Question about Tools & Hardware - Others
Air blow gun kit
How do I install the air blowgun kit under my seat?
    Problem Solver:
  • 12 Answers
You must tap into the existing air line that feeds your air ride seat There should be a brass fitting about the same size when you have On the air blower hose itself Take the videos and pictures underneath your seat so I can see what you looking at
Posted on May 13, 2013
3 Suggested Answers
  • 2712 Answers
SOURCE: Blow Gun Specs
Specifications for air blow guns include pressure capacity and air line connection type. Pressure capacity or maximum rated pressure is rated at the air inlet and measured in pounds per square inch (psi). Many types of air line connectors are available. Quick-release connectors contain fittings that are attached internally. By contrast, push-on connectors include barbed ferrules. Air blow guns use several types of national pipe thread (NPT) connectors, most of which are inch-based and female. Important NPT measurements include threads per inch (TPI) and outside diameter (OD). 1/8” NPT connectors have 27 TPI and an OD of 0.405”. 1/4” NPT connectors have 18 TPI and an OD of 0.540”. 3/8” NPT connectors also have 18 TPI, but an OD of 0.675”. 1/2” connectors have 14 TPI and an OD of 0.840”. #10-32 NPT threads are also available. Air line connections that can swivel or pivot are suitable for applications that require versatile positioning.
Posted on Aug 27, 2008
  • 2712 Answers
SOURCE: how to Install Air Compressor and Nail Gun
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
Evolv 2 brad nailer no power
If you can check nailer on another compressor. If it works check your compressor, if not the nail gun is in need of repairs. Otherwise, reading the two guages on the compressor, check that the pressure in the tank is around 100psi and the regulated pressure is between 85 and 90psi. If not, regulated pressure is adjusted by the knob on the front of the housing. With a blowgun on the end of hose, connect the other end to the compressor. If you don't get any air the regulator may be broken and not letting air through. If you have air at the blowgun the problem may be with the nailer.
Apr 08, 2012 | Craftsman Air Tools & Compressors
Bad air leak out of handle can it be fixed
Depends, older Vacula 010 guns were easy to fix with new o-rings on the valve (there should be 2), the newer 020 guns can leak and seem not to be repairable, even with new o-rings. Unfortunately the older guns have been out of production for 4-5 years, replacement parts are not available. But the o-rings are a common size o-ring, easily sourced.
Dec 16, 2009 | Vacula 4" Full Flow Blow Gun
Most of the car radio buttons don't work.
You want to purchase a small can of Compressed air,local computer store,Rshack,and this will allow you to apply compressed air to the surface of the radio in hopes to dislog that which my be causing a malfunction .
Please rate. Thanks jj505
Mar 20, 2009 | Mintcraft CC970 Air Blow Gun 13"
I purchased the Porter Cable 20 piece accessory kit part A00438, and no idea on how to assemble this. No instructions included either. This is the kit that allows to put airpressure in your car, bikes,...
First get some teflon thread tape, for applying 2 or 3 tightly wrapped turns around the male threaded quick-disconnect adapters, threaded end on your air hose and compressor before installation.
Note: remember that the female quick-disconnect adapter is also a check valve that will only release air when a male quick-disconnect adapter is inserted, i.e. do not install a  male quick-disconnect adapter directly to an air compressor outlet.
Note 2:Always remember to wear approved eye protection when operating air tools.
Start by installing the female quick-disconnect adapters on a male threaded end of the air hose and on to the outlet port on the air compressor tighten the connections with two open end wrench's. Then install the male quick-disconnect adapters to the other end of the hose, blow-gun tool, and the air chuck tool, (tighten as described above). The other implements in the kit (wire brush attachment, inflation needle, etc...) can be threaded in to the outlet port of the blow-gun as needed.
The operation of connecting  quick-disconnects are as follows: Grasp the tool in one hand, and with the other hand grasp the air line near the end leaving the thumb and fore finger free to operate the spring loaded outer release cylinder on the female quick-disconnect by pulling back on it. With the cylinder pulled back, insert the male quick-disconnect adapter in to the female quick-disconnect adapter, then release the thumb and fore finger from the outter release cylinder, thus locking the two together. check to be sure the lock has engaged by lightly pulling at the tool. Reversing this process will disengage the tool from the air line.
Hope this helps Good luck
Feb 21, 2009 | Porter Cable C2002 Wk Oil Free Umc Pancake...
How to Install Air Compressor and Nail Gun
Aug 27, 2008 | Mountain Air Blow Gun with Rubber Tip
Blow Gun Specs
Aug 27, 2008 | Astro Pneumatic AP 1718 Deluxe Air Blow...
Compressed air tool Usage
Craftsmen often prefer a compressed air tool over an electric power tool for certain jobs. Drywall and trim work are both made easier and accomplished more quickly with pneumatic tools. The most commonly purchased compressed air tool duo for homeowners is the pneumatic drill and nail gun. If you are a homeowner shopping for compressed air tools, be sure you understand how different models work and how the power is supplied. Read the manufacturer’s directions for use and maintenance, and be sure to have the proper sized hoses, fittings, and air compressor.
Aug 27, 2008 | Campbell Manufacturing Campbell Hausfeld...
How to use to clean my car?
Shoot the blow gun in all the tight spaces where your vacuum hose can't reach. If possible, attach a small jet pipe on the end of the gun to reach the tiniest crevices.
Aug 27, 2008 | Legacy Rubber Tipped Blow Gun
Tools & Hardware - Others Logo
297 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
