Question about Simplicity SE3 Computerized Sewing Machine
Thread loose on the bottom of fabric - Simplicity SE3 Computerized Sewing Machine
    New Friend:
I have the same problem. mine is brother LS 1217
Posted on Jun 15, 2013
Having issues with my Janome 6500P with stitches since I had service
Sounds like a threading issue.
Be sure to install a brand new needle (every 8-16 hours!).
Remove the top thread completely from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. You may need to tweak the top tension until the two threads meet in the middle of the fabric.
This should take care of your problem. If not, you may have the technician look at it again.
Remember, thread problems under the fabric are usually top thread issues. Thread problems appearing on top of the fabric are usually a bobbin thread issue (or top thread tension being too loose).
May 04, 2018 | Janome Sewing Machines
Top stitch is fine bottom is loose. Have tried adjusting tension but not working. If I get tension too tight breaks thread so I gradually change tension to no avail. Please help
Check your stitch sample. The loose stitches under the fabric--are they actually top thread???? Usually,stitch problems under the fabric is a result of a top thread problem. In this case, it could be bird nesting.
Remove the top thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot.
Rethread from the beginning.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 21, 2017 | Sewing Machines
My bottom tention of Bernina Deco 340 is to loose. How to I correct is. The top treat shows to much at the bottom
Um, the top thread is showing on the bottom of the fabric? The top tension is too loose. The two threads create a tension battle, one pulling against the other. To pull the bobbin thread up, tighten the top tension. The tension is accurate when the two threads meet "in the middle" of the fabric. On thinner fabric, you might see a tiny spot of bobbin thread on the top and a tiny spot of top thread on the bottom.
Aug 24, 2017 | Bernina Sewing Machines
The tension on my machine is off.I don't know which thread to adjust.bobbin or top thread. on fabric top stitch seems ok,bottom stitch bunches up and is loose.How do I readjust the tensions?
If the thread problem appears under the fabric, it is a top thread issue.
If the thread problem appears on the top of the fabric, the bobbin thread is the issue.
Perhaps the upper thread is not seated completely in the tension disk. Remove the upper thread from the machine, ALWAYS RAISE the presser foot, then rethread from the beginning. Make sure the thread path is correct. Test your stitch.
If the thread is still looping under the fabric, the upper tension is too loose. Set the upper tension to the midway point. Test and adjust the tension until it is where you want it. Preferred tension is when both threads meet in the middle of the fabric.
sewing machine tension Google Search
Oct 29, 2016 | Sewing Machines
Doing zig zag the bottom thread is so loose - what is wrong?
the needle thread tension is too loose
tighten it up so that it pulls the bottom thread up into place
Sep 26, 2016 | Sewing Machines
Hi. I just bought this machine and I am having trouble with my bottom stiches. I have tried every remedie but the stiches is too loose
Read this hope it helps
http://www.threadsmagazine.com/item/4302/understanding-thread-tension/page/all
May 19, 2016 | Sewing Machines
Harrision gc5550. Why is bottom stitching loose?
Usually, loose threads under the fabric indicate a loose upper tension. Be sure that you RAISE the presser foot BEFORE threading the upper thread. This allows the thread to seat properly in the tension guides. If the loose threads are still appearing under the fabric, try tightening the upper tension. The upper and lower threads should meet in the middle of the fabric.
Sep 18, 2015 | Sewing Machines
Singer 301a...sews on top of fabric nicely...bottom is just loose loops of thread...it's like the bobbin is not sewing...I put 2 different colors in to see...top is perfect...on bottom of fabric I see the...
This is a tension adjustment problem. It's good to use two different colors of thread, like you did. From your description, the top thread (needle thread) tension needs to be tighter. As you tighten the tension of the top thread, you'll see that the top thread pulls the bobbin thread up into the fabric so it's no longer laying loose on the bottom of the fabric.
You'll need to have the pressure foot down when you tighten the tension. Tighten it a little, sew a practice seam, check to see what the stitch looks like. Tighten it a little more, sew, check, etc etc--until both top and bottom look the same--you shouldn't see much (if any) of the bobbin thread color on top of the fabric or the top thread color on the underside.
Let me know how this works for you, ok?
Robbie
Jan 25, 2010 | Singer Sewing Machines
BOTTOM STITCH IS ALWAYS LOOSE
If the top stitch is loose, then you need to tighten the bobbin tension: if the bottom stitch is loose, tighten the top tension. Hope this helps. It could also be the size needle and thread you are using for a particular fabric. Different fabrics require different notions.
Mar 13, 2008 | Sewing Machines
Simplicity SE3 Computerized Sewing Machine Logo
42 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
