Question about Kent International Kent Trouble 20 Inch Freestyle BMX Girls Bike
How do I adjust the brakes? - Kent International Kent Trouble 20 Inch Freestyle BMX Girls Bike
Replacing rear brakes
REMOVAL & INSTALLATION
It is a good idea to only disassemble and assemble one side at a time, leaving the other side intact as a reference.
  1. Raise and support the vehicle safely.
  2. Remove the brake drum.
  3. Disconnect the parking brake rear cable and conduit.
  4. Remove the brake shoe hold-down springs and brake shoe hold-down pins.
  5. Remove the brake shoe adjusting screw spring.
  6. Remove the brake shoe adjusting lever and adjuster screw.
  7. Remove the brake shoe retracting spring.
  8. Remove the brake shoes from the backing plate.
  9. Remove and discard the parking brake lever clip. Remove the washer.
  10. Remove the parking brake lever from the rear brake shoe.
To install:
  1. Thoroughly clean the backing plate with brake cleaning solvent and dry completely.
  2. Use silicone grease to lubricate the brake backing plate-to-brake shoe contact areas.
  3. Apply a light coating of premium grease to the threaded areas of the adjuster. Turn the adjuster in and out to spread the lubricant. Turn the adjuster all the way down on the screw and loosen one-half turn.
  4. Install the parking brake lever to the rear (secondary) brake shoe with a new clip.
  5. Position the brake shoes on the backing plate and install the brake shoe hold-down springs.
  6. Attach the parking brake rear cable and conduit to the parking brake lever.
  7. Attach the brake shoe retracting spring.
The socket end of the brake adjuster screw is stamped with "R" or "L" to indicate that it is to be installed either on the right (passenger's side) or left (driver's side) of the vehicle. The adjuster nuts can be distinguished by the number of grooves machined around the body of the nut. Two grooves indicate a right-hand adjuster nut and one groove indicates a left-hand adjuster nut. Another way to identify brake adjuster assemblies is to check thread pitch. The right side adjuster assembly has right-hand threads and the left side has left-hand threads. If installed correctly, the brake adjuster assembly will increase in length when the brake shoe adjusting lever is operated.
  1. Install brake adjuster screw in the slots on the brake shoes. The wider slot on the socket end must fit in the slot on the front (primary) brake shoe.
  2. Install the brake shoe adjusting lever on the lever pin.
  3. Install the brake adjusting screw in the slot on the secondary brake shoe and in the slot on the brake shoe lever. The brake shoe adjusting lever should contact the brake adjuster screw.
  4. Adjust the brake shoes.
  5. Install the drums.
ADJUSTMENTS
The drum brakes are self-adjusting and require a manual adjustment only after the brake shoes have been replaced, or when the length of the adjusting screw has been changed while performing some other service operation.
Drum Installed
  2. Remove the rubber plug from the adjusting slot on the backing plate.
  3. Insert a Brake Adjustment Tool (D81L-1103-C) or equivalent into the slot and engage the lowest possible tooth on the starwheel. Move the end of the brake spoon downward to move the starwheel upward and expand the adjusting screw. Repeat this operation until the brakes lock the wheels.
  4. Insert a small screwdriver or piece of firm wire (coat hanger wire) into the adjusting slot and push the automatic adjusting lever out and free of the starwheel on the adjusting screw and hold it there.
  5. Engage the topmost tooth possible on the starwheel with the brake adjusting spoon. Move the end of the adjusting spoon upward to move the adjusting screw starwheel downward and contract the adjusting screw. Back off the adjusting screw starwheel until the wheel spins freely with a minimum of drag. Keep track of the number of turns that the starwheel is backed off, or the number of strokes taken with the brake adjusting spoon.
  6. Repeat this operation for the other side. When backing off the brakes on the other side, the starwheel adjuster must be backed off the same number of turns to prevent side-to-side brake pull.
  7. When the brakes are adjusted, make several stops while backing the vehicle to equalize the brakes on both of the wheels.
