Question about Optics
Towa telescope manual - Optics
I have a towa ex300 and have just reseted it anew, now on programing it, the decimals are not showing up on the print
Some models have a decimal setting in the programming codes. Check to see that you have reset it correctly using the decimal for your country.
For those who have asked about a Towa EX300 manual, try here:
https://the-checkout-tech.com/manuals/cashregisters/Towa_EX-300_and_Geller_EX-300_operating_and_programming_manual.html
Mar 31, 2017 | Towa Retail Supplies
Date&time on et 5616 towa
Hi Reggie,
Towa registers have special programming codes. That is such an old model that codes won't be on the net. You would need to get them from the manual. Try this one:
https://the-checkout-tech.com/manuals/cashregisters/Towa_ET-5616_operating_programming_manual.html
Nov 26, 2016 | Towa Retail Supplies
When i getting z report, journal report is coming with Z report but i want only z report what can i do to solved this problem ? BRAND:TOWA, MODEL:TX-500
You can turn that off in the settings for Towas. It's called something like print electronic journal with Z report. Just set it to only do Z report. Checkout tech has the most Towa manuals: https://the-checkout-tech.com/manuals/cashregisters/Towa3.php
Dec 09, 2015 | Retail Supplies
How to adjust my Tanzutsu telescope?
Go to this link and you'll see several different manuals for your telescope. http://www.manuals.club/results_alpha.php?search=TELESCOPE+TANZUTSU
May 31, 2014 | Tasco Optics
Towa manual
Key on P1 1-start-select then put date then cash
2-strt -select put time in 12hr then cash
Dec 03, 2013 | Towa Retail Supplies
Sear's Refractoring telescope Parts
Most of the refractors sold by Sears were made by Towa of Japan. These used the Japanese standard .965" barrel diameter eyepieces. These are hardo come by today and usually not worth the hunt. Get an 1.25" to .965" "hybird" star diagonal that will permit the use of 1.25" accessories. Orion sells this item. HTH, Geo.
Jan 09, 2008 | Optics
Optics Logo
110 people viewed this question
Top Optics Experts
james laughton
james laughton
ray gallant
Are you an Optic Expert? Answer questions, earn points and help others
