Question about Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White
Stuck faucet does not swivel
Grohe Parkfield kitchen faucet wont swivel smoothly. Have to really push it to move from one side of the sink to the other.
There may be some kind of residue clogging the swivel part. It may be necessary to disassemble the faucet to allow the swivel part to be cleaned.
Nov 14, 2016 | Grohe Home
Tip
Diagram-Type Faucets
DIAPHRAGM-TYPE FAUCETS
  • The diaphragm faucet is washerless but is similar to washer-type faucets. A rubber diaphragm between the stem and seat creates a straight-down, frictionless close. As with washer-type faucets, diaphragm faucets have two handles.
  • Remove the stem by following the steps outlined for washer-type faucets. Instead of a washer on the end of the stem, you'll find a swiveling disc. If the rubber diaphragm doesn't come out with the stem, it is still inside the faucet.
  • If the diaphragm didn't come out with the stem, use pliers to peel it from inside the faucet and pull it out. Install a new diaphragm around the swiveling disc, then replace the stem in the faucet.
  • If the faucet is leaking around the stem, replace the stem's O-ring before reinstalling the stem.
on Jan 16, 2010 | Plumbing
Rohl pull down faucet does not swivel but to one side
Improperly, maybe. Incorrectly, probably. Have the installer redo.
Jan 27, 2016 | Rohl Plumbing
Water Ridge kitchen faucet model FP4A4107NP does not swivel between sinks. I thought they all could be directed into either side of a double sink?
Did you install the faucet without using the top mounting plate? This could cause no spout swivel.
Dec 26, 2014 | Plumbing
Am installing a new American Standard faucet. Does it need to be lubed prior to installation?
I think American Standard probably is correct, especially if there is a history of swivel faucets seizing over time.
Dec 11, 2013 | American Standard 4205.104.075 Reliant...
Flip over bathroom plug in bath stuck & bath full :/
follow this steps and fix it. God bless you
  1. Remove the shower head from the pipe.
  2. Clean the arm threads and wrap them with plumbers' joint tape.
  3. Screw the head back on and hand-tighten it. Remove any excess compound or tape.
  4. Test and retighten as needed.
Repair a shower head that leaks at the swivel:
  1. Unscrew the shower-head body from the swivel-ball ring.
  2. Find the O-ring or a similar seal inside. Replace it and screw the shower head back into place.
  3. Turn off the water supply and open the faucet handle to relieve water pressure.
  4. Carefully loosen the coupling nuts at the shutoff valves and at the base of the faucet.
  5. Carefully remove the supply tubes.
  6. Remove the locknuts that hold the faucet to the sink and lift the faucet out.
  7. Clean the area where the old faucet sat.
  8. As needed, install the new spray hose and supply tubes, if any, through their holes in the sink.
  9. Set the rubber gasket that came with the faucet on the sink where it will be mounted. If no gasket is supplied, apply plumber's putty.
  10. Set the faucet into position and center it.
  11. From under the sink, attach the faucet locknuts to hold it to the sink.
  12. Reinstall the supply lines, then turn them on and test the faucet. Turn it on carefully because the line and faucet have air in them.
Nov 28, 2013 | Home
My rohl A3608 is leaking from the lower swivel on the faucet, how does the faucet above this swivel come off for repairing the leak?
there is a 2mm set screw on the back of the neck. Contact ROHL customer service 800.777.9762 to get replacement o-ring set to repair leak.
Sep 16, 2013 | Rohl Plumbing
Danze D456513 kitchen faucet will no longer swivel. How do I correct this?
The swiveling part may have corroded. You can attempt repair by disassembling the faucet and removing the corrosion or simply replace the complete faucet
Mar 23, 2013 | Danze Plumbing
My blanco kitchen mixer does not swivel. It is stuck in one place
You need to remove the handle and then remove the top cover to the housing. After the cap is removed you can pull off the spout. It probably needs new washers. You will see what you need to fix it at this point. Just remember to turn off your water before doing this.
Mar 22, 2009 | Blanco CLASSIC 1 Handle Pull-out Spray...
Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White Logo
14 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