  8. Lower the vehicle.
Drum Removed
See Figure 2
Fig. Fig. 2: When using a brake adjustment gauge, first measure the inside diameter of the drum (top) and then adjust the brakes shoes to the proper outside diameter (bottom)
  1. Remove the brake drum.
  2. Make sure that the shoe-to-contact pad areas are clean and properly lubricated.
  3. Using a Brake Adjustment Gauge (D81L-1103-A) or equivalent, check the inside diameter of the drum.
  4. Measure across the diameter of the assembled brake shoes, at their widest point.
  5. Turn the adjusting screw so that the diameter of the shoes is 0.030 in. (0.76mm) less than the brake drum inner diameter.
  6. Install the drum.
INSPECTION
See Figure 3
Fig. Fig. 3: Measure brake shoe thickness in several places around the shoe
Inspect the brake shoes for wear using a ruler or Vernier caliper. Compare measurements to the brake specifications chart. If the lining is thinner than specification or there is evidence of the lining being contaminated by brake fluid or oil, replace all brake pad assemblies (a complete axle set).
Dec 19, 2010 | 1998 Ford Windstar
1998 ford escort se hand brake need adjusting. doesn't hold.
Try to adjust the rear brakes tighter at the shoes, if you have drum brakes. May require taking the drum off and adjusting the adjuster. Or, adjusting it from the backing plate access hole if there is one.
Be sure to check the cables to make sure they are not broken anywhere between the hand brake lever and the back brakes.
Good luck on this repair.
ADJUSTMENT
  1. Raise and safely support the vehicle.
  2. Remove the wheel and tire assembly.
  3. Remove the brake drum.
  4. Using a brake adjusting gauge, measure the inside diameter of the brake
    drum.
  5. Compare the brake drum measurement to the brake shoes.
  6. Adjust the brake shoes by inserting a brake adjustment tool into the knurled
    quadrant of the rear quad operating lever and adjust the shoes to the same
    measurement as the brake drum.
  7. Install the brake drum.
  8. Install the wheel and tire assembly.
  9. Lower the vehicle.
  10. Check the brake system operation by making several stops while driving
    slowly forward.
Nov 02, 2010 | 1998 Ford Escort
How to installing brake shoes on back ?
First you have to compress the parking brake cable spring and attach the parking brake lever.
Clean and lubricate the brake backing plate.
Use silicon Brake Caliper Grease and Dielectric Compound.
Then,
install the rear brake shoes and linings:
1) position the rear brake shoes and linings
2) position the parking brake lever
3) install the brake shoe hold-down spring pins and the brake shoe hold-down springs.
Install the parking brake strut
1. install the parkig brake link spring on the parking brake strut
2. install the parking brake strut
3. Install the brake shoe anchor ping guide plate.
Install the short brake shoe retracting spring
1. Place the brake shoe adjusting lever cable over the anchor pin, with crimped side in
2. Install the short brake shoe retracting spring
Note: Make sure the brake shoe adjusting lever cable is positioned in the cable guide groove
Install the long brake shoe retracting
1. install the cable guide
2. position the brake shoe adjusting lever cable in the cable guide groove
3. install the long brake shoe retracting spring
Note: to prevent incorrect installation, teh socket of each brake adjuster screw is stamped R or L
Assemble the brake adjuster screw assembly.
1. apply silicone brake caliper grease and dielectric compound
2. install the brake adjuster screw into the brake show adjusting screw nut to the end of the threads and then loosen one half turn
3. install the brake shoe adjusting screw socket on the brake shoe adjusting screw nut.
Install the brake adjuster screw assembly
1. Position the brake adjuster screw assembly
2. Install the brake shoe adjusting screw spring
3. Position the brake shoe adjusting lever cable
4. Position the adjusting lever return spring and the brake shoe adjusting lever
5. Hook the brake shoe adjusting lever cable to the brake shoe adjusting lever.
Test the operation of the automatic self-adjuster
1. Pull the brake shoe adjusting lever cable and check that the brake shoe adjusting lever rotates the brake shoe adjuster assembly
2. Release the brake shoe adjusting lever cable and check that the brake shoe adjusting lever advances to the next notch on the brake shoe adjusting screw nut.
