Question about Pool & Spa
Will a Hayward propeller fit on a dynamo motor and how to replace
  • 717 Answers
Impellers do not interchange with other brands. Each impeller will only fit the model of pump it was made for.
Rod @ US Parts Center
Posted on May 09, 2013
How to wire a Lucas dynamo
easy for a old timer like me ,the larger D terminal goes to the regulator and the smaller field terminal is the warning light ,now inside the main wire goes to one of the brushes and the other one goes to the casing ,to test hold casing on the NEG battery terminal and the pos one is connected to large connection and the motor will spin like a electric motor .To reverse polarity for a older + earth you reverse the connection casing to positive and the D and F connections joined together and connected to the NEG and spinm the motor ,positive earth dynamo ,simple isnt it
Nov 16, 2013 | Cars & Trucks
Will a smith 1hp pump fit in place of a hayward 1hp
as long as the frame size matches i.e. 56J in this case then you should have NO issue with changing the motor mfg.
US Parts Center
Aug 18, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
Good morning, I have a hayward agph models h100Id1, Went to turn it on yesterday and it started fine but then started banging and shaking. Cobwebs? I read something about the diverter plate might be...
I'm assuming that you have checked the water circuit and have bleeded it correctly and thoroughly - air bubbles will cause that when they go thru the heat exchanger.
The banging and shaking are caused by the blower from the burner- it's either:
1 - the motor is dislodged from its casing and the blades of the propeller fan are hitting the case walls - the casing will have to be opened and the motor refitted properly;
or
2 - the bearings of the shaft of the motor of the blower are damaged and the shaft oscillates - the entire blower will have to be replaced, here's a new one - number 2http://www.poolpartsonline.com/p-11-hayward-h100id1-h100idp1-above-ground-heater-parts.aspx
or
3 - the propeller is loose on the shaft - the blower will have to be dismantled and the propeller reattached .
Here is an exploded diagram to help you with the dismantling
http://www.poolpartsonline.com/popup.aspx?src=wolthuis.aspx%3fproductid%3d11%26size%3dlarge
May 29, 2011 | Hayward H Series Induced Draft Abg 100,000...
I WANT TO KNOW HOW TO CONNECT MY BYCICLE LIGHT GENERATOR
The generator, or dynamo, fits onto the back fork bar of the bike. The top, which rotates, should be close to the tyre of the back wheel. There's a little lever which you press downwards. When you press it the dynamo moves in against the tyre so that when you're cycling the movement of the wheel causes the top of the dynamo to rotate. To stop it, or turn off your lights, you pull the dynamo back out from the tyre. You need to adjust the dynamo so that the top of the dynamo makes contact when the lever is pressed but doesn't when it's pulled back out.
Normally a dynamo has only one wire which connects to the lights. You need to use lights designed for it. This carries the positive current. The frame of the bike usually acts as the negative. Some dynamos may have 2 wires. In this case the positive connects to the centre of the light and the negative to the outer.
Apr 13, 2011 | Cycling
I installed a complete hayward filter with a new multiport valve. i can see DE in my pool. what would cause this? Thanks for your help.
If these Hayward pool filters are leaking DE back into the pool, there are a couple things that you will want to check. Check for loose bolts on tube nest plates and tighten them if necessary. Make sure that you don't have a worn or loose fitting diaphragm gasket and that there are no rips and holes in it. Replace the gasket if any of these is the problem. Check for openings or tears in one or more Flex-
Tubes and replace them if necessary.
Dec 19, 2010 | Pentair Clean & Clear Filter and Dynamo...
Our dynamo CA04-26 pool pump is making a whining noise. Can we oil it somewhere? What could cause it to make this new high pitched sound?
The bearings are likely failing and they are not open to allow for re-lubrication. You can replace them yourself or take the motor to a local electric motor repair shop to have it done for you. A shop will probably cost about $40 to $50 for parts and labor. You should also replace the seal at the same time. The cost for the seal is under $10 and the labor shouldn't change.
May 29, 2010 | Pentair Dynamo 3/4 Hp Above - Ground Pool...
My hayward pool pump was working fine until yesterday when I blew the circuit it was on. After turning the breaker back on, all my pump does is hum. I took the rear cover off of the pump and was able to...
It is likely a motor failure. You may be able to take it to a local electric motor repair shop but most of those motors are not economical to repair. You can replace the motor and pump seal for far less than the whole pump. If you would like a quote on the parts, try us at www.arrowpools.net
Use the contact button and include your current pump info in the message.
Jul 05, 2009 | Hayward Powerflo Matrix 1 - Hp Above...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
