Question about Lion Brand Homespun Yarn
Decreasing knitting stitches
When I decrease stitches in knitting I loose the pattern. How can I avoid this?
    Problem Solver:
  • 17 Answers
What do you mean you loose the pattern? Can you please be more specific? Thanks
Posted on Jan 15, 2014
List of abbreviations for crochet
easiest Google ever! :>) There are images to in the main link at the bottom.
Crochet Abbreviations Master List ' Welcome to the Craft Yarn Council
www.craftyarncouncil.com/crochet.html
Following is a list of crochet abbreviations used in patterns by yarn industry designers and publishers. The most commonly used abbreviations are highlighted.
How to Read a Crochet Pattern
How to Read a Crochet Pattern ... Here is how to make a slip ...
The Craft Yarn Council
Crochet Chart Symbols. Stitch charts in crochet and knit ... More results from craftyarncouncil.com »
Guide to Crochet Abbreviations - The Spruce
https://www.thespruce.com > ... > Needlecrafts > Crochet > Crochet Basics That said, if you happen to come across a pattern that is missing its abbreviations, here is a listing of commonly used crochet abbreviations chat can be useful.
How to Read Crochet Abbreviations - dummies
www.dummies.com/crafts/crocheting/how-to-read-crochet-abbreviations/ Most crochet stitches appear as abbreviations to save space on the written instructions. For example, you'll see the abbreviation dc instead of double crochet ...
Learn to read crochet patterns - Annie's Catalog
https://www.anniescatalog.com/crochet/learntoread.html It's not necessary to learn the abbreviations and symbols all at once, but refer to the lists as you find these terms listed in your crochet patterns. Some things to ...
Crochet Abbreviations - Abbreviations and Acronyms - YourDictionary
abbreviations.yourdictionary.com > ... > Crochet Abbreviations Commonly-used Crochet Abbreviations. beg - beginning. BL - Back Loop, block, or bobble, depending on the context. BP - Back Post. ch - chain stitch. cl - cluster. cont - continue. dc - double crochet. dec - decrease.
Crochet Abbreviations listing and key for standard crochet pattern ...
www.sweaterbabe.com/crochet-abbreviations/ Common crochet abbreviations and terms listed and explained for learning to read and follow crochet patterns. Standards used by crocheters.
Crochet Instructions - Crochet basics and Crochet abbreviations
www.crochetnmore.com/123basics.htm Crochet instructions, including crochet abbreviations and the crochet basics and so ... ask about a treble decrease so I'm listing this stitch again in different terms.
List of abbreviations for crochet - Google Search
Apr 30, 2017 | Sewing Machines
Decreasing single crochet stitches
There are several ways of decreasing crochet stitches, but the pattern should indicate what stitches to use. The most common (or easiest) is to yarn over in the first stitch (do NOT pull the rest of the stitch through) and then yarn over into the second stitch and pull the final stitch through both yarn overs.
How to Decrease Single Crochet dummies
Mar 18, 2017 | Sewing Machines
How to increase a knitting pattern Gingersnap
Usually increasing stitches is accomplished by knitting (or purling) twice in the same stitch.
How to Increase and Decrease Knitting Stitches For Dummies
Decreasing is accomplished by knitting (or purling) two stitches together.
Jul 14, 2016 | Sewing Machines
Hand knitting. the front sections of a jacket mentions to OMIT a stitch at the end of every row - what does that mean? decrease? or Slip1 knit1 and pull slipstitch over?
If it says "omit," then I'm guessing it means to not do anything in the last stitch of the row. However, you may also be able to just knit two together or use the slip stitch. It will probably affect the appearance of the edge, but you may just have to experiment on a test to see which looks best for your pattern.
Jun 13, 2016 | Sewing Machines
What does ssk mean in knitting and do you have a list of different meanings for kniting
Slip slip knit or SSK is a basic way to decrease stitches. It makes a decrease that slants to the left and is often paired with knit two together, which is a right-slanting decrease.
To execute this decrease, slip the first stitch as if to knit, slip the second stitch as if to knit, then slide the left-hand needle into the front part of both stitches and knit them together.
Oct 21, 2014 | Sewing Machines
What is:g/knit_two_tog.htm ???
knitting instruction, knit two together is a way to decrease the number of stitches, you put the needle through two stitches, wrap the wool around to make a stitch and pull the loop through making a new stitch.
How to Knit Two Stitches Together eHow
Feb 09, 2014 | Sewing Machines
I am knitting a hat that is smaller than the instructions call for . How do I determine the amount of repeat stiches between the decreases for the crown
you could just use a smaller needle and use the pattern as is..to determine the repeats,look at the the pattern and see how many repeats they have in it.decrease one st per repeat all the around..
Feb 08, 2014 | Sewing Machines
I am not sewing i am knitting
i usually knit until the size i want..then divide the stitches by the largest number you can get..place markers between the stitch number you came out to..do this on a knit row before decreasing so you can be prepared for the following row.once you reach the markers k2tog and knit till marker and repeat around...
Lion Brand Homespun Yarn Logo
140 people viewed this question
Top Lion Sewing Machines Experts
Chance Miller
Donald Ayers-Marsh
Debbie
Are you a Lion Sewing Machine Expert? Answer questions, earn points and help others
