Question about Garden
Scag 48" belt drive with tecumseh 5 spd.
My mower pulls good in 4 & 5 gear, but in 1,2,& 3 it jumps in and out of gear like a hesitation? Is it the shifter plate or shifter dogs?
SOURCE: MOWER CONTINUES TO PULL AFTER DRIVE CONTROL IS RELEASED
try and slacken the adjuster nut on cable mate there shoul b 1 smwhere at top of cable near drive control lever/handle and also 1 at drives gearbox. failing that mate it could be a tensioner spring on the drive control mechanism
Posted on Apr 17, 2009
  • 21 Answers
SOURCE: Troy Mower Belt Slippage
If you have an tension adjuster on the handle loosen up until you can slip it back on. If thats not enough remove the spring at the tranmission.
Posted on Jun 21, 2009
bobthebulldo
  • 67 Answers
SOURCE: Mower takes too long to pick up speed
check that the belts are at right tension as they could be sliping slitly and that is why it is taking the time to kick in ,try tightening the belts a bit
Posted on Oct 17, 2009
SOURCE: i have an MTD 3.5 hp Tecumseh lawn mower. The
WHAT KIND OF OIL DO I NEED FOR THE LAWN MOWER
Posted on May 14, 2010
  • 143 Answers
SOURCE: Ihave a Rally mower with a Vector Tecumseh 5.5 hp
Sound like a dirty air breather filter or dirty carb. jets. Remove carburettor and blow out with air. Stephen
Posted on Sep 11, 2010
My scag 48 inch walk belt driven ,is having trouble going up slight hills , already change the clutch springs
I also have a 48" Skag wall behind mower. Have you checked the tension on each wheel's belt when under load? It that where the slippage is, or is there a slow down on the engine itself? If the engine is slowing down...several things to check...needs tune up...plugs...I also use premium gas in my mowers and get better performance. Check all belts for where and slippage. Is it engine or some mech connection?
Hope this helps
Paul
Jun 10, 2017 | Garden
My 36 inch scag mower skips whilein drive speeds
Could be the drive belt slipping or a gear slipping. I would try the belt first.
Oct 08, 2014 | Garden
Why did my Lawn Boy Platinum self propelsion quit?
I believe there is a V-belt that drives the front wheels,it may have broken,or the gears in the gear box have failed !
Jun 22, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Drive gear does not engage
Cable adjustment,broken V-belt, bad gear box.
May 30, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
2008 poulan pro 18.5 hp 42" cut 6 spd smokes bad when i put it in gear
check drive belt make sure its not rubbing against melt guied tabes
Aug 18, 2013 | Poulan Pro Lawn Tractor 2006 and Newer...
Scag mower
Worn tention springs
Jun 12, 2013 | Garden
911 electric start repair
remove the starter and see if the gear is broken
Aug 09, 2012 | Garden
Belt size for 616 deutz allis riding mower ,deck & drive
most wear parts numbers are on the bottom side of the hood.
Jul 29, 2012 | Garden
What automatic transmission was used in the 1992 Ford F-250 Diesel
A.T., 4x4, AOD (5.0L)
EAC}G}}400" type="radio" name="userInterchange" />A.T., 4x2, AOD (5.0L), 11-1/4" ext hsg
EA}}}400" type="radio" name="userInterchange" />M.T., 4 spd (Warner T-18), 4x4
M.T., 5 spd, Mazda/Toyo Kogyo, 4x4
M.T., 5 spd, ZF, 4x4, 8-460 (7.5L)
M.T., 5 spd, ZF, 4x4, 8-445 (7.3L, diesel)
EAA}N}}400" type="radio" name="userInterchange" />A.T., 4x2, AOD (5.0L), 10-1/4" ext hsg
M.T., 4 spd (Warner T-18), 4x2, 12" ext, cable drive speedo
M.T., 4 spd (Warner T-18), 4x2, 12" ext, elec speedo
M.T., 4 spd (Warner T-18), 4x2, 4" ext, cable drive speedo
M.T., 4 spd (Warner T-18), 4x2, 4" ext, elec speedo
F>}A}}400" type="radio" name="userInterchange" />A.T., 4x4, C6, 8-460 (7.5L), (elec speedo), (tag F2TP-YA)
M.T., 5 spd, ZF, 4x2, 6-300 (4.9L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-351 (5.8L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 6-300 (4.9L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-351 (5.8L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-460 (7.5L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-460 (7.5L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-445 (7.3L, diesel), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-445 (7.3L, diesel), elec speedo
M.T., 5 spd, ZF, 4x4, 6-300 (4.9L), ID E9TA-TA & TB
M.T., 5 spd, ZF, 4x4, 8-351 (5.8L), ID E9TA-TA & TB
M.T., 5 spd, ZF, 4x4, 6-300 (4.9L), ID F4TA-BA & BB
M.T., 5 spd, ZF, 4x4, 8-351 (5.8L), ID F4TA-BA & BB
>C}}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, elec speedo
>D}A}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 2.73 ratio
>D}A}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 3.08 ratio
>D}B}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 3.55 ratio
>D}B}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 4.10 ratio
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 6-300 (4.9L), (elec speedo), ID F2TP-BA
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 6-300 (4.9L), (elec speedo), ID F2UP-DA & DC
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-302 (5.0L), (elec speedo), (ID F2TP-DA)
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-351 (5.8L), (elec speedo), ID F2TP-FA
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-351 (5.8L), (elec speedo), ID F2UP-EA, EB & EC
?}}}400" type="radio" name="userInterchange" />A.T., 4x4, E4OD, 8-351 (5.8L), (elec speedo), (ID F2TP-HA)
}}}400" type="radio" name="userInterchange" />A.T., 4x2, C6, 8-460 (7.5L), (elec speedo), ID F2FP-CA & DA
A.T., 4x4, E4OD, 8-460 (7.5L)
E}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-445 (7.3L, diesel)
A.T., 4x2, C6, 6-300 (4.9L), w/o ID F2FP-BA; w/o ID F2UP-CA
A.T., 4x2, C6, 8-351 (5.8L), w/o ID F2UP-CA
A.T., 4x2, C6, 6-300 (4.9L), w/o ID F2FP-BA; ID F2UP-CA
A.T., 4x2, C6, 8-351 (5.8L), ID F2UP-CA
A.T., 4x2, C6, 6-300 (4.9L), ID F2FP-BA
A.T., 4x4, E4OD, 8-445 (7.3L, diesel)
A.T., 4x2, E4OD, 8-460 (7.5L)
A.T., 4x2, C6, 8-445 (7.3L diesel)
EF}D}}400" type="radio" name="userInterchange" />A.T., 4x4, C6, 8-351 (5.8L)
Good luck
Aug 10, 2010 | 1992 Ford F250
1994 prelude h23 2.3 non vtec 5 spd at start up no cel- smooth idle. under accel it jerks and hesitates but rpms stay solid, however unmoving. strong smell of gas. low power. after driving a few minuted...
Try replacing Oxygen sensor (top of exhaust pipe just rear of engine; 22mm ring-spanner job after cutting wires); though normally comes up with Code 1 on the MIL, this is the right bunch of symptoms.
Jun 12, 2009 | 1999 Honda Prelude
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
