Question about Samsung Digimax S630 Digital Camera
Flash I can't figure out how to turn the flash on, help!!!!
It should come on automatically if you have the top dial set to auto(auto lines up with the little black dash that is direcly to the left of the dial when looking at the top of the camera from the LCD side) and a lower light environment. If you are in a bright light environment the flash will not function.
Posted on Sep 07, 2007
SOURCE:
Flutterby fairy charge with charger blinking
STATUS LIGHT will FLASH RED when
charging. Allow at least 30 minutes
for a full charge.
STATUS LIGHT will turn ORANGE,
and then turn off when charging is
complete.
STATUS LIGHT will FLASH GREEN
when the batteries in the CHARGING
BASE are LOW. Replace the
batteries.
STATUS LIGHT will FLASH RED &
GREEN when there’s a CONNECTION
ERROR. Reconnect the FAIRY.
Jan 03, 2014 | Butterfly Toys
How do i turn off my flash on my panasonic dmc-fh27?
Touch [MENU] to bring up the menu. Touch [REC] to enter the recording menu. Touch [FLASH] to enter the flash menu. To turn the flash off, select "Forced Flash: OFF" (lightning bolt in a circle with a slash through it).
The flash menu is described on page 66 of the advanced manual.
Feb 25, 2012 | Panasonic Lumix DMC-FH27 / DMC-FS37...
How do I turn the flash off?
Push the button with the lightning bolt and watch the screen. When a lightning bolt in a circle with a line through it appears, the flash won't fire.
Nov 11, 2009 | HP Photosmart E327 Digital Camera
How do I turn the flash on my camera? It is a Mitsuba DV304.
You move the joystick to the left to enable the flash!.... took me forever to figure it out lol.... hahaha
Jan 19, 2009 | Mitsuba Video Cameras
My pictures turn out fuzzy all the time and i can't figure out how to turn on my flash. Please Help! Casio Exilim EX-Z70
Flash should turn on by pressing the "Set" button and then the down arrow until you get to the flash menu. Choose the setting that looks like a lightning bolt.
If that doesn't work press the "Menu" button and then press the "right arrow" until you are on the far right tab. Press the "up arrow" until you come to "Reset." Press the "Right arrow." The camera will ask you if you want to reset it. Tell it "Yes." This will take it back to factory settings and clear any mode that turns the flash off.
Are the pictures fuzzy because the flash isn't working? Are outdoor pictures in daylight fuzzy or OK? If they are fuzzy all the time you may have a lens problem. If they are only fuzzy when the flash is needed, fixing your flash should cure the problem.
Dec 18, 2008 | Cameras
I cannot figure out how to turn off the flash on my canon sd450
You first need to change the operating mode to Manual. Then you can change the flash by pressing the right button a few times.
Nov 19, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
How Do I?
Hi - You can download the manual from the link underlined in blue below:
Powershot a400
See page 40:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 13, 2008 | Canon PowerShot A400 Digital Camera
Digital concepts camera
you've got to change the view... it may be on the outdoors view. On the side of the camera opposite the batteries, there's a switch that has a flower, and two piramids. Change it to the piramids and turn on the flash
Dec 31, 2007 | Cameras
Sunpak 266d for Minolta-Ricoh
Found this on line. Hope it helps. http://www.cameramanuals.org/flashes_meters/sunpak_auto_266d.pdf
Nov 11, 2017 | Sunpak 266D for Minolta-Ricoh TTL Flash
Samsung Digimax S630 Digital Camera Logo
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
