Question about GE Refrigerators
How can I find a total water line diagram for my GE TPS24PPBA
I see several water lines running along the back of the refrigerator. We just bought it - used. Down near the compressor there are two separate water lines that are either broken or not connected to anything. One comes down from the freezer compartment and doesn't connect to anything. The other comes up from the bottom. I would assume it is one broken line, except for the fact that they are slightly different sizes. Can anyone assist?
  • 6 Answers
SOURCE: water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
Posted on Aug 07, 2008
  • 112 Answers
SOURCE: Ice forming bottom of freezer leaking out the door
It is acutually a collector pan for the drain hose. When the refrigerator runs a defrost cycle (about every couple days), that pan collects the water from the ice that is melted and drains it through a hose inside the unit, to a pan under the unit. You will have to pull the back panel off the back of the freezer and melt it with either hot water or a hot blowdryer. Do it until you see the water draining freely into the bottom pan.
Posted on Oct 18, 2008
tborn6
  • 700 Answers
SOURCE: GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Posted on Apr 03, 2009
  • 25 Answers
SOURCE: Water line connectors/tubing? GE Monogram Refrigerator
go to your local appliance parts dealer , they should be able to get the parts you need
Posted on May 21, 2009
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
I have a GE refrigerator water comes out but it's not making ice. Bought a new filter.model number GAL25JFXN LB
there are several possible causes for your symptom: failed water valve, failed dispenser microswitch, or the line has frozen solid where it runs close to the freezer interior approximately 4 inches from where it dispenses. push a long plastic zip-tie up the water line above the water dispenser paddle. if it stops against an ice blockage you will need the water line heater kit from GE.part#WR49X10173. If there is no blockage, remove the rear service panel and follow your supply line to the water valve...have a helper push the dispenser paddle while you feel the valve body- if there is no hum or vibration you may need a new valve#WR57X10032. things get more complicated if neither of those tips help, time to call a Tech!
Apr 08, 2016 | GE Refrigerators
Why would ge refigerater ice maker work but want dispense water
The inlet line is either kinked or the line is frozen up which would require a total defrost e.g turn it off for a day. the other reason could be the water valve itself.
Jul 27, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
How to install water tank on GE side x side. I have the new tank to install. Need diagram of connections.
Hello.
I do not believe any diagrams exist on the web for such diagrams. Basically the way it goes is as such
The tank has a long line and a shorter line
the shorter line connects to the water valve on the back of the refrig.
the longer line runs underneith and connects to the connector behind the freezer door lower hinge cover or that area by the lower freezer door hinge. depending on age of refrig. that fitting the tubes connect to unscrew or on newer models the collar on the inner part of the connecter is push in while pulling out tube to remove old tube
Aug 17, 2011 | GE Refrigerators
Drinking water from refrigerator stopped dispensing immediately
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , pt # WR49X10173 which comes with instructions , to keep this from happening again .
May 29, 2010 | GE GSS20IEP Side by Side Refrigerator
Our water dispenser on our GE side by side refrigerator quit working. I changed the filter. No results.
At the bottom of the freezer door ( remove the kick plate , 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the water line in door is frozen , GE has a heater kit , pt # WR49X10173 , for this particular problem . It comes , with installation instructions .
Jan 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Our water dispenser stopped working we can hear it click but water will not come out?
At the bottom of the freezer door ( remove the kick plate by removing 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If frozen , GE has a water dispensor heater , pt # WR49X10173 , to keep this from happening again . Also , by turning the dispensor light on , for several hours , so it will heat the spout , has worked for several people .
Dec 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water stopped coming out of the front
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
There is also a dispensor heater , you may want to install , pt # WR49X10173 . This should keep the water line from freezing again , if it turns out to be that problem .
Nov 07, 2009 | GE GSL25JFR Brushed Steel Side by Side...
Artica black water supply line cracked/broken
Go to sears.com, click on "Parts Direct", screen will pop up, enter model number, press enter, wait a few seconds, you will see diagram of your unit, locate part & part number, order from sears or any parts house that sell appliance parts.
Sep 23, 2009 | GE GSH25JFR Side by Side Refrigerator
Water freezes in door dispenser
there is a length of line that runs thru the refrigerator, If it drops below frezing where this is located the line will freeze causing a blockage.
Mar 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser won't work
see my posts in my solved solutions on water line freezing. I can email you a bulletin for a heater kit.
Dec 06, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
