Question about Vehicle Parts & Accessories
Keyless entry won't
Keyless entry won't work for my 2004 F150 tried reprogramming it did not work
    Master:
  • 435 Answers
Video might not help but sit in the car insert ur keys in the ignition and turn it on and off for 8 time as quickly as possible and after the 8th time press the remote button and it should work. Hope this helps cheers
Posted on May 03, 2013
I went through programing as far as lock recycling but wont go any further
Remote Transmitter Programming NOTE: All keyless entry remote transmitters must be programmed at the same time.
NOTE: Programming (or reprogramming) the keyless entry remote transmitters into the central security module can be accomplished using a diagnostic tool or by carrying out the following steps.
  1. Turn the ignition switch from OFF to RUN eight times within 10 seconds, ending in RUN. If the module has successfully entered program mode, it will lock and then unlock all doors.
  1. Within 20 seconds, press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed. Repeat this step for each transmitter.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Inspection and Verification.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after Step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the doors will lock and unlock one last time to confirm.
Mar 18, 2016 | 2004 Ford F150
Keyless remotes not working
Try reprogramming the remotes. Here are the instructions for the procedure. Hope it helps. Cobra!
Programming NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
NOTE: To program (or reprogram) the keyless entry remote transmitters into the RAP module, perform the following steps:
  1. Make sure that the anti-theft system is not armed or triggered.
  1. Turn the ignition switch (11572) from OFF to RUN eight times within ten seconds, ending in RUN. If the RAP module has successfully entered program mode, it will lock and then unlock all doors.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the RAP module will lock and unlock all doors one last time to confirm.
Jun 06, 2010 | 1998 Ford F150 Regular Cab
How to program a keyless entry for land rover
MOST OF THE TIME WHEN YOU HAVE PROBLEMS IN THE REMOTE AND KEYLESS ENTRY.THE DEALERSHIP HAS TO REPROGRAM IT.BUT FIRST CHECK ALL THE FUSES AND RELAYS.IF THEY ARE OKAY.THEN DEALERSHIP HAS TO FIX.
Sep 16, 2009 | 2004 Land Rover Discovery
Mazda 3 yr 2004
Fords "better idea"...go to an automotive stereo shop that does keyless entry install for around $89...it's the cheapest way to go anyway. Dealer will have to reprogram the FOB, you're looking at $100+
Jun 14, 2009 | 2004 Mazda 3
Keyless entry not working
Mine did the same thing, but it was the battery claw on the inside of the remote has come loose from the circuit board. I bought one from www.keylessride.com its like 45bucks after shipping. Its better then the 120 the dealer wanted. They will send you reprogramming steps too, it was super easy.
Apr 16, 2009 | 2004 Chevrolet S-10
I can't find the keyless entry code for my 2004 ford freestar
The code is on the fuse box under the dash near the hood release. On my van there are two bar codes on a sticker attached to the fuse box. Under the first bar code, on the right side is the 5 digit code (bring your glasses the numbers are really small). After you get this code, just search the internet and there are plenty of forums on programing the keyless remote and also adding your own unique number to the key pad entry.
Good Luck
Mar 08, 2009 | 2004 Ford Freestar
2005 F150 Keyless Entry
There is a technical service bulletin out on this probelm on 2004/2005 F150.
ISSUE: Some 2004-2005 F-150 vehicles built through 2/7/2005, may exhibit an inoperative keyless entry keypad. This may be due to the vehicle security module (VSM) not being configured to accept keyless entry keypad input.
The fix is to reprogam the vehicle security module with as-built data. So it would have to go to the dealer to do this.
The tsb number is 05-5-5.
Feb 21, 2009 | 2005 Ford F-150
the keyless entry system is tied into the computer system and needs to reprogramed by the dealership
Nov 30, 2008 | 2004 Jeep Grand Cherokee
Vehicle Parts & Accessories Logo
574 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
