Question about Refrigerators
Lg refrigerator lrtx18311ww - Refrigerators
LG lfx31945 REFIGERATOR...FREEZER NOT COOLING. ER FF CODE
LG Help Library: Error Codes - Refrigerator ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library
  1. Cached
  2. Similar
Feb 26, 2018 - FF Error Code. A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup. ... If you notice frost buildup along the walls of the freezer compartment, the leveling and door alignment of the refrigerator will need to be checked.
SOLVED: Error Code ER FF - Fixya
www.fixya.com/support/t121701-error_code_er_ff
  1. Cached
  2. Similar
Oct 18, 2006 - Error Code ER FF Our refrigerator is 1 year & 1 week old. A few days ago it started making a noise that sounded - LG LRBC22544 Bottom Freezer question. SOLVED: Error codes Er rF 10 posts 14 Nov 2013 Lg lfx31925st 00 code er ff 10 posts 21 Sep 2013 SOLVED: How Do You Repair An lg lfx31925st error ... 11 posts 16 Nov 2012 SOLVED: LG refrigerator lrsc26944tt error code ER FF 11 posts 25 Jan 2009 More results from www.fixya.com
FIXED LG refrigerator error code Er FF - ApplianceBlog
https://www.applianceblog.com/mainforums/.../8302-LG-refrigerator-error-code-Er-F...
  1. Cached
  2. Similar
Mar 31, 2007 - Hey guys, This LG has me stuck. I have run the smart board entirely through the diagnostic mode and it says everything is OK - hours later a code comes up "Er FF" Model: LRSC26922TT Serial: 407KRPV00464 I have had no luck finding any useful info on the web.... nothing but horror stories about LG. FIXED LG Refrigerator LFXS32726 - Error Code E rF 3 Aug 2016 LG LFX31925 drain iced up (ER FF code) - How to remove freezer ... 24 May 2016 FIXED LG LFX31925ST Giving error code ER RF 3 Sep 2013 Kenmore elite refrigerator error code er FF 3 Mar 2013 More results from www.applianceblog.com
LG REFRIGERATOR REPAIR. HOW TO REPLACE FREEZER FAN. FF ...
9k=? 4:42 https://www.youtube.com/watch?v=Yiifd2sTrZI
  1. Similar
Jan 3, 2013 - Uploaded by SOCALAPPLIANCE LG Refrigerator repair. FF error code / ee ff . Bad freezer fan. Bad evaporator fan. How to repair an LG ...
Mar 22, 2018 | LG Refrigerators
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
Error code listing for LG lsc27931st Refridgerator.
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
http://www.searspartsdirect.com/refrigerator-repair/error-codes/lg-bottom-freezer-refrigerator-error-codes.html
May 18, 2015 | LG LSC26905TT Side by Side Refrigerator
I need an owner's manual for LG refrigerator LFC237605W. thanks, ed
Assuming you really meant LFC23760SW, you can download the manual at
http://www.lg.com/us/appliances/refrigerators/LG-french-3-door-refrigerator-LFC23760SW.jsp
Feb 14, 2011 | LG LFC25760 French Door Refrigerator
I like to know if my LG refrigerator has warranty with the company because it's not working. I bought it 3 years ago and it is not getting cold.
You only have by default, a one year manufacture warranty on your refrigerator. If you bought a a extended warranty, you may still be covered.
Compressors on LG's are either five or seven year manufacture warranty.
Mar 26, 2010 | LG LRSC-26922 Side by Side Refrigerator
LG refrigerator compressor/lights won't turn on
You have a bad main board call LG service and discuss your options.
Nov 29, 2009 | LG LSC26905TT Side by Side Refrigerator
LG LFX25960ST refrigerator food freezing above the pantry draw. Made all the tempature adjustments and still happening.
I have the same problem and I know the solution.
For LG to get their "in the door icemaker" to work, they have to blow cold air into the door's icemaker compartment. This air travels through two vents located just inside the refrigerator on the left side. The problem LG has is that the seals between the door and the refrigerator for these vents leak. This means that cold air is vented into the refrigerator compartment. Any sensitive food placed on the bottom two shelf on the left side will freeze. I can place two bowls of water in my refrigerator and make ice in 6 hours, even though the refrigerator is set to 38 degrees. The good thing is that LG knows there is a design problem and they know they can not fix it. After calling LG repairmen out for my freezing problem and not getting the seals fixed, LG gave up. Of course LG will try replacing the seals, and then replacing the door; but the real problem is a bad seal design. Just keep putting bowls in your refrigerator and as long as they continue to freeze up, keep calling LG back and demand that they fix the problem. LG can not fix the problem because it is a bad design, so now I am getting a new refrigerator Model LFX 29927, which is better and has dual icemakers. If you an LG refrigerator with their in the door icemaker, place two bowls of water inside the refrigerator, and if your seals are bad and they freeze; complain to LG until they give you a new refrigerator.
Nov 10, 2009 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
