Question about Altec Lansing VS2121 Computer Speakers
Open speaker How can I open the speaker vs2121?, I would like to open the case to repair it but I can't because I don't find the screws. Who can help me with this problem?
How to fix a jammed cooling fan
Opening the case is simply a matter of removing the case screws and opening the case. It\'s not difficult. Just be aware of small parts that may come loose in the process.
A few good tips:
  1. Have a clear work space with enough room to set out the parts as they are removed
  2. Projector cases often use a variety of screw lengths and sizes. Draw a map of the projector and place the screws in their positions to help you remember where the screws go when it comes to reassembly (see diagram)
  3. Take pictures for reference later
  4. It might make it easier if you remote the lamp first. Remember, it\'s important not to touch the lamp or any glass part with your bare fingers. It will cause black spots on the lamp and possibly premature failure
  5. Don\'t force the case closed on reassembly. Check for parts that aren\'t seated correctly.
Don\'t bother trying to repair the fan. These are often MagLev types and it\'s much easier to just replace them with an equivalent part. Here\'s a 5000 pound sterling projector on which I replaced the fan.
Sep 04, 2014 | Dell 4210X DLP Projector
How to open/repair Logitech S100 speakers for the power cord replacement?
first open the net over the speaker...top bottom corner there is a hole then in this hole put a strength stick pressure heavy by side..then it will show u crack by this crack u have to open it!!remind there is no screw in s-100 logitech speaker!!Thanx!
Feb 07, 2013 | Logitech S100 Computer Speakers
Pyle PDWR68B speaker has an internal speaker loose
Buy one speaker. You can bought it from any electronic spare part selling shops.
Jun 02, 2012 | Pyle PDWR68B Center Speaker
I have the speakers S125i of logitech, but there is a piece that is loose inside of the speakers, at the begining the speakers sounds well, but then the left speaker stoped working. I think I'm able...
The Logitech is a little tricky. You need to carefully pry off the white bezel around the speakers and then pry away the grills. Under the grill you will find four screws holding the two speakers, and four screws set deep in holes.
Undo these eight screws and the front will come off.
Jul 20, 2011 | Logitech S125i
Hi, I have a pair of EVZX4. One of them making really bad noise especially when bass playing. I wanted to open and check the problem but I couldn't. I don't know how to open and rich the twitter....
MOST of the plastic cased speakers have a BUNCH of screws from the back, some in "wells" and others along the edges that have to be removed to allow the front half of the case to separate. When all screws are out, a gentle pry will separate the front. Note SOME of the screws in the wells require a very long Phillips screw driver... usally a number 3 size as well.
May 07, 2011 | ElectroVoice Ev Zx4 15" 2way Electro-voice...
I need to figure out how to open up the subwoofer for the Altec Lansing vs2121 model. Thank you
theres no on/off button for the subwoofer. once you plugged in the power cable,turn on the speaker system by turning the VOLUME knob on the right satellite until you hear a click sound.
An LED will light on the front of the right satellite when the power is ON. if you still dont hear any sound from the sub woofer then check to make sure that all cables are connected properly and are making a clear connection.
hope this help
Sep 06, 2010 | Altec Lansing VS2121 Computer Speakers
Altec lansing vs2121 model speakers blown
I have the speakers ( in perfect condition) but can not find the base unit. Do you want to sell your base unit ? Or do you want to buy the speakers ?
stevem727@gmail.com
Mar 11, 2010 | Altec Lansing VS2121 Computer Speakers
One speaker not working
jjohnmith
First things first:
1) check your speaker for good connector, and all is working is playing fine.
2) check if your warranty covers one SPK. or RMS
other than that ,
Good Luck
Feb 01, 2008 | Altec Lansing VS2121 Computer Speakers
Hi
Looking at the manual http://www.alteclansing.com/downloads/EUR/VS2121%20manual.pdf page 3 of the pdf says Connect the lime green 3.5mm stereo cable (hardwired into the right satellite) to the lime green input labeled ?FRONT? on your sound card. So your right speaker should have a cable with a green end that plugs into your standard audio out jack If you have multiple outputs and don't know which you are set up for, then turn the speakers on and up, put a long song on, and plug that green wire into every jack on the PC! If you've got no other issues you'll hear something! Good Luck
Aug 28, 2007 | Altec Lansing VS2121 Computer Speakers
Altec Lansing VS2121 Computer Speakers Logo
55 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
