Question about DCS PHFS Phoenix III Outdoor Patio Heater
Pilot goes off when knob advanced to "on"
Pilot lights fine but as soon as I release pressure on the knob (undepress) and turn it to on, to start the burner, the pilot goes off no matter how long I have let it warm up
2 Suggested Answers
t1m130
  • 86 Answers
SOURCE: pilot flame lights but goes out when knob is released
i would try cleaning or replacing the thermocoulpe if you did replace it make sure the flame is touching the thermocouple
Posted on Jul 30, 2009
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
40,000 btu Charmglo patio heater, brand new, pilot light stays lit as long as you keep the knob depressed. As soon as you release the knob, and turn it to the high position, the pilot goes out! Please...
There is a thermocouple that detects that there is a pilot flame so that main gas won't come on unless there is a pilot. That thermocouple is faulty. These are available from a plumbing supply house. The thermocouple will be attached right in the flame from the pilot and connects back into the gas valve.
Dec 24, 2010 | Garden
I have a Rheem gas furnace, model # RGAA-100C and need help lighting the pilot. The instructions on the metal plate tell me to set the valve to off, then to pilot, push the valve down until lit, and then...
Hi, follow what I say and it is very easy. The knob that says off, on, and pilot, is where you need to start. You don't want to turn it off now, as its been off for awhile now. Turn the knob slowly pushing down on it until you fill it go down. The knob will go down believe me. When this happens, keep holding it down as this is what starts the gas to the pilot which is back under the burner, under it. Just take a flash light and you can follow the aluminum tubing back and where it stops is where you light it with something long with a match in it or a small rolled up paper. Keep the knob down the whole time you are lighting it. When it lights, keep the knob pushed down for about another minute. Then slowly release the knob and the pilot should stay on. Once you have it on, turn the knob to on, not off. If you turn it the wrong way, it will go off and you will need to start over again. Once it stays on by itself, turn your thermostat up for heat and the burner will light and come on. Just remember that the pilot where you light it is where the tubing goes back under it, as the pilot gas goes through it. You will need a light. Look at the knob with a good light and it will tell you which way to turn it. In the pilot position, the knob will press down to let the pilot gas in, and you can reach back and light it. Then turn knob on. Pilot should stay light. Turn on thermostat and it will fire up. Let me know how it goes. You may have to try a couple of times.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Oct 05, 2010 | Heating & Cooling
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
Pilot wont light
If the pilot light goes out when you release the primer,then the thermocouple is bad.You can try to adjust the thermocouple,if it can be.It needs to be in the pilot flame.If the thermocouple is not in the flame,it will not stay lit.If you can not get the pilot to light at all,with the primer pushed down,then replace the regulator.To light the pilot light,you need to turn the dial to pilot.Then press the primer button down and hold it.The primer is either built into the turn knob,or it is a res button.Hold the primer down,and light the pilot,continue holding the primer down for at least 40 seconds.Then release the primer slowly,and if the pilot light starts to get weak,and try to go out,then push back down,and hold 30 seconds more.After the pilot stays lit,turn the knob to furnace or low,or whatever the directions say.
Oct 19, 2009 | Heating & Cooling
Light pilot light
Turn control knob to "Pilot" and press it down. While holding knob down, light pilot with a match. After pilot lights continue to hold knob down for about one minute. When you release the knob the pilot should remain on. If it goes out then the thermocouple needs to be replaced.
Jul 18, 2009 | Pool & Spa
Pilot light does light , but as soon as you release the gas knob it goes out
Hi there. You must continue to hold the knob in for at least 30 seconds before releasing. If the pilot still goes out, the "thermocouple" is bad. It's the little tube in the pilot flame. To replace, remove the main burner assembly/pilot. You can get a thermocouple at any hardware store. Ask questions while you are there.
Thanks
Paul
Jul 12, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Burner will not ignite as pilot light goes out when knob is released
Are you holding the knob for 30 or more seconds,If so,Clean or replace the thermocouple/Flame sensor.
May 29, 2009 | Endless Summer (GA200209) Stainless Steel...
ProCom blueflame heater pilot light difficult to light
You pilot ignator is plugged.I take a small wire and run it in the hole every year and I also Blow the heaters out real well with air.THis has always worked far me.I need a phone number or email address to Pro Com because i'm having problems with a new one i just bought and I can't find the papework.Could you pleas eif you have this info email it to me
Good Luck
Jay
jaycalk@yahoo.com
Jan 07, 2009 | Procom (177653) Utility Heater
Vulcan Deep Fryer Need to Light Pilot
you have to hold the knob in after pilot is lit for at least one minute
Jul 09, 2008 | Vulcan EF3 Deep Fryer
Heating & Cooling Logo
43 people viewed this question
Top DCS Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a DCS Heating and Cooling Expert? Answer questions, earn points and help others
