Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet fabric softner problem
When I first started using the machine, I would fill the fabric softner and at the end of the full cycle the fabric softner and detergent spots would be empty. Now at the end of a full cycle when I try to do the next load of laundry the fabric softner spot is full of water. Why?
  • 2 more comments
  • michelle palka Aug 07, 2007
    Yes, I think it is just water. The problem is, I have to take the dispenser out of the machine to empty the water. I don't have any room to put the fabric softner in. I shouldn't have to do this with a brand new, expensive washing machine. Any suggestions.
    Thanks.
  • teresa1000 Nov 20, 2007
    I'm having the same problem. Water is filling up the fabric softner section after the load is done so for the next load, I can't put any fabric softner in because of all the water, it start spilling out once I put the softner in. It's backed up I think from putting too much Tide in the wash cycle, how do I unplug it?
  • Anonymous Mar 19, 2014
    rinse cyle does not take down fabric softner and leaves water in compartments
  • Anonymous Mar 27, 2014
    compartment will not empty
According to the whirlpool FAQ's page, that is normal. They stated that at the end of the cycle, fresh water is used to clean the detergent holders. Not sure that I believe them though.
Posted on Dec 28, 2007
    Scholar:
  • 161 Answers
It obviously is backed up or splashed in from the wash. And if it is just water why worry about it.
Posted on Aug 07, 2007
If I put soap in fabric softner spot can I just add water and let it drain out?
You could remove it and clean it out. Or you can add water a few times and put it in a spin. It will only release in the spin cycle.
Dec 31, 2012 | Maytag Performa PAV3200
I have a front loading Kenmore washer and when i put liquid detergent and fabric softener, the liquid flows into the machine - should the detergent and fabric softerner remain in their compartements until...
Yes the detergent and softener will stay in the dispenser drawer until the correct time for them to be dispensed. The detergent is dispensed during the main wash cycle and the softener will not dispense until the rinse cycle
Jul 26, 2011 | Kenmore Washing Machines
At beginning of wash cycle when washer is filling also fills the liquid fabric softener and goes in with the laundry detergent then there is no fabric softener for the rinse cycle.
Hello, Thank You for using FixYa. I will be helping you today.Sounds like the softner valve is stuck open. You would have to open the top and start the cycle and see if the softner valve is getting power to it. If its not and water is comming through it is stuck open and needs to be replaced. If it is getting 120volts to it the control board would have to be replaced.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Maytag Neptune MAH5500B Front Load Washer
Despite cleaning out the drawer, the fabric softner is still there at the end of the wash. Have cleaned the drawer several times, but to no avail. Any suggestions?
Remove drawer/ look inside opening of washer ( at the top of opening inside) there is small little holes for the water to come through to fill the fabric softner spot and also bleach spot and detrgent spot. Holes may be pluged use a old tooth bush or some item to clean holes..Hope that helps thanks for voting.
Mar 18, 2011 | Washing Machines
Clothes coming out spotted
Hi Residue builds up inside of washing machines for all sorts of reasons. Many detergents and fabric softeners can leave filmy layers behind. Hard water can cause spotting on both plastic and metal thus ending up with spots on your washing, how to resolve this follow the instructions, 1, use vinegar a bottle and place your machine on the hottest wash cycle and let it run through a full cycle, when finished use a paper towel with vinegar to clean the inside, set machine on a rinse cycle, this may need to be repeated but will solve it, also use gels and liquids instead of powders and descale etc.
Jul 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
"fabric softner staining the clothes"
make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
The fabric softner drains out as soon as I pour it in
the fabric softner drains or flushs down in the rinse cycles,,,now if you fill past the line or open in dispencer it will sphion down by it self,,in short your overfilling dispencers,,onthejob
Jan 07, 2009 | Kenmore Elite 45986 Front Load Washer
Mile 864 front loader - clothes come out with new grease marks
Problem will be the use of fabric softner or too much detergent. The stain you are seeing is generally to animal fat that is present in fabric softner, Best solution is to cut back on the amount of softner being used, same with powder.
Sep 18, 2006 | Miele W864 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
466 people viewed this question
Dan Webster
Dan Webster
Sal De
