Question about Samsung Verizon Wireless 4G LTE Mobile Hotspot SCH–LC11
Samsung factory reset
No recovery
Hi, I did a factory reset on my Samsung Galaxy S7 and lost my photos. Is there a way I can recover that data without rooting (jail breaking) my phone. I would like to return it to Verizon.
Option 1: Recover Android Data from Google
If you have set up Google account on your Android and enabled synchronization for all data, after factory reset, you can set up your Google account again on the phone. An option during the set up process will allow you to restore all the synced data.
Option 2: Restore Android Data from Backup
Many Android phones are endowed with local back up app or function. If you have backed up data regularly, then, after factory reset, just go to "Settings" > "Back up & restore", and select the latest backup file to restore data from backup.
Method 2: Android Data Recovery after Factory Reset without Backup Unfortunately, you might performed factory reset accidentally without backup, or the backup file lost or failed to be recognized by your phone, or some data couldn't be backed up, etc. If you come across any one of these situations, a professional data recovery software, Gihosoft Android Recovery Free, will do you a favor. With it, you can not only recover photos after factory reset on Android devices, but also other erased data. Moreover, it supports Samsung Galaxy S8/S8 +/S7/S7 Edge/S6/S6 Edge/Note 5/J7/J5, HTC 10/A9/M9, LG V20/V10/G6/G5, Sony, Motorola, Google, Huawei, ZTE, OnePlus, etc.
Fore more info, check this link https://www.gihosoft.com/android-recovery/recover-data-after-factory-reset-android.html
May 25, 2017 | Samsung Cell Phones
How do I restore factory presets to me Samsung Galaxy 6?
You need to do a factory recovery. Follow the link and read the information there n doing a reset. Two Ways to Factory Reset Galaxy S6 and Galaxy S6 Edge
Dec 30, 2016 | Samsung Cell Phones
How do i restore system factory settings on a samsung R50 PC
Method one:
<1>. Press and hold on Esc key, and then start Samsung laptop
Note: Please don't loosen your hand on Esc key until the Samsung laptop starts with restore system.
<2>. Find Samsung Recovery Solution program, and run it. Or Enter Menu window.
Note: Samsung Recovery Solution is system restore program provided by Samsung. Used for Samsung password recovery etc.
<3>. Press F11 to restore Samsung factory setting.
Method two:
As we all know, Samsung laptop is taken with one function that Samsung factory reset with one key. Just start your Samsung laptop and press F4 or F7 at the same time. And Samsung laptop will run system restore program automatically.
May 21, 2016 | Samsung Computers & Internet
How to recover deleted contacts for galaxy s4 after factory data reset?
I would say yes there are a number of data recovery programs available which can do this for you but you have be real quick with the recovering process, because further delay means that place where your data previously was gets over written by something else. You can use software to recover you data back. But do remember act fast over it and don't try writing something more over it otherwise the chances of getting your things back will decrease.
MobiKin Doctor for Android Windows Version
Recover Deleted Contacts from Android
Apr 30, 2015 | Samsung GALAXY S4
Factory settings samsung pc np-r580
Before you start the recovery process be sure to have backed-up your data. Returning to Factory state will completely erase you hard disk. You do not have to do a restore to factory settings; Samsung provide various levels of recovery
Certain links from this webpage
Global Download Center
should tell you how to perform this task. There is more than one way of doing it.
Consult chapter 4 of the manual http://downloadcenter.samsung.com/content/UM/201409/20140901105918371/Win7_Vista_Manual_eng.pdf
This discussion from the Microsoft community sumarises it:
how do totally reset my samsung np r580
12.February.2015
Feb 12, 2015 | Samsung Computers & Internet
My phone keeps flashing on and off
If it's in warranty take it to service center
if not, go to recovery mode and restore factory setting
if you are having the same problem in recovery mode, it might be a hardware prblm as well..
How to factory reset Samsung Galaxy S3 mini I8190
Oct 08, 2014 | Samsung Cell Phones
S5600
Samsung S5600 Preston Hard Reset:
  • Press and hold Volume DOWN + Camera + POWER Until Samsung menu Appear
  • Now you see android recovery menu
  • Now select Wipe data/factory reset and press power key to confirm
  • Now select Yes -- Delete all user data and press power key to confirm
  • Now reboot device
  • hard reset done
Hard Reset By Code:
  • Enter Dial number *2767*3855#
  • Now you see Factory Format
  • wait until factory format complete
  • after factory format handset will be reboot
  • hard reset done
Apr 24, 2014 | Cell Phones
How to reset a samsung htc on lock screen
  1. 1Power down your device. Before you begin the reset procedure, you will need to completely power your device off. If it is frozen, you can pull the battery out to turn it off.
  2. Press and hold the recovery buttons. The buttons vary from device to device, so you may need to look up the instructions for your particular phone. You will need to press and hold the buttons for a few seconds. Some of the more common button combinations include:
    • Volume Up + Home + Power
    • Volume Down + Power
    • Home + Power
    • If none of the above work, do a web search for your phone's model plus "recovery mode"3
    • 3. Select Factory Reset. Once the recovery menu opens, you can navigate the menu with the volume buttons. You may need to open the Recovery menu to find the Factory Reset mode. Use the Power button to select your menu options.
      • You will be asked to confirm the factory reset.
      • 4
      • Wait for the restore process to compete. After your phone resets, it will be set back to factory defaults and will be like it just came out of the box.[2]
Mar 04, 2014 | Samsung Galaxy Ace GT-S5830
Notebook NP-N210-JB02HK White 250G Win 7
hello,
use the preinstalled software 'samsung recovery solution'. with this software u can reset your netbook to factory reset / complete restore.
the software guides you through the process.
take care to save all your datas (pics, docs, and so on...) before resetting ! Or you may lost them all...
best regards nayss
Oct 29, 2013 | Samsung Notebook NP-N210-JB02HK White 250G...
Can I do a factory reset on my Samsung Q30 Laptop
To factory reset your laptop, Run the Samsung Recovery Solution.
Select Start > All Programs > Samsung Recovery Solution > Samsung Recovery Solution.
If windows will not start you need the Recovery CDs.
WARNING !!! Be sure to back up an data you wish to keep, this procedure will wipe it out.
Oct 19, 2008 | Computers & Internet
Samsung Verizon Wireless 4G LTE Mobile Hotspot SCH–LC11 Logo
55 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
