Question about aFe 2003 Ford Ranger - 2.3L 4-cyl. engine - Air Filters
Code p1120 engine light came on code p1120
The engine turns but won't start, after no problems the day before
You should get a code reader to see if there are any OBD codes that are set. This problem is usually caused by the crank sensor
Mar 17, 2016 | Hyundai 2007 ELANTRA Electric Engine...
Does check engine light reset after replacing faulty gas cap.
A check engine light will not clear itself! The light will have to be code read and reset using a OBD code reader.
Feb 26, 2015 | AEM Brute Force Intake 2003-2005 Ford...
Would a bad intake gasket cause a check engine light or for the insufficeint flow to EGR code come up?
Yes it can be. Here is a simple way to check for a intake leak. Get a can of crab cleaner. Start the motor, let the motor idle if it will. Spray the crab cleaner around the intake where it bolts.to the cyl heads. If the intake is leaking you will hear the motor idle change. You can check vac lines the same way. Hope this helps you find the problem.
Jun 12, 2014 | aFe 2001 Chevy Impala - 3.4L V6 - Air...
Abs light on on the dash and a motor under van stays on when key is off
the motor you are hearing could be the abs pump. abs light will not come up on a code reader for engine as its classed as body part. if it is this pump then the system is faulty and the pump running can mean that it has a broken fin inside you cannot fix this part and another abs pump will be need to fix this.
Mar 11, 2014 | EBC Brakes 2001 GMC Safari - AWD, without...
Reset engine indicator light
1. With the Car Off, Press and hold down the Odometer Trip Reset Button. 2. While still pressing the Trip Reset Button, Turn the Ignition Key half way on where all your oil, check engine lights etc.. turn on. Don't turn it as far as you would to normally start the car. Wait a few seconds and the Check engine light will turn off. 3. Turn the key back to the Off position and you're done.
(source: Yahoo Answers)
Feb 08, 2014 | aFe 2004 Honda Accord - 3.0L V6 - Air...
Engine failsafe program light
no ---you have a problem so run the fault codes to find out what it is
then use a scan tool to reset the ECM
Feb 16, 2018 | aFe 2001 BMW 7-Series - 740iL, 4.4L V8 -...
Renault scenic problems
there is one major prob with renault engine manegment system is the crankshaft position sensor when it goes faulty it can cause strange problems get it changed first its easy and inexpensive to replace. is the eml light on? if so the fault code may relate to a throttle body fault
Oct 21, 2017 | Accel 77135-1 GEN VII Throttle Boddy...
Check engine light
The PCV system in the 3.6 is a cyclonic separator (like a Dyson vacuum) integrated into the valve cover on the passenger side. It can get clogged, but it's rare.
Nov 08, 2013 | aFe 2006 Volkswagen Passat - 3.6L V6 - Air...
Mitsubishi fuso 2008 check engine light
Hello
When the service engine soon light (Also called the check engine light) is turned on this is to alert you to the fact that powertrain control module (computer) has detected a failure somewhere in the systems it controls, this can be the transmission or the engine or emission system, there are fault codes set in the modules memory for these faults. What needs to happen now is to have the powertrain control module scanned with a special tool called an OBD2 electronic engine control scanner or a OBD2 code reader. Once the code(s) are read then you must perform the diagnostics for each code and make the appropriate repairs based on the findings of the diagnosis that was performed, this is called doing "Pinpoint" testing.
Jun 23, 2012 | Mitsubishi 4 Fuso Truck Fe 2005 / 2008 Air...
aFe 2003 Ford Ranger - 2.3L 4-cyl. engine - Air Filters Logo
41 people viewed this question
Top aFe Air Purifiers Experts
Pcm2048
Jim Goldsmith
Jim Goldsmith
Thomas Perkins
Thomas Perkins
Are you an aFe Air Purifier Expert? Answer questions, earn points and help others
