Question about Briggs & Stratton Garden
Uneven cutting There is a dip in the grass between the 2cutting blades. I believe one of the blades may be bent. Is there any other adjustment that would cause this condition. Has anyone tried the gator blades on this unit.
    Problem Solver:
  • 7 Answers
Could be bent Spindles. Easiest way is to mark on deck where point of blade is and rotate blade around if both ends don't match mark on deck highly likely bent blade or spindle. Id say bent blade more likely.
In my experience Gator blades in general work fantastic.
Posted on May 03, 2014
SOURCE: UNEVEN GRASS CUTTING
The most common cause of uneven grass is tire pressure of the machine. Even though they may look like they have air, when you go around a corner it may droop down on that side. If the mechanism is intact, there is no reason for it to change while riding. Or possibly you have a bent hanger.
Posted on Dec 15, 2011
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
perpetually
  • 360 Answers
SOURCE: uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
Posted on Sep 21, 2009
panilling9
  • 284 Answers
SOURCE: Cuts uneven, lawn looks terrible. Missing half
Are your blades upside down? Mower deck level?Proper air pressure all 4 tires?Correct blades for the diameter of cut? Deck bent? Deck hangers bent?
Posted on May 29, 2010
  • 640 Answers
SOURCE: We hit a stump and
Most likely you have bent the shaft of the engine. Remove the plug and turn blade by hand to see if you have a wobble and see the bend in the shaft. If this is the case, the only way to repair it is to tear apart the engine and replace the crank shaft. Many mowers are not worth enough to pay to have someone do this for you. That leaves doing it yourself or replacing the engine (if you have a spare around) or replacing the mower. Sorry to give you the bad news.
Posted on Sep 09, 2011
The rear right wheel on my John Deere Z225 is scrubbing the frame.
A: Scribbling the frame:
-Possibly the bolts on the wheel are lose. And it turn warble that's why it scrub the frame.
B: Uneven cut:
-Uneven cut is not the tire or wheel. Possibly the height adjust on the cutter deck is broken or lose bolt. Or may be bend cutter blade as well.
Check it out
Good luck
Mail
Jun 12, 2018 | John Deere Garden
Dec 15, 2011 | Garden
The accelerator pedal is not working properly. Especially when trying to go up hill. I have to keep pushing & letting go, pushing & letting go. even when it starts to move. Also, the right blade...
I am guessing that this was posted in wrong category.
You mention that you have to keep pushing / letting go of the accelerator. Is the engine RPM changing, or is the tractor surging, when you do this? What happens if you keep a steady pressure on the pedal? Isn't the throttle control via a lever on the panel?
Your uneven blade height can be caused by a multitude of issues.
1) If the spindles were changed, the wrong spindle may have been used on one side or the other.
2) The wrong blade adapter has been used on one of the spindles.
3) Mower deck has been bent
4) Mower deck is binding. Try raising it all the way up, and lowering all the way down. See if the uneven cut changes at both levels (all up or all down).
5) Blade is bent on one side, though this would usually cause such a ruckus and vibration it would be quite noticeable.
6) Belt is slipping. Yes, sounds strange, but if blade speed changes significantly, then the position where the grass is actually cut changes because the grass can "lean over" more.
7) Using a mulching attachment in tall grass can cause 1 blade to clog, and the cut grass that is swirling bends over other grass that needs to be cut.
8) Mower deck support bracket has been bent
9) Mower deck wheel has a bad bearing, and doesn't support the deck at same height as other side.
10) Mower deck is cracked / bent at a support location
11) You have lost a retaining pin at a support bracket and the bracket is loose.
12) A spindle's bearings are worn out, and the spindle is "jumping" as it turns.
If the blades are directly beside each other where they blades will overlap, it is normal for a small amount of height difference to occur. But, most decks have off set blades, one slightly in front of the other.
you should be able to raise the deck all the way, and pull the tractor's front wheels up onto something (landscape timber?) to get more access, then measure blade height in relation to bottom of the deck. If different, then you are looking at wrong blade / adapter or a spindle issue. If the blades are the same height, then you are likely looking at a deck support issue / binding in linkage.
Aug 25, 2010 | Craftsman Garden
My mowers cuts uneven I replaced the blades but it still cuts uneven how can I level it?
Park mower on a level flat surface ( a concrete garage floor is ideal ) lift deck up until you can put a piece of a 2x4 flat underneath the deck and lower deck until it just contacts the 2x4. loosen adjustment nuts or turnbuckles and adjust until the deck just starts to clear the 2x4. this should level your deck. Now , lift the deck and remove the 2x4. put blade height lever on a known cut length and with a tape measure, measure the tips of the blades from the floor to the blade tip...they should all be the same within 1/8 of an inch...if not then you either have a bent blade, bent spindle shaft, or spindle bolts are loose or misaligned. Your deck could be warped too...depending on how hard a lick it took...good luck !!! ;-D
Jun 24, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
The mower is mowing uneven in the front. what can i do? it seems that it is scalping the grass but both sides are level
Look under the mower deck. If you can't see well and work on it, you may have to remove the mower deck and flip it over on the ground. Grass and mud buildup in the decj could cause a blade to pinch grass, 'scalping' the lawn. Clean it all out. Dull blades cause cut grass to look torn and brown. Remove and sharpen. Bent blade will cause uneven cut. Replace it. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
May 28, 2010 | Garden
Uneven grass cutting
Hope this helps.
Sep 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mtd riding mower: right mower blade cutting uneven, but don't see problem
The blade can be bent or the deck is not level. Adjust the deck and level it from side to side. Now level it from front to rear with the front of the deck 1/4" lower than the back. If after leveling it, you find it still cuts uneven remove all blades and inspect them. You will more than likely find one is bent. Replace a bent blade.
Sep 18, 2009 | Garden
42" deck - uneven mowing in the center
yes its repairable & yes it can bend the spendle but most likely the blades is it one that does it or both blades or the center or the sides of deck is bent by stepping on the deck let me know if i can further help thanks wade
Jul 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
47 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
