Question about Goodman CLQ36AR49 Air Conditioner
Wiring diagram Fan went out hired a guy to replace it. He forgot where the wires from the motor go. Black/high - red/low - purple/common. I don't have a schematic. Can you help? Motor GE P993AS 1/3 hp
ranger25
  • 72 Answers
SOURCE: wiring diagram
The white wire is nuetral, if you are trying to make a shop fan or something like that then you hook it to the white wire which goes to the wide spade on the outlet. The black one which is the hot and goes to the smaller blade (looking at an outlet in the U.S. on the right hand side) on the plug and should be for one speed operation. The other three should be capped off if you use it this way. If not, then cap off the black on on the motor and run the hot wire on the plug through a three stage switch. To find what speed corresponds to what wire you have to check resistance to the white wire and the lower the resistance, the higher the speed and hook up to switch accordingly. Also, ground the case with a solderless ring connector under a mounting screw attached to the ground prong on plug. Hope this helps.
Posted on Jan 28, 2008
  • 143 Answers
SOURCE: CHANGING OUT A FAN MOTOR
The black and white wires get 220 from the contactor. The brown and brown/white go to the capacitor. I do hope you bought a matching capacitor to go with the new motor. They don't cost much and make the hook-up way easier.
Posted on Jul 25, 2008
burzerko
  • 254 Answers
SOURCE: HELP!!! Help wiring new motor for CKL60-1
  1. This is what your wiring should look like if you are using two caps. then you should be using a potential relay as well. This is the diagram for using a potential relay. Hope it helps you.
Posted on Aug 28, 2008
Sea Breeze
  • 4654 Answers
SOURCE: replacing old 3 wire condensor fan motor with new 4 wire
The extra wire is a additional speed wire and the existing model that you are installing is possibly not set up for that additional speed. It depends on the exact model of air conditioner that your post says you have, but we can never be sure until you confirm the model number of your Goodman, if its a split unit, a package unit or condenser fan or evaporator fan. Let me know all of those answers and I will help you determine the answer, Thanks, Sea Breeze
Posted on May 08, 2009
shastalaker7
  • 1515 Answers
SOURCE: I have a goodman phkjo48-1 heat pump about 5 yrs
Yes Jay, this is what happened. Hopefully you didn't burn out the condenser fan motor you just had tested.Brown normally connects to the capacitor, as this is what starts and keeps the motor running. Hopefully, it just got hot and overloaded to trip the breaker. You say there are 3 wires coming out of a junction box, but you don't remember how they go. @ are hot wires as this motor is 220 volts. Not being onsite with you, and the wires are now faded from the sun, you will need to find out where they connect, ( the 3 coming out of box ) to see which 2 go to most likely they contactor you replaced. They will connect 1 to the load side and the other to the load side but opposite each other. The load side is the side of the contactor that the main 2 hot wires dono't connect to. This is the line side in.If you are sure you wire the contactor right, then it has to be the motor. If you follow the brown wire back, it should go to the run capacitor. Re-check your connections on the motor, even if you have to look at the schematic, which will show you where they connect, and the colors. It should be real easy for you Jay. Get back to me and keep me posted. The new motors have 2 brn wires that go to the capacitor and 2 to 3 going to the load side of the contactor.
Shastalaker7
A/C, & Heating Contractor.
PS, Please rate me on my help to you. Thank you.
Posted on Feb 17, 2011
Gentlemen, I have a GE P547BS fan motor.I'm trying to replace it with a Mars 10584 fan motor.
You can check the colors on the wires with an ohm meter to find there function. Highest resistance is low speed lowest resistance is high speed the one left is medium.
Aug 25, 2015 | GE Heating & Cooling
Mars blower motor diagram?4 wires
Gentlemen,
I have a GE P547BS fan motor. I find replace it with a Mars 10584 fan motor. GE has five wires, BRN, YEL,PUR,BLK,RED. Goes through the capacitor with the yellow going on to 200 V the purple and black go to 220 V. Mars motor as a six wire connection two Brown's go to the capacitor. yellow I'm assuming goes to the hot/neutral and a black I would say would be high-speed blue is medium and red is low. Now when I connect with this way it blows the fuse. Anybody run into this problem before? Any help? By the way, it's a 240 V single phase system.
Jun 05, 2012 | Heating & Cooling
How do you hookup a universal hvac condeser motor the old one had a black wire,red and a brown wire plus the green&yellow ground the new one has a black wire a yellow then it has back connetor thats...
WHAT??? Did the new motor come with a wiring diagram? Typically you will either be using a "3 wire" connection or a "4 wire" connection. 3 wire is for using the existing capacitor (provided it's the right size), 4 wire is for using a separate capacitor. You should have 5 total wires on new motor HIGH/LOW/COMMON/CAP & CAP. Then possibly some separate wires for ground and rotation. The ground goes right where you mount the motor, rotation...make sure its blown up and out of the machine. 3 wires would be...1 SPEED 1 COMMON 1 CAP. 4 wire would be 1 SPEED 1 COMMON 2 CAPACITOR WIRES. Good Luck!!