Adjust the brakes.
Thats it
Sep 10, 2010 | 1998 Ford Ranger SuperCab
I need a diagram of the rear brakes of a 1997 Intrepid Chrysler-where can I get one>
If the following is not enough then maybe try Alldata.com which generally has more information, but it will cost: REMOVAL & INSTALLATION Chrysler Concorde, New Yorker, LHS Dodge Intrepid Eagle Vision
  1. Remove the rear wheels and brake drums.
  2. Remove the dust cap from the rear hub and bearing assembly.
  3. Remove the cotter pin, nut retainer and wave washer. Discard the old cotter pin.
  4. Remove the rear hub and bearing assembly retainer nut and washer. Remove the rear hub and bearing assembly from the spindle.
  5. Remove the automatic adjuster spring from the adjuster lever.
  6. Rotate the automatic adjuster starwheel enough so both shoes move out far enough to be free of the wheel cylinder boots.
  7. Disconnect the parking brake cable from the actuating lever. Disconnect parking brake cable one side at a time.
  8. Remove the both lower brake shoe to anchor springs.
  9. Remove the 2 brake shoe hold-down springs from the brake shoes.
  10. Remove the brake shoes, upper shoe-to-shoe return spring, automatic adjuster and automatic adjuster lever from the backing plate as an assembly.
  11. Separate the brake shoes from the automatic adjuster mechanism.
  12. Remove the brake shoe automatic adjuster lever from the leading brake shoe. To install:
  13. Thoroughly clean and dry the backing plate. To prepare the backing plate, lubricate the bosses, anchor pin and parking brake actuating lever pivot surface lightly with lithium based grease.
  14. Remove, clean and dry all parts still on the old shoes. Lubricate the starwheel shaft threads with anti-seize lubricant.
  15. Assemble both brake shoes, the top shoe to shoe return spring, automatic adjuster and automatic adjuster lever before mounting on vehicle. Make sure the ends of the automatic adjusters are positioned above the extruded pins in the webbing of the brake shoes prior to installation.
  16. Install the brake shoe assembly onto the brake support plate and install the hold-down springs.
  17. Install the lower anchor springs and reconnect the parking brake cable to the park brake lever of the trailing brake shoe.
  18. Rotate the serrated adjuster nut to remove the free-play from the adjuster assembly.
  19. Install the automatic adjuster lever spring on the lead brake shoe assembly and the automatic adjuster lever.
  20. Install the rear hub and bearing assembly. Install washer and retainer nut and torque to 124 ft. lbs. (168 Nm).
  21. Install the wave washer, nut retainer and a new cotter pin onto the spindle. Install dust cap.
  22. Adjust brake shoes so not to interfere with brake drum installation. Install the rear brake drum. NOTE: After installing the brake drums, pump the brake pedal several times to partially adjust the brake shoes. To verify proper operation of the self-adjusting parking brake, be sure that both rear brakes are not dragging when the parking brake pedal is released.
  23. Install the rear wheels and lug nuts. Torque the lug nuts, in a star pattern sequence, to 95 ft. lbs. (129 Nm).
  24. Road test the vehicle. The automatic adjusters will continue brake adjustment during the road test of the vehicle.
Sep 03, 2010 | 1997 Dodge Intrepid
How to adjust parking brake. do you need to take anything apart?
You cannot adjust the cables on a minivan manually. the tension is automaitcally adjusted by the self adjuster on the pedal release.
The park brake cables on this vehicle have an automatic self adjuster built into the park brake pedal mechanism. When the foot operated park brake pedal is in its released (upward most) position, a clock spring automatically adjusts the park brake cables. The park brake cables are adjusted (tensioned) just enough to remove all the slack from the cables. The automatic adjuster system will not over adjust the cables causing rear brake drag.
