Desktop computer power issue
No fans or light when powered
  • 315 Answers
Hi Ryan,
Sorry but the video clip doesn't give me much to work with.
Can you confirm that the PC actually powers on and your operating system boots?
If the computer boots then the main fan attached to the CPU is connected and possibly running, if it wasn't working the computer would beep and power itself off.
So I'll assume you are talking about the case fans or the power supply fan....
The case fans could be something as simple as a disconnected cable or more complicated like a damaged wire or worst case the fan itself has become faulty and failed.. If you are thinking of removing any wires it would be best to take a photo or make a note of where it needs to be connected to but it would be better to test another fan connected in its place if possible.
If it's the power supply fan then the only option would be to purchase a new power supply that matches the specification of the existing one or even with slightly higher specs.
Best Regards
Mike
Posted on Apr 28, 2013
Why my desktop did not turn on?
U need technician, tell him to check with the other power supply then if he dont have another power supply then connect the Green and Blank point on the cable coming from the SMPS, if SMPS fan is powering on then issue is with ur motherboard and if not then issue is with ur power supply that is SMPS
Aug 20, 2014 | HP Pavilion Computers & Internet
We have around 30 units of DELL Optiplex GX280 having mother board failure. It was more then 3 years old already. Once the turbo fan become noisy then it will gone dead.
May be serious. See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans sound like 747 taking off. Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad.
I obviously can not be 100% sure about this as the unit is not here.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one such link.
http://en.community.dell.com/support-forums/desktop/f/3514/p/19253544/19414291.aspx
Feb 16, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
The computer dose not turn on.when i push the power button the cpu fan speed up and the speed of fan is going on.there is no video on the monitor.
This is a response I gave to someone else with a similar issue.
May be serious. See if the power light goes amber after power up. I had (have - still siting in my basement - gx280 minitower) one that did same. Power up, fans sound like 747 taking off. Power light goes amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad.
You can google this and see the issues. Here is one such link.
Dec 24, 2010 | Dell OptiPlex GX280 PC Desktop
Dell optiplex 330 flashing orange on the power botton
Try to clean the RAM and place it again in the motherboard.
May 31, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
When I turn it on, only the fans run. I cannot hear the hard drive run and the hard drive light on the bezel is solid yellow
look on bios to see if detects the hard drive ...if does not boot to windows...the hard disk has no reason to go on ....and the issues could be many ....check the Ram memory if do not appear anything on screen at all ...and just runs the coolers and clicks without boot at all...in this case its the Ram memory ...so check it ...get it out ..put it back ...and remove the bios battery to force it see them again .....if it is booting until the operating system should appear ...and after that nothing ...reinstall ...
Also .....if there is anything written on the screen ..read carefully ..usually it will say whats wrong ...and advise in same issues..like replace hdd ...or files missing ...or blue screen error from memory issues..
Nov 07, 2009 | E-Machines T6216 (827103077834) PC Desktop
The computer will not power up and there is a flashing green light in the back
Replace power supply..May have juice enough to turn on powersupply fan and maybe cpu fan but not enough amperage to power up system. Go to Best Buy or local Computer shop and replace yourself.
Aug 28, 2009 | HP Presario S3200nx (DC479AR#ABA) PC...
HP Compaq Presario SR1820NX will not turn on
i worked for hp and compaq it is well known issue to reslove this issue
1#turn off the computer and uplug the power cable from the computer and then hold the power button for 20 second then turn on the computer and the momment you back to desktop screen
go to download driver from hp site and here is the web site http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-43507-1&lc=en&dlc=en&cc=ca&lang=en&os=228&product=1841849 and restart the computer .
Apr 15, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
HP Media Center Power Up Problem
replace the power supply-from a computer store, should be no more than 30 dollars
Nov 02, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
Computers & Internet Logo
David Payne
David Payne
