Question about Dryers
7067KCB-62 (4.5 5)
This is the receiver number, for my ceiling fan I beleive I need to replace it plus the hand held remote. Can you help?
Crossedwires
  • 44 Answers
SOURCE: Bad Receiver for remote UC7051R
I don't know if this will help you or not. but this is the site for most off brand equipment handled by target and wal-mart stores. Aloha is a brand handled by target and home depot (I think) anyway here it is, hope it helps...
http://www.alcosupport.com/
Posted on Feb 09, 2008
ceiling-fans
  • 20 Answers
SOURCE: Ceiling fan remote not working
It is certainly possible that the remote went bad -- after all, it is an electronic device, and is was "made in China". With that said, there are other possibilities:
* The receiver, which is what receives the signals sent by the remote control, could have died. In most remote-controlled fans, the receiver is located in the ceiling canopy (the decorative part up by the ceiling, which hides the wires). In other fans, it's located in the switch housing (the part of the fan to which the light kit attaches). Solution: try everything else on this list; if nothing works, replace the receiver. Universal replacements for most models are available at Home Depot and Lowes.
* A wire on that receiver could have come loose. Solution: check all wires for secureness.
* A wire in your wall or ceiling -- the wire which provides power to the fan -- could have come loose or been chewed through by a rodent. Solution: use a circuit tester to check whether there's power at the connections at the top of the fan, in the ceiling, where the fan connects to the building's wiring.
* A circuit breaker could have tripped or a fuse could have blown. Solution: check your circuit breaker or fuse panel.
* The DIP switches inside the remote control -- which set the frequency on which the control transmits -- could have been knocked out of position accidentally or by a child playing with it. Solution: check the code on the DIP switches on the receiver in the fan -- then, make sure the remote control has its DIP switches set the exact same way.
If none of the above work, then yes -- the problem is with the receiver or the transmitter (remote). The two are typically sold as a pair, and universal replacements are available at Home Depot and Lowe's.
Hope that helps! Feel free to ask for clarification if you need it!
Posted on Jun 17, 2008
SOURCE: Minka Aire remote controlled ceiling fan
I have a newer Minka w/ wall controller. The books says to make sure both the wall control and the receiver(up in the fan) are both programmed the same. My receiver has no little switches but has a sticker stating that you need to hold the 'fan off' button down for 3 seconds after turning on the power so the receiver can memorize the program in the wall switch. You have 60 sec to do this after power is turned on. Good luck !
Posted on Feb 25, 2009
SOURCE: The Hampton Bay Altura Ceiling fan functions only with remote.
I contacted the manufacturer (kingofffans.com) after my Altura fan would run on high speed only and the remote would not control any thing. They said their was a manufacturing defect with a capacitor that affected many of the Altura fans. We are now on a waiting list for a new capacitor and housing, because they did not have enough replacement parts.
Posted on May 27, 2009
SOURCE: Hampton bay ceiling fan with built-in remote receiver
In case someone else stumbles upon this:
I replaced the remote receiver on one of these fans. jb is right just the top housing that touches the ceiling needs to be removed. Twist it counter clockwise and pull down. You'll see all the wires and the remote receiver. It might not seem like much room to work with, but you can remove the wires and slide the receiver out sideways to replace it or if you can't see the dip switches. Too bad Home Depot is too cheap to even provide instructions when they send you the replacement remove receiver.
Posted on Jan 24, 2010
How do I program a MinkaAire R211 remote?
How do I program a MinkaAire R211 remote? - Fixya
www.fixya.com/support/t26033435-program_minkaaire_r211_remote
2 hours ago - I have set the wall mount, hand held R211 remote and the fan receiver to the same frequency. 1 & 2 ON and 3 & 4 OFF. But the remote still wont ...
[PDF]Universal Hand Held Remote System - Minka Group
minkagroup.com/sites/default/files/product.../RC212-English.pdf
NOTE: The RC212 Universal Hand Held Remote Control System is equipped with a learning frequency function which has 256 code combinations to prevent ...Missing: r211
Minka Aire Remote Control RCS212 and Wall ... - YouTube
? 0:56
https://www.youtube.com/watch?v=359xzOXynxI
Jun 14, 2013 - Uploaded by Del Mar Fans & Lighting
Del Mar Fans & Lighting's Minka Aire specialist provides tips for using these innovative ceiling fan controls ...
