Question about Garden
Manual for 5020 earthquake - Garden
I’m looking for a carburetor for an Earthquake rear tine tiler with a Briggs and Stratton 5hp motor. It’s a model 5020 with serial # 201026
Chances are the Chinese produce a replacement and ebay is likely to list them alongside new and used genuine Briggs units. Amazon too are likely list some.
Might be worth trying freecycle too.
You might prefer to pay full price from a Briggs dealer which can be found almost everywhere.
Jan 29, 2018 | Briggs Garden
I need a parts manual for a earthquake model 5020 rear tine rototiller
contact the manufacturer on the net and look for a pdf version if available.
Jun 17, 2015 | Ardisam 5.5 Hp Rear Tine Rototiller
My Earthquake Rear Tine Gas Rototiller - 196cc Viper Engine 4-cycle just makes a squeeling noise and tines won't rotate.
Sounds like the belt is slipping. Have you removed the belt cover and inspected the belt and the tensioner pulley ? If your model is like mine the tension can be adjusted just below the handles by looseneing the nut where the cable goes into the cable sheath and moving the cable cover further away from the handle. That takes up some slack and will make the tensioner pulley tighter on the belt. If the belt is shot tension isn't going to help.
Try "google" with "earthquake 5070 manual" first option should be a PDF copy of a model 5070 manual. Will have diagrams on how to adjust the cables.
May 08, 2014 | Earthquake 6015V Rear Tine Rototiller
Error code e3000 0000
All problems associated with this copier can be found in its user manual. The link below is the user manual for the model associated with this question. A simple search in the manual of the error code should result in the answer to your question.
http://www.retrevo.com/support/Canon-5020-Copiers-manual/id/23385dj783/t/2/
Mar 21, 2011 | Canon imageRUNNER 5020 Copier
Need a user manual for Earthquake 3365PS tiller
I need a service manual for the earthquake 9800 auger with the 3.8 hp tecumseh.
May 12, 2010 | Ardisam 5.5 Hp Rear Tine Rototiller
Garden Logo
135 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