Apr 10, 2017 | Heating & Cooling
I have a ceiling fan switch (Westinghouse 77075) that was broken, so I do not know where the wires (black, gray, yellow and purple) went. The speeds are black+gray+yellow, black+gray+purple, and...
I can offer resources:
1) Test switch that was removed, and test for hot connection to narrow down options.
What speed was fan stuck in when switch was removed? Let's say medium speed.
Which connection at fan is hot? Use voltage tester to find hot connection at fan, and match that up with wire-color on switch that was removed.
One and only one wire on 3-speed fan switch connects to hot. And the hot wire is the only wire that connects to each other wire as switch cycles through pull-chain sequence. All pull chain switches follow same sequence: off, low, medium, high.
Let's say old switch was stuck in medium, and you know which color wire connects to hot.
Test switch with continuity tester to see which wire(s) have continuity with hot wire: some switches, it will be 2 wires, and other switches it will be 1 wire. Match where wire(s) were connected, and map that to tests on new switch.
2) Open following link for illustrations and some other links.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Sep 16, 2011 | Speed Ceiling Fan 3-speed Switch By...
I am installing a Mars 1/3 hp fan motor. It has a black wire,red wire, blue wire, yellow wire and (2) brown wire that go to a capacitor. May Furnace has Black power wire, red wire (speed) and white common....
Hello, Typically your common wire will be white, high speed- black, medium speed- yellow, medium low-blue, red- low. The motor could still run for a short time if it was wired wrong but will either trip a breaker or go off on it;s overload when it's gets hot.
Feb 26, 2011 | Heating & Cooling
I took the pump out and repaced with a new one. The wiring lugs are different. the old one has White common, black low red High. The new one has no distinction as to what is low or high. How do I hook...
all US motors should have a wiring diagram on the side of the motor unit. The wires going into the pump would hold their same values. I am assuming the previous pump was two speed as well, if not that is your problem.
assuming that they are both two speed reference the common on the pumps motor diagram, and connect the white wire to that terminal.
reference the diagram for correct low speed and connect the black wire to that termial,
repeat for the high speed.
I deal alot with the flo master pumps and they should all be labeled. The most important thing is to get the common correct, switching the other two wires (black and red) incorrectly would simply result in high coming on when low is supposed to and vice versa.
If there really is not a diagram, here is the most typical setup for that motor.
(if you look closely at the terminals on the motor, there are numbers there)
connect the white common to terminal #5
connect the red hot wire to terminal #1
connect the black hot wire to terminal #2
connect the ground
done
Hope this helps.
If this post has helped you, please take the time to vote positively for me on this site.
thanks, and if you need more help, email me @ : adamh@newconceptchem.com
Oct 28, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
High voltage blower motor wiring diagram for air handler model ar36-1
you should have three wires if its factory specified and it should be purple,brown,black purple goes to common on capacitor,brown to fan on cap and blk to defrost board
Sep 14, 2010 | Heating & Cooling
How do I wire a new condensor fan motor to the new capacitor? The old capacitor is longer and it has 3 terminals. the new capacitor is much smaller and oval. It has 2 terminals. the fan motor has 3 wires,...
Before attempting any of these recommendations, First disconnect all the power sources and check your wiring diagrams on the motor and condensing unit.
On the old capacitor if you look on the top near each of the three terminals. Are they marked, fan - C - herm? If they are that is a dual capacitor and that needs to stay because that is also your compressor capacitor.
The Red wire from the conductor is Run and it's connected to C on the old capacitor.
Follow the Yellow wire and see if it goes to the S or start terminal on the compressor, if it does then that is the Start wire for your compressor and it connects to herm on the capacitor.
For the fan motor a lot of times the wiring connections are printed on the motor label.
Check the label, Purple should be run and connect to C on the old capacitor.
Black should be Common and it connects to the opposite side of the contactor as the Red wire. If the Red wire connects to T1 then the Black wire connects to T2.
The Brown wire shoud be the start wire on the fan motor and it connects to the Fan terminal on the old capacitor.
Now if you want to use the new fan capacitor. Take the Purple wire from the motor and look for any marks (red paint or a dash) on or beside the terminals on the new capacitor. If there is an identifying mark then connect the Purple wire to that terminal, if no marks you can connect it to either terminal. Then you need a jumper wire from C on the old capacitor to the purple side of the new capacitor. Then take the brown wire and connect it to opposite terminal of the new capacitor.
Apr 05, 2010 | Heating & Cooling
Replaced fan relay but now lowing fuses
This might be a ground wire loose somewhere. Or a hot wire exposed to a ground. Electrical problems are the worst part of a car to fix. Try to replace just the wires or the entire harness to the fan relay.
Hope this helps.
Aug 23, 2009 | 1992 Volkswagen Jetta
Goodman CLQ36AR49 Air Conditioner Logo
100 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
