Question about NEC Oki Mc160N A4 Colour Multifunction Laser Printer Print/Scan
Process error belt
I keep getting : process error belt
Error message
Here is a web site with a number of solutions to try and fix the error you are seeing:
HOW TO Fix process com google process gapps has stopped Error Message...
Jul 10, 2013 | ZEEPAD 7 inch Android 2.2 Tablet
PROCESS ERROR-BELT CLEAR BY COVER
epson cx 16
May 16, 2012 | Epson ACULASER CX16
Konica minolta 1690mf process error belt clear by cover
KONICA MINOLTA 1690MF ERROR:
process error - belt (clear by cover)
SOLUTION: Open and close the scanner unit. Reseat the Image Unit and cycle the power to the machine. If the error persists and the machine is covered by warranty, a printer exchange is recommended.
KONICA MINOLTA SUPPORT PAGE:
https://kb.mykonicaminolta.com/selfservice_bus_anon/microsites/search.do?cmd=displayKC&docType=kc&externalId=TAD-doctad227704html0&sliceId=&docTypeID=DT_TAD_1_1&dialogID=10562139&stateId=1%200%2010556672
Feb 27, 2012 | Konica Minolta magicolor 1690MF All-In-One...
Keep getting "an error occurred while creating
You will obviously get your answer if you contact ArcSoft's support.
You also haven't provided enough information for someone to be able to actually help you.
Mar 18, 2011 | Arcsoft ShowBiz DVD 2 (3265)
"981 Service Switch Error"
981 service switch error refers to BUD(belt up/down) clutch if the error essage is hard. it could be possible that someone could have playes with white CAM below the tranfer belt(behind the waste toner box) if you suspect that the cam was manually rotated, then you are in a big FIX. if not then it could be just a problem with the cam being worn out. in this scenario you cannot remove or reset the transfer belt as you normally do it. there is a special procedure to remove the transfer belt. try the following.
remove the waste toner box., fool the front door of the printer so that you can watch the transfer belt moving up/down. while you have the fron door open,
Turn off the printer, press and hold the go and return buttons on the printer , keep watching the shaft that show the position of the belt, once it moves, be fast enough to turn off the printer. If you were successful in this procedure , you can remove the belt from the printer without any problem. Make sure not to touch the white cam shaft. visually examine the internal mechanism of the shaft, if it is wornout replace it.
IF the white cam was turned manually then you might have to replace the BUD clutch.. which is the most difficult process in this machine....Wish you all the best.
Nov 12, 2010 | Lexmark C912 Led Printer
Elevation has gone too high. foot rollers are hitting front plate
Precor Error E4, Incomplete Initialization Probable Cause Indicates that an incomplete upper PCA to lower PCA initialization occurred. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Run the initialization program. Caution: The treadmill's running belt will accelerate to the treadmill's maximum speed (12mph). DO NOT stand on the treadmill's running belt during the procedure.
  1. Set the on/off switch to the OFF position. Wait a minimum of 10 seconds to allow the internal power supply to discharge.
  2. Remove the safety key from the console and set the on/off switch to the ON position.
  3. Press INCLINE UP and SPEED DOWN keys together. While pressing these keys, replace the safety switch on the console. Continue holding the INCLINE UP and SPEED DOWN keys until the display goes blank. INIT will appear in the time window of the display. The EEPROM is now clear and reset. After a second, 1.25 will appear in the distance/calories window, 15.0 (the maximum incline) will appear in the incline window, and 12.0 (the maximum speed) will flash in the speed/pace window.
  4. Press QUICKSTART to begin the speed calibration process. Power bits will appear in the incline window, the target speed will appear in the time window and the actual speed will appear in the speed/pace window. At the beginning of the process, the target speed will be .5mph. The running belt will start. Once the actual speed reaches .5mph, the target speed will then change to 12mph and the running belt will accelerate until it reaches 12mph, then it will stop.
  5. When the running belt stops, the display will return to the user mode and the initialization process is complete.
Precor Error Code E4
Apr 30, 2009 | Precor EFX 546i Elliptical Version 4
Pionner laser disc reader error U1
The drive belt is probably failing. This is a common problem with the CLD-504, actually. It will need to be replaced.
Mar 22, 2009 | Televison & Video
356 BELT ERROR
Please Google your problem.
The method in the following link helped us to solve our same problem.
<OKI C9300 Code 356:Belt Unit Life>
http://www.fixyourownprinter.com/forums/printer/53306
There is a shortcoming, however, in this method:
The reset process resets the usage stats of toners, drums, fuse and belt. After reset it displays on Print Supervision as if all the a.m. parts have been replaced with new ones.
Aug 16, 2008 | OKI C5200n Laser Printer
Error code sc481
Hello thomasg.I will answer you question gladly and precisely but I do this at my own peril. I get rated on my quality by how well I "fix" my customer's problem (your problem).The details I am about to provide to you probably wont make alot of sense to anyone that is not a field engineer that is formally trained on your copier.So I risk getting a poor rating from you since I will not have "fixed" your problem and you might choose to grade me as being not very helpful.But at least I might save you some money since you will know what's wrong BEFORE you place a service call. (which you will need considering what the error code means) So at least you have a chance of avoid being overcharged. Your copier has what is called a transfer belt that turns when making copies. The copier keeps track of the turning of this belt as it is crucial to copy process. SC 481 means that the copier cannot determine the transfer belt position. Causes: belt is damaged or main motor has stopped which drives the belt.99.9% of the time it is the flimsy belt.I have never seen this problem as the result of the main motor. I am reading this directly from the service manual. Please be kind when you rate my help. :-) Let me know if I can help you further.
Jan 05, 2008 | Gestetner DSc224 Copier
NEC Oki Mc160N A4 Colour Multifunction Laser Printer Print/Scan Logo
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