Jan 01, 2016 | Dryers
How to reverse kichler ceiling fan, UC7206T
Stock Kichler ceiling fan c. 2006, works with replacement remote control 337001WH hand-held unit from Amazon 2013. Started running backwards when two remotes were activated at the same time by accident. Random button pushing on two remotes simultaneously got it to go back to forward. (Apparently original remote hand-held transmitter had forward/reverse setting, but the substitute 337001WH transmitter doesn't. When two transmitters run at the same time, the fwd/rev code may be decoded in the collisions at the receiver. Thank goodness!)
Jun 13, 2012 | Kichler Lighting 300105CTO Ceiling Fan
The remote on my Hunter ceiling fan (Model: 27185 - 060) does not activate the ceiling fan. I can turn the light on manually, but not the ceiling fan. I cannot see the antenna on the ceiling fan.
The first thing you need to do, is change the battery(s) in the hand held remote, as well as the battery(s) in the receiver inside the fan's cowling. Weak batteries will limit a remotes operation.
And, FYI - there is no antenna on the ceiling fan.
I hope this helps you. Thanks for choosing FixYa.
Jul 25, 2011 | Heating & Cooling
Ceiling fan is all wired up and on ceiling but light doesn't come on or fan doesn't spin. I have checked connections and tested for power. Is there a switch or anything on receiver that needs to be...
Jerry, from what you said, I assume you have a remote controlled ceiling fan. If that's the case, check the batteries in the hand held and the receiver, to make sure they are charged. Also, make sure they are installed properly. The Owner's Manual should have a reference to setting or resetting the codes for the remote control (Hand Held & the Receiver). Check those to make sure they are matching. And don't forget, the wall switch must remain ON for the fan to work, even with the remote control. The remote simply overrides the wall switch, when in operation. You may have to use the pull chain to start the fan motor the first time, then the remote can take over from there.
Good luck. I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 10, 2011 | Heating & Cooling
I have a Hampton Bay Cieling fan, model # FAN- DH L3H2003, and the remote control does not work. How can I get a replacement?
before you buy a new hand-held remote ... have you changed ALL the batteries. There's a set in the hand-held remote and batteries in the receiver, which is behind the fan's cowling. If you haven't changed them all, I'd do that before investing in a new remote control.
if you find, after changing all the batteries, you do need a new remote control, here is a link to one for all Hampton Bay Ceiling Fans.
http://www.homedepot.com/h_d1/N-5yc1v/R-100071965/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Hope this helped you. Please let me know. Thanks.
Jun 01, 2011 | Hampton Bay Heating & Cooling
How do you install the remote transmitter in a Hampton Bay Ansley ceiling fan?
jaggirl, most Hampton Bay, Remote Controlled Ceiling Fans have the receiver already installed inside the fan's cowl. The Transmitter is the Hand Held Remote. Both require batteries.
Apr 05, 2011 | Air Purifiers
I have a casablanca ceiling fan 35G11R( old model) lost remote,
I see you have an R on the end of your model# R designates Comfort Touch. I would be interested in buying the remote control from you.
As for ordering the parts, refer to www.casablancafanrepair.com
Jan 26, 2010 | Casablanca Fan Advan?Touch W-62 Remote...
Need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
May 31, 2009 | Hunter Ceiling Fan Remote Transmitter...
Installation
I assume that you're talking about a remote-controlled ceiling fan.
There are two parts to a remote-control setup -- the transmitter (the switch which you use to operate the fan and/or light), and the receiver (which receives the signals sent by the transmitter, and directly controls the fan and/or light).
The receiver -- which should look like a plastic rectangle, usually white, grey, or orange-brown in color -- can be identified by the fact that it has several colored wires coming out of it, and doesn't have any buttons. This is mounted in the ceiling fan itself. On nearly all setups, it goes inside the canopy (the decorative part of the ceiling fan, up by the ceiling, which hides the fan's electrical wires).
The transmitter may be either hand-held like a television remote control, or in-wall mounted like a light switch. If you have the hand-held variety, there is nothing to install in a wall box. The wall-box wires should be appropriately connected up, and a blank cover plate should be put on top of the gang box.
If, on the other hand, you have the in-wall variety of transmitter, then yes -- it gets mounted in the wall, in a gang box, like a normal light switch or outlet.
If you need any further clarification, please feel free to ask!
Jun 17, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
326 people viewed this question
Top Dryers Experts
