Question about Canon Rebel Cameras
Linkage problem, wont focus
    Novelist:
  • Canon Expert
  • 357 Answers
Make sure lens is set on AF and not M. Clean body and lens contacts with a Q-tip dipped in alcohol. Try multiple lenses to make sure it is not a problem with just one lens. Put the lens on M and turn the front and make sure it turns freely and is not stuck by impact/spillage etc. Push down on the release button and make sure you have two distinct 'pops' (release switch may be broken). Gently lift up mirror and make sure that the AF sub mirror also comes up properly. Impact can break the little plastic guide pin for the sub mirror so that it is not in the right position and the AF will not work. Also make sure that the spring that makes the sub mirror come up is in position (they come off). Can be on either the right or left side of the mirror depending upon the model.
These are the steps I would take if you brought your camera into the shop I work at.
Posted on May 05, 2013
2000 ford focus, manual, the stick stick flops around not engaged
There are three posibilities for this worn linkage on the gearbox the linkage under gear lever or a broken mounting on the bracket where the lever comes up through the floor as long as you can get all gears it will be exturnal linkage fault.
Mar 04, 2014 | 2000 Ford Focus
My 2000 ford focus wont shift. Its not the transmission because I can shift it manually a the transmission. Could this be the linkage?
I think your shifter cable broke go back to the linkage at the trans and find the bracket the cable attaches to and try to pull the cable through if you can it broke that's why I think the shifter lever is now all over the place also go to the bottom off the steering column it may have just come loose at the bracket inside the car good luck Adam you'll find it Stephen
Sep 05, 2017 | 2000 Ford Focus
2008 ford focus manual trans no gears told shifter housing needs replaced
Same thing just happened to my 2008. I was driving to work and suddenly, no gears available (1-5 or reverse). Had it towed. Mechanic says linkage is connected and working. Has to drop the transmission. Minimum cost is $1,200.00!!!!!
Jul 31, 2012 | 2000 Ford Focus
The windshield wipers to my Ford focus stopped working today. They worked for a little while & then stopped in the up position. You can hear the motor working but they don't move. You can move them...
Your wiper linkage has come off the wiper motor. To reconnect the linkage, first remove the wiped arms, the remove the wiped cowl. The wiper cowl bolts are located under the hood and screws through the spaces in the cowl. Reconnect linkage, reinstall cowl, reinstall wiped arms.
Jul 05, 2011 | 2006 Ford Focus
I have a 2007 ford focus and the back door on the passanger side wont lock manually or electricly.i try to push the lock in but its like its stuck, and when i try to use the electric switch its like its...
first try some WD40 sprayed into the inner door this may loosen things up, ask you said the door locks sometimes worked.
if not sounds like the linkage in the door has either bent, come off, or water got in and rusted things up, in any case you will have to take the inner door panel off using a tool you can pick up at the auto parts store.
In the door ( beside the window mechanism ) you will find heave metal rods/linkage for opening /closeing the door latch and lock.
you will have to see that all are connected and not just hanging.
you will also find a connected to this linkage a small round or rectanular item with a couple of wires this is your electric door lock. you will have to manually check to see all are moving freely and if not fix it. or just take the car to a mechanic or body shop.
good luck
Mar 25, 2011 | 2007 Ford Focus (3 Door) Hatchback
The. Manual trans in my 2000 ford focus wont ahift to first third or fifth gear but I have second and fourth and reverse this happened immediately after I changed the battery and got in it to drive the...
could be the selectors in gearbox
but i would check all gearlever linkage first that could be your problem . if not problem has to be selectors in lid of gear box
Feb 04, 2011 | 2000 Ford Focus
Ford focus gearstick linkage
ford focus gearchange linkage what about it ??
Jan 13, 2011 | 2000 Ford Focus
Push door and it justs wont click shut moved swinging arm in door with screwdriver but wont lock
if it wont lock that means that its broken replace the whole latch. its easy just take the door panel off then take the linkages off the latch take out the two or three screws holding the latch on and pull it out. than reverce those steps when installing the new latch.
Jan 04, 2010 | 2006 Ford Focus
06 ford focus 5spd. no 1st, 3rd, or 5th gear.
It sound like the gear linkage isn,t set up right, you wouldn,t always be able to engage a gear unless you rocked the car.
Aug 25, 2009 | 2006 Ford Focus
99 focus wipers stoping
you have the linkage adjusted wrong turn them on then off,remove the arms from the pivots and reset to correct location.
Aug 05, 2009 | 2000 Ford Focus
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
