Wharfedale lcd1710af insructions
Electrical lead faulty - need replacement
Western digital lap top drive does not seem to spin at start up 160 gb
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
hope this helps you
Nov 28, 2011 | Western Digital Scorpio WD1600BEVS 160 GB...
Windows 7 can't recognize harddisk anymore
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this helps you
Sep 15, 2011 | Toshiba (MK3259GSX) 320 GB SATA II Hard...
One of the bootable device has not been found.
your operating system is looking for somewhere to boot from
make sure there no disks in your drives
hope this helps you
Sep 10, 2011 | Computers & Internet
Control wont work completly dead
also check the Cmos battery and computer ram make sure they are securely seated with no dust built up or in the sockets
hope this helps you
Aug 13, 2011 | Computers & Internet
ASUS DSBF-D Dead, no startup, fans dead, just 1 green led on MB.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
hope this helps
Jul 18, 2011 | ASUS DSBF-D/SAS Motherboard
My monitor turns itself off every 2 minutes
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem hope this helps
Jun 17, 2011 | Computers & Internet
Power supply is ok but no pwer on
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this helps
Jun 03, 2011 | Foxconn A6VMX Socket AM2+ AMD Motherboard...
Wont power up
May 26, 2011 | Computers & Internet
N computing L230 restart automatically
May 25, 2011 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
