Question about Coffee Makers & Espresso Machines
Vitale S coffee machine
My coffee machine won't work and all the lights are flashing as per the video
    New Friend:
  • 26 Answers
Looks like you need to descale your machine. A good cleaner is CLR. Follow the instructions on the bottle. If you don't want to purchase that, use white vinegar. Fill up the reservoir and run a brew cycle after letting sit for 20 mins. Make sure u run clean water threw at least 3 cycles once done
Posted on May 06, 2013
Noggin
  • 944 Answers
SOURCE: Program light and time flash once per second
Here's the link to the user manual if you need it; http://www.cuisinart.com/share/man/34_man.pdf The water filter should be fine - if not it should be obvious to the eye that it is blocked/restricted - hold it up to the light. Try running through the descaling procedure in the manual if you havent recently - if it doesnt let you run a cycle, try it overnight without running it, and see if it will let you run a vinegar cycle in the morning. Try and pour vinegar into all the parts you can where it would go if a cycle was able to be run. If that doesn't get it running, check that none of the program/time setting features are still on - they should turn off after a few seconds, but maybe it is stuck in "time set" mode or similar. If none of the actions in the manual change the setting, try unplugging the unit and leaving it for at least half an hour unplugged, then hold down the power button when you plug it back in - this should reset the machine. If the reset doesn't work, it sounds like you have a control board fault - best solution is to contact cuisinart; http://www.cuisinart.com/contact/ Hope this helps :)
Posted on Aug 01, 2007
heatman101
  • 43501 Answers
SOURCE: The blue light on the left doesn't light up.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Posted on Sep 03, 2011
mc1bean
  • 3053 Answers
SOURCE: The coffee maker suddenly stopped
Hello, ck
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
SOURCE: Coffee bean light won't go out when full and coffee won't work
Hi coffee friend I have just answered this question. I think
After you have done all the cleaning you have done, you can try this: do check that all knobs correctly set. That the steam spout is closed. that the water tank sitter correctly
Disconnect from power, wait 2-3minutes connect again and hope for the best.
Kolbrun
Posted on Apr 16, 2012
bugoy31
  • 1238 Answers
SOURCE: no water going to coffee part of vitale s coffee machine
you possibly have faulty pump
Posted on Nov 06, 2012
Saeco Odea Go machine, red light blinking,
when the red light blinking it means machine must be primed. BUT if you prime it and still red light -you have to change the FLOWMETER.
Dec 24, 2017 | Saeco Odea Go
I have a Nespresso Lattisima and all four lights are blinking four times in quick succession and nothing is working. I've tried emptying it out and it's done that, but still the same problem.
Your machine has almost certainly entered the water quality mode. (Water hardness setting). This is very easy to fix. Switch machine off. Before switching back on press and hold any off the following buttons: Latte Macchaito (top right) for soft water, Cappuccino (bottom right) for medium water or finally both of them for hard water. While holding the correct buttons switch the machine back on BUT hold for approx. 10 seconds or until all lights stop flashing, (APART FROM THE BUTTON YOUR HOLDING). This will reset the machine and you're good to go. Regards Coffee Engineer!
Jan 17, 2013 | Nespresso Lattissima 660.R
My Saeco xsmall plus espresso machine is flashing red light on it
Owning this machine for nearly five years, all I can say is that it is an example of problematic engineering. It does not except dark roast some of the time, and if it is very well roasted it won't accept it at all. As the machine is fully automatic, there is not much you can do but roast the coffee to a degree that will be accepted by the machine. IMHO this is an unacceptable decision made by engineers and Saeco should address this issue.
Nov 04, 2012 | Saeco Coffee Makers & Espresso Machines
Red light won't stop flashing. Parts are in place
Be sure all coffee grounds are cleaned from beneath the water tray and the grounds tray and the coffee brew group. We had the same problem but finally redid everything, including cleaning the coffee brew group under hot water, drying and replacing carefully until it clicked in place. The moving parts of brew group have to be in exactly the right place. Good luck!
May 12, 2012 | Saeco Spidem Villa
Kolbrun
Apr 16, 2012 | Solis Palazzo Espresso Machine
Won't even turn on. Was flashing cup size lights on left & right and I turned it off and later tried to turn it on and it won't turn on.
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 13, 2011 | Keurig B100 Coffee Maker
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
Aug 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Coffee Makers & Espresso Machines Logo
398 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