Due to the automatic adjust feature of the park brake pedal, adjustment of the parking brake cables on these vehicles relies on proper drum brake.
When the park brake pedal is applied the self adjuster is by-passed and the pedal operates normally to engage the park brakes.
When a service procedure needs to be performed on the park brake pedal or the park brake cables, the automatic self adjuster can be manually locked out by the service technician.
Aug 25, 2010 | 2004 Dodge Caravan
Parking Brake doesn't work. I have adjusted the
Check your rear brakes and their adjustment. If parking brake is seperate check them also. The brakes have to work and be adjusted properly then adjust parking brake.
Sep 08, 2009 | 1996 Jeep Grand Cherokee
I need a diagram for the rear drum brake for 2002 Ford Ranger
Copy and paste this into your search window: 2002 ford ranger rear brake diagram
You should see four pictures pop up, select the brake parts diagram or the brake picture.
Sep 03, 2009 | 1993 Ford F150 SuperCab
I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
Drum, Rear Brake System Standard Rear Brake
Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
Heavy Duty Rear Brake
Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
The rear drum brakes:
  • Have internal shoes that expand against the brake drum (1126).
  • Are a single-anchor type.
  • Are actuated by one rear wheel cylinder (2262).
  • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
  • Adjust rear brake shoes and linings (2200) automatically.
  • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
Apr 04, 2009 | 1997 Ford F150 Regular Cab
Park Brake Adjustment
Park Brake Adjustment (Disc Brake)
Tools Required
j 21177-A Drum-to-Brake Shoe Clearance Gage
Park Brake Shoe Adjustment
Caution: Refer to Brake Dust Caution.
Important: The park brake shoes must be adjusted before the park brake cable tension is adjusted.Set the J 21177-A so it contacts the inside diameter of the rotor
  1. Position the J 21177-A over the shoe and the lining at the widest point.
  2. Turn the adjuster nut until the lining just contacts the J 21177-A. Park brake shoe to brake rotor clearance: 0.6604 mm (0.026 in)
  3. Repeat steps 1-3 for the opposite side.
Park Brake Cable Tension Adjustment
Important: Before you adjust the park brake cable tension, verify that the park brake shoes are adjusted to provide a clearance of 0.6604 mm (0.026 in) and the rear disc brake rotors are installed.
  1. Verify the self adjuster lock-out pin has been removed.
  2. Fully apply and release the park brake pedal 3 times.
Feb 22, 2009 | 2007 GMC Sierra C/K2500
Rear brakes scrubbing on 1998 chevy venture van
Removal Procedure Tools RequiredJ 38400
Caution: Keep fingers away from rear brake shoe springs to prevent fingers from being pinched between spring and shoe web or spring and backing plate.
  1. Remove the brake drum. Refer to Brake Drum Replacement
    Notice: Do not over stretch the adjuster spring. Damage can occur if the spring is over stretched.
  3. Use the J 38400 in order remove the adjuster spring (1). Disengage the adjuster spring loop from the tab on the adjuster actuator.
  4. 2.1. Remove the loop end of the adjuster spring from the adjuster actuator. 2.2. Remove the straight end of the adjuster spring from the secondary brake shoe.
  5. Use the J 38400 in order to spread the brake shoes apart.
  6. Remove the adjuster.
Installation Procedure
  1. Use the J 38400 in order to spread the brake shoes apart.
    Important: Ensure that the adjuster (2) engages the brake shoes (4 and 5), the park brake actuator (3), and the adjuster actuator (1) properly.
  3. Install the adjuster.
  5. Install the adjuster spring (1).
  6. 3.1. Install the straight end of the adjuster spring into the secondary brake shoe. 3.2. Install the loop end of the adjuster spring to the adjuster actuator.
Dec 06, 2008 | 1999 Chevrolet Venture
Kent International Kent Trouble 20 Inch Freestyle BMX Girls Bike Logo
167 people viewed this question
Top Kent International Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Kent International Cycling Expert? Answer questions, earn points and help others
