Why will my programmable honeywell thermostat not keep changes to my schedule
I have tried adjusting settings on my programmable thermostat but it is not saving the changes....why?
    Top Expert:
  • Heating & Co... Master
  • 36,394 Answers
Could be batteries need replacement
Posted on Apr 28, 2013
How do I cancel schedule on Honeywell Thermostat TH6320R1004 and operate manually
https://customer.honeywell.com/en-US/Pages/Product.aspx?cat=HonECC+Catalog&pid=TH6320R1004/U
There is an owners/installation manual at this link. Option #16 shows that it's a programmable only tstat. You don't have an option to remove the programming. Hope this helps!
Mar 31, 2017 | Honeywell Heating & Cooling
Rth9580wf1005 changing setting on own
There may be a sudden weather change or heat change that may set it of. Also it might help to double check your settings just in case one of the buttons or dials have been knocked.
Mar 01, 2014 | Honeywell Electronic Programmable...
Trying to set temp on honeywell t-stat
I believe what your experiencing is the 75 degrees is the hold temp position...the display then reverts back to the actual room temperature...it doesn't mean the set temperature changed back to 65 degrees. Try to reprogram the thermostat schedules, and try not to use the hold function...just the temporary hold. (which is bumping the programmed temperature up or down until the next programmed period)
Dec 09, 2013 | Honeywell Programmable Thermostat Heater
No control boiler runs will not turn off at programmer if I turn wall sat no it gos off
If it turns off, in any way from the thermostat, check the programming for over lapping schedules that could keep it running.
Nov 30, 2013 | Honeywell Programmable Thermostat Heater
How do I set the temporary or permanent override feature on the Honeywell RTH2310B model thermostat?
To set the temporary override, press arrows up or down to desired temp. This will keep temperature
at temporary setting for 2 hours then return to programming. To permanent override press MODE button until schedule period number disappears (number inside little house on stat). Then adjust temp with arrows. Press the MODE button again to cancel override and return to programmable.
Jan 25, 2011 | Honeywell Programmable Thermostat Heater
Honeywell Chronotherm iv fan keeps running even when heat and cool turned off. How do I turn it off?
To turn the fan off, press the "fan key" until it says "auto". This will turn the fan off. When the programs scheduled, changes, the fan will go on again. You have to repeat the fan to "auto" each time the schedule changes.
May 12, 2010 | Honeywell Programmable Thermostat Heater
Does this thermostat have a delayed start setting?
You will have to have the installer manual and go into the con fig settings to change Honeywell.com
Jun 16, 2009 | Honeywell Electronic Programmable...
Non-deletable schedule in VisionPRO TH8000
The thermostat has a function called "Adaptive Intelligent Recovery".
This feature allows the thermostat to learn how long the furnace and air conditioner take to reach programmed temperature settings, so the temperature is reached at the time you set. For example: Set the Wake time to 6 am, and the temperature to 70°. The heat will come on before 6 am, so the temperature is 70° by the time you wake at 6.
You can turn off this function. Download the installation guide at the next link:
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH8321U1006
and look for funcion number 0530 Adaptive Intelligent Recovery. In this manual you also find the way to do a reset with the function number 0710.
I hope this solves your problem.
Nov 19, 2008 | Honeywell Programmable Thermostat Heater
Honeywell thermostat
Go to www.honeywell.com and search their data base for your model of thermostat. You wil need all the numbers of your thermostat to be able to search. Once you find it, download the installation manual.
Good Luck.
Dec 03, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
815 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
