Question about Samsung P2770FH 27 LCD Monitor 1 ms 1609 Adjustable Display Angle 16 Server
Back Cover Removal
I don't see a way to remove the back cover of the Samsung P2770FH monitor. Can someone describe the method for removing the back cover.
Sahill
  • 23 Answers
SOURCE: Removing the back cover of a Samsung SyncMaster 753s
there is 2 lock on front side first remove back side lock or scrow then insert small pin pull up back cover your monitor will get open
ashok
Posted on Jan 21, 2008
tia_baby_87
  • 14 Answers
SOURCE: battery cover
I usually cushion the phone between my hands then push against the back in the opposite direction to my other hand works everytime.
Posted on Jan 10, 2009
  • 555 Answers
SOURCE: How to remove back cover of monitor
Here are the instructions to open the monitor:
http://josepino.com/?open-samsung-back-cover
"Don't kill yourself just to save some bucks"
Good luck.
Posted on Sep 04, 2009
  • 11 Answers
SOURCE: lCD TV
There is more than two screws holding the back cover on. I think it is more like 4 to 6. After you have removed all the screws you will nee a flat screw driver to help pry the two halves apart. Be careful the front of the cover has little snaps that help hold the two together.
Posted on Mar 09, 2010
  • 128 Answers
SOURCE: samsung galaxy fit how to remove the back cover
look at the bottom of the phone in the center u see a small space gentle use finger nail and lift the cover...or locate your earphone jack and go to the corner and gentle lift with your finger nail
Posted on Jun 11, 2011
When I was attaching the screen to a VESA arm, one of the nuts inside the unit came off and is floating in the unit. I need to get the back cover off to get the nut and re-attach it. How do I get the...
As it appears it seems that the back of the unit is held together by clamps. I wouldn't advise you to go ahead with the dis-assembly because you risk breaking the clamps. But if you must do it proceed with caution. Start prying open from the bottom screws toward the top of the unit. Use a plastic wedge to help the prying. It really comes down to finesse and experience. If you don't feel confident doing it don't do it as you might break it irreparable. The mount should be usable even mounted in 3 points.On the other hand the loose nut could cause some damage short circuiting the board. \
Good luckVlad
Feb 27, 2012 | Samsung B2230 LCD Monitor
Nokia c7 sim card removal i don't now how ??
Insert the SIM card and battery
Important: Do not use a micro-SIM or a micro-SIM with an adapter in this device. This device does not support use of micro-SIM cards, and use of incompatible SIM cards may damage the card or the device, and may corrupt data stored on the card.
Follow the instructions carefully, to avoid damaging the back cover.
Safe removal. Always switch the device off and disconnect the charger before removing the battery.
1 Unlock the back cover release latch, and lift the back cover
2 If the battery is inserted, lift the battery out.
3 Insert a SIM card. Use the diagram printed on the device to correctly align the card.
4 Line up the contacts of the battery and the battery compartment, and insert the battery.
5 To replace the back cover, direct the top locking catches toward their slots, and press down until the cover locks into place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Nokia C7 (8 GB) Smartphone
Can someone tell me how to open the case of my Samsung 932BW? There are no screws on the back or front. I need to open it up to take a look at the capacitors. Thanks.
1.follow this first
2.Turn the monitor so the front section is facing
upwards. after completely pulling this front cover,
Turn the monitor so the back of it is facing
upwards. Lift up and remove the back cover.
Sep 27, 2010 | Samsung 932BW Monitor
I have samsung syncMaster 551s CRT monitor. i want to open its back cover. i found only two scrow and i have remove them. but now problem is i cant remove it. plz help me.
You have to find 2 holes at the top of the plastic cover (at the front edge of the back cover) of this monitor and place a flat blade screwdriver in them and gently press to unlock the cover.
Sep 22, 2010 | SAMTRON 55V 15" CRT Monitor
Stem on lcd monitor can't be removed
Usually the stem has a plastic cover that hides the securing screws from view. You must pry up the cover to reveal the screws securing the stem to the monitor. This is most easily done with a Plastic pry bar or plastic putty knife. Hope this helps you with your problem.
Apr 27, 2009 | Computers & Internet
Removing back cover of samsung monitor 15'' crt 55v
I need some solutions to remove back cover for the CRT samsung monitor
Jan 17, 2009 | SAMTRON 55V 15" CRT Monitor
Removal of front cover
To remove the front cover you need to start by putting the monitor down flat on its face on something that wont scratch the screen.
Next, remove the screws holding the base to the back of the monitor. (You might need to remove a plastic cover to get to the screws).
Once you have done this check for a screw under where the base was screwed on. Remove this screw.
Now check the back of the monitor for one screw in each corner. Not all models have these 4 screws,if they are there, remove them.
Now the front and back of the monitor are held together with plastic clips. You will need to gently pry the front and back apart.
Its easiest starting at the bottom middle and working around.
Once you have separated the front and back, the inner circuitry is exposed. The control panel for the unit can be removed by unscrewing 3 screws that hold it in.
Aug 26, 2008 | Philips 190B6CB/27 19" LCD
ashok
Jan 20, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung P2770FH 27 LCD Monitor 1 ms 1609 Adjustable Display Angle 16 Server Logo
27 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
