Question about Timex T600 Clock Radio
Timex T600 I bought this radio used. When I set the alarm to go off in radio mode,it keeps going back to 85.9 and I can't hear radio go on to wake me up.
  • Anonymous Feb 09, 2008
    Yes, I've had this one for years and I can't tell you how many times I overslept because during the night the power went out and the radio alarm retuned itself to nothing.
Can anyone tell me where to obtain a owner's manual? I bought this clock used.
Posted on Jul 11, 2008
Best site I have used , Just what i wanted. THANKS
Posted on Jul 10, 2008
THis one is easy because I experienced the same problem until I found out what was going on. The radio portion of the alarm works from the preset stations in the memory. You can select preset one-what-ever. If the preset is not programmed to a station, it will revert back to the lowest FM channel. All you have to do is program your presets and select which preset you want the alarm to function from.
Posted on Jun 09, 2008
    Scholar:
  • 161 Answers
Just use the alarm part of the clock.
Posted on Aug 07, 2007
How do i set the alarm on a t231
Setting The Alarm Time of T231
This Timex clock radio has dual alarms that can be set and used independently. The initial default alarm settings are 6:00 AM for Alarm 1 and 7:00 AM for Alarm 2. The procedure for
setting both alarms is the same.
NOTE: The alarm times can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows
'OFF' and then reverts to the time.
1. Press and hold the ALM 1 button until the Alarm 1 time and the Alarm 1 Buzzer indicator begin flashing in the display, then release the button.
2. Press the HOUR / REV button to advance the display to the desired wake-up hour. Observe the PM indicator to confirm that you have set the wake-up hour correctly. If the PM indicator is
'On' the wake-up hour on the display is PM. If the PM indicator does not appear the wake-up hour on the display is AM.
3. Press the MIN / FF button to advance the display to the correct wake-up minute, and then release the button.
4. Press the ALM 1 button once more to confirm the wake-up time setting or after 10 seconds the display will stop flashing and the new wake-up time will be entered automatically. The
display will return to the correct time of day but the Buzzer indicator will remain 'on' in the display indicating that the Alarm 1 is now set to wake you to the buzzer.
5. To change the alarm mode from buzzer to radio, or to cancel the alarm, press the ALM 1 button again. Press the ALM 1 button once more to select the Radio alarm. Press the ALM 1 button once more to cancel the alarm function. The alarm indicators disappear and the display returns to the correct time.
6. Follow the same procedure to set the Alarm 2 wake-up time.
Sep 29, 2014 | Timex Audio Players & Recorders
I have a Timex Wacky Wake-up Alarm clock and can't
When you are setting the alarm on the wacky wake-up timex alarm, if you keep pressing FWD, you will see a small PM in the bottom right hand corner. When the PM sign is gone, you will now that it is set to AM.
Mar 09, 2012 | Timex Watches
I have the emerson smartset clock radio. model cks1702. i need the mannuel so i can set it to go off through the week
There are several SmartSet clock Radios by Emerson. Which model do you have?
It's possible that you have alarm 1 and alarm 2 both set for weekends (if a two-alarm version). For the SmartSet radio, CKD5811, that I am used to, you can change the alarm mode between Everyday, Weekdays and Weekends. Press and hold the Alarm 1 (or Alarm 2) button then press the Alarm Mode button to toggle between the modes. Then release both buttons. If you press the Alarm 1 button, you will see the current alarm mode indicated by the indicators by the day that are lit. The Alarm Mode button is between the On/Off button and the Alarm 1 and 2 buttons on the CKD5811. Make sure that you have the Wake to Radio, Wake to Buzzer or Wake to CD slide set for the alarm in question. For Wake to Radio, set your station. For Wake to CD, make sure that the CD in the unit is one that actually plays in the unit (scratches, etc). Also check the volume (although that seems like less of a concern since it does wake you on weekends).
The manual for the CKD5811 is here:
http://www.emersonradio.com/resources/owner_manuals/manual_1312917117.pdf . Additional manuals are here: http://www.emersonradio.com/owner_manuals.php . Scroll down in the drop down menu for the SmartSet manuals (clock radios all start CKD). The manuals are in alphabetical order.
I hope this helps.
Oct 29, 2011 | Emerson Smartset Clock Radio
How do i set my alarm and when do i know it is on or off....keeps coming on and i dont know how to shut off the alarm...thank you
This clock radio features a dual alarm system, with two separate alarms that can be operated independently. The alarms can be set to wake two people at different times, or to have a main alarm and a backup. One alarm features your choice of radio stations as an alarm wake sound, while the second features a buzzer wake sound. You can set the radio alarm, the buzzer alarm, or both alarms.
Setting Radio Alarm
1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the "alarm Set Button again. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold a button for a few seconds to advance the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator. 3. After setting the radio alarm time, you will need to select the station to wake up to. First, press the "AM/FM" Button to select a radio frequency. Next, select a station using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level. 4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date is set. 5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press the "Alarm Set" Button twice so that the display shows the standard, non-flashing display.
Setting Buzzer Alarm
1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm Indicator will appear. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as described above. 3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer. 4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set" Button once so that the display shows the standard, non- flashing display.
Activating the Alarms
1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 2. To activate the buzzer alarm, press the "Buzzer Alarm" Button so that the Buzzer Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its 7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display. 4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm sounds. The alarm will shut off for approximately nine minutes before sounding again. The feature can be repeated several times during the one-hour snooze cycle. 5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an Alarm Indicator appears on the display, the alarm will sound at the set time, according to the 7-5-2 settings.
Mar 23, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
How do you set your alarm on this
Here's a link to the instructions manual for your clock.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jan 18, 2011 | Timex T600 Clock Radio
How do we set the alarm? on a Timex T600 clock radio
Here's the manual
http://www.timexaudio.com/pdf/T600IB58846_99.pdf
Good Luck and please rate 4 thumbs up for the free answer
Aug 23, 2010 | Timex T600 Clock Radio
Wacky wake up alarm clock instructions
Hold down the "time set" button until the time on the clock flashes. Then use rev or fwd to set the time. Press the "time set" button again once you have the correct time. You can do the same to set the alarm by holding down the "alarm set" button.
Jan 03, 2009 | Watches
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator
will appear on the display, showing that the radio alarm has been set.
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #1: Ocean Surf
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
Nov 18, 2008 | Timex (T307S) Clock Radio
Setting the alarm alternatives
No solutions yet - just bought the last display model off the shelf at Target with no manual (Timex T617S). I'd like to find a hard copy or online manual, or just some help from a kind owner of this clock radio.
Feb 27, 2008 | Timex Audio Players & Recorders
Manual for timex 609t alarm clock
you should be able to just push the Time button (top one third from the right) and when it starts to blink, just change it like you change the alarm.
Oct 17, 2007 | Audio Players & Recorders
Timex T600 Clock Radio Logo
604 people viewed this question
Top Timex Audio Players & Recorders Experts
Gyula Lacz
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
