Question about Philips Televison & Video
Set up menu coming on everytime tv is turned on
I have a philips lcd tv model no 37pfl5522d-05 it has been working fine,but has started with this problem.the set up menu comes up everytime the set is turned on as if you have just took it out the box.i go through the set up ie language, country, then scan, it finds all the programs and goes through the set up ok.you can then watch the tv but when you turn off and then come to turn on again the set up menu comes up and you then have to start all over again with the set up can anyone help thankyou
falter
  • 245 Answers
SOURCE: Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u have.....how old is ur TV?
hope u get a answer from hitachi....and good luck
Posted on Mar 12, 2009
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Posted on Mar 13, 2009
  • 476 Answers
SOURCE: digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
Posted on May 19, 2009
  • 65 Answers
SOURCE: Acoustic Solutions TV Fault
I think you are looking at a power board problem. I had the same thing happen to a Vizio and I replaced the power board and it solved the problem. It could also be the input board but most likely the power board.
Thanks,
Ced
Posted on Jul 13, 2009
joedirty
  • 158 Answers
SOURCE: I have an AVOL ALT3213M TV 32
Yes, I had the same problem and it was the invertor board that controls the lamps .I bet ya that's your problem.Hard to locate parts for these lcd's.If you find a supplier please post.Have fun locating parts. It took me 2 weeks to locate one.
Posted on Jun 19, 2010
How do I change my tv to hdmi without remote
press mode and then either channel or volume button thenit should work
May 13, 2015 | Philips Silver Tilt/Tilting Wall Mount...
How to resert colour on philips tv model 37PFL5522D/05
there will be an option on your controls that allows you to reset.
go to colour
select factory default
Aug 12, 2013 | Philips Silver Tilt/Tilting Wall Mount...
My phillips tv model number 37pfl5522d/05 colour has gone dark
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 16, 2012 | Televison & Video
Need to tune in Philips Tv 14pv284/05 lost manual
If you're trying to scan for channels, this option should be found in your menu. I am not sure what your menu looks like, but usually there is a "Channels" setting in your menu. You can then select "Start Scan" or "Scan for Channels." You might also look for anywhere that says "Initial Setup" or somewhere in the menu that says "Add/Remove Channel." For some reason, Philips does not allow you to look this model up on their website. If you can't figure out the menu you should try calling Philips customer support.
LCD Television (2008 and newer)
1-866-771-4018
Televisions (purchased before 2008)
1-866-310-0787
May 01, 2011 | Televison & Video
I have lost the manual to my philphs 37pfl5522d/05 plz could u help me as i can not tune the tv in
You can download and print the instruction manual in PDF format by clicking this link.
For more information and details, click here
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Sep 16, 2010 | Philips 37PFL5332D 37 in. LCD Television
Hi, where can i get a replacement screen for the philips 37pfl5522d/05 or what other 37'' screen is suitable for this model
You can try looking here:
www.shopjimmy.com
You may have to look inside the TV to see who actually makes the screen for your TV, you can have same model of TV with mare than one screen makers being used. The screen is the MOST expensive part of the TV, it may be more than what your TV is worth.
Nov 15, 2009 | Televison & Video
Digital channels have stopped working, only blue screen!
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
37PFL5522D/12 remote channel
hi my name is mark, if i understand you correctly you are using the bose remote to control the tv.if so follow link. http://www.managemyhome.com/mmh/products/ManualSearch.action you will be able to down load the owners manual for your bose system. hope this helps. thanks for your question.
Mar 18, 2009 | Televison & Video
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
