Question about Bell Sports 1006376 AirStrike Dual Action Frame Pump
Airstrike bell 800 pump instructions
How to adjust for Schrader valve
Resistance when I try to pump, no air enters tire.
Make sure that the end isn't bent and connects to tire good. You will here a little air escaping if hooked up correctly. If that isn't it make sure there is no obstuction in the air line. Release relief valve and let air out.
It could just be the end, your connection to the tire, or at worse a bad pump.
May 29, 2016 | Bell Airstrike 1000 Gauge Frame Pump
Airstrike Bell 1900 , the hose is ripped. What do I need to do? How to replace it?
Always a good idea to contact the manufacturer: The Bell Garage or a bike shop may be able to help. The pump may accept a different brand hose.
Sep 13, 2013 | Airstrike Bell 1800 Floor Bike Pump
I have a "Judge"
Sure, A new O-ring and a little grease, the same you use on your bearings to make a good seal.
Without seeing and feeling the actual pump, a sloppy O-ring will cause a loss of pressure.
You will also want to check the head and make sure the rubber still makes a seal around the tube valve, if not then that will need to be replaced as well.
Mar 20, 2011 | Airstrike Bell 1800 Floor Bike Pump
Need new hose , where can I find this for airstrike 1800 model
Has anyone found a replacement hose for the Airstrike 1900? And/or instructions on how to replace it?
Jun 15, 2010 | Airstrike Bell 1800 Floor Bike Pump
Can a schrader valve and a pump w/ a schrader socket be incompatible? I cannot inflate a new Slime 26x tube w/ either of two Bell pumps. Air just compresses in the pump, as if the pin in the socket is not...
You may be on to something. Try pressing the valve open with a narrow object just to make sure it can open. Get a valve tool and remove the core to see what's going on inside. Take the tube back to the shop and have them prove it will take air.
http://www.google.com/#hl=en&rlz=1R2ADFA_enUS360&q=schrader+valve+tool&aq=f&aqi=g10&aql=&oq=&gs_rfai=&fp=a3c13f954bf61e86
Jun 14, 2010 | Bike Slime Self Healing Tube, 26"
How do I use the Bell AirStrike Digital Floor Pump
The gauge measures three different amounts. Be certain that you have it set to PSI. Then set the target PSI. The green LED indicator will then flash when you are within 5 PSI of your target and will flash constant when the target PSI is reached.
Jan 02, 2010 | Airstrike Bell 1800 Floor Bike Pump
Should I add oil to the top opening (where pump shaft enters same) if it's losing air out this opening when I go above 40 psi?
It's not the opening that is the culprit. Those bell bicycle pumps have an o-ring for a piston seal, and this ring needs oil from time to time. The oil that should be used is as thin an oil as you can find, something like 3 in 1. You should disassemble it to check to see if the plastic piston isn't cracked. (They do crack from time to time, and might be what is wrong with your pump.)
Nov 25, 2009 | Airstrike Bell 1800 Floor Bike Pump
Bicycle tire pump won't pump.
If you can? unscrew the two pieces of the pump clean and oil it. W/D40 works pretty good.
Apr 24, 2009 | Airstrike Bell 800 Frame Mount Bicycle...
Bell Sports 1006376 AirStrike Dual Action Frame Pump Logo
Top Bell Sports Plumbing Experts
Donni Steen
Tom Chichester
Are you a Bell Sports Plumbing Expert? Answer questions, earn points and help others
