Compaq v6000 unable to detect wireless network of dlink dir 600 router. Others are able to use this router. Also I see other networks in the locality but notmine. I use windows XP. Please advise
  • 2,072 Answers
Well most likely if you're running Windows XP you have an older computer. Which means the computer may only operate on 802.11a or b or g and the router may be only operating on 802.11n standard. Your laptop doesn't operate on N therefore you can't see the 802.11n network. Either buy a new computer or you can buy a wireless N adapter to attach to the computer.
Posted on May 03, 2013
oldnovii
  • 667 Answers
SOURCE: Cannot configure D-Link DIR 625 wireless router
Hey Raj - Unplug your modem and router. After 60 seconds plug your modem back in. When the lights return to normal (except the activity light) , plug your router back in. Give it 10 seconds and try it. If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be happy to assist you further. Thanks.
Jeff
Posted on May 31, 2008
acdr
  • 1913 Answers
SOURCE: how to put a password on dlink dir-300 wireless network
u have to setup as wep
then enable secure network then set encryption key.wihc is prompt for connect network.
Posted on Dec 30, 2008
SOURCE: VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Posted on Mar 17, 2009
rtrahan
  • 741 Answers
SOURCE: Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Posted on May 03, 2009
  • 68 Answers
SOURCE: my dlink dir-600 wont connect ot the internet.
Please check the router settings page
Posted on May 02, 2010
I have a dlink n150 router dir-600L. i tried to configured it and changed the SSID and network key. the problem is, i cannot connect it to the wireless connection even though the network appears on my
Did you enter the security key (password)? It may be your laptop? Try resetting the D-Link to default settings and connecting to the laptop. They reconfigure the SSID and Security Key. Write down the info for future use. Here's a user Manual: http://www.dlink.com/uk/en/home-solutions/connect/routers/dir-600-wireless-n-150-home-router
Jan 24, 2013 | D-Link DIR601 WirelessN 150 Home Router...
I recently bought and through fixya.com I managed to connect a D-link DIR 600 router to a network of my apartment. We use hotspot login for this network because its not only me to connect. The problem
Hello here you can download info:
http://www.dlink.com/us/en/home-solutions/connect/routers/dir-600-wireless-n-150-home-router
Youtube setup:
http://www.youtube.com/watch?v=YzV3k845TJ8
Here is a picture how to connect it:
Connect the cable from your internet provider to the internet port.
The blue ports or 1 - 4 is for non wlan connections
such as a desktop pc or a network printer.
You maybe have to setup the wireless network with a code
so others can`t use your internet.
Good luck
Nov 19, 2012 | Computers & Internet
Can't connect my iphone4 to dlink it says dismis
lets try removing the security configuration if any from the wireless network then try connect the iphone again.
Dec 04, 2011 | D-Link DIR-615 Wireless Router
Ever since the storm I can't get online wirelessly, I can't get on with the internet cable direct but not with the dlink 600. Please help.
check
1.- Cable leave modem is attached to Port WAN (they are others 4 ports LAN)
2.- In router Dlink DIR 600 led Internet in On or blinkling
3. using web browser type http://192.168.0.1 (this is IP default )
4.- reset your DIR600, using a clip press in reset Hole 10 seconds
5. Try again using web browser type http://192.168.0.1
If connect, re configure your modem for your wireless network
Sep 14, 2011 | D-Link DIR-600 Router
Hi i Just bought dlink 600 i am using compaq and has iphone and internet tv all of them cant connect by wifi my compaq can only connect with a cable. on my tv it says internet connection failed. and btw cm...
ok first prep. we need to configure your router. to do that we need your compaq laptop directly connected to the dlink via ethernet cable. after securing the connection, try to open a browser, whether internet explorer or mozilla firefox. go to the address bar and type in, 192.168.1.1 it would ask you now for a username. username is " admin " password is " password " if it wont let you in, try "admin" for password. if it still cant, try to live it blank and just click on login. it would take you now to the dlink router page. there you can configure your wireless connection and set your network name. make sure to click apply settings after configuring it. then try to check your wireless connectivity again. this should work.
Sep 02, 2011 | D-Link DIR-600 Router
Hi sir, I want to configure DLINK 600 dir wireless router in my hathway connection. Pls help me sir.
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
Sep 24, 2010 | D-Link DIR-600 Router
I am unable to connect to the internet with my dlink
Just connect my dlink 615 to a new dell computer on the vista page for the Network and internet the broadband connection is disconnected. What can I do to connect it? When I switch the dlink network back to the old computer everything works fine.
Aug 03, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Dec 31, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
