practice. They both are 12 volts, the difference is in the amount of CCA available (Cold Cranking Amps).
Jan 11, 2011 | Poulan Garden
2005 Poulan PD17542LT Lawn tractor, It starts fine but after cutting my front yard (20-30min) it dies, it will start up but dies in a few sec. If I let it set and cool off I can get 20=30 min till it gose...
Normal maintenance been applied to this rider ? Filters, lube, cleanings ? This sounds like an electrical issue (component hot), or a vacuum in the fuel tank. Next time it 'stops' open the fuel tank up and listen to any air 'whooshing' in.
Jun 22, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
32 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
