Question about Home
Delta 1016 P
Dropping delta shower valve.
  • 26 Answers
Your local hardware store sells a removal tool
Posted on May 06, 2013
thabrain
  • 76 Answers
SOURCE: Delta Monitor 14240 LHP shower head
one word clr. let it sit in the solition over nite it will remove scale and deposits. you can find clr at lowes, home depot, walmart, etc.
Posted on Oct 28, 2008
manhandy
  • 146 Answers
SOURCE: Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Posted on Jun 26, 2009
  • 44 Answers
SOURCE: need a diagram on how to disassemble a Delta 1900
http://www.deltafaucet.com/search/results.html?q=Delta+1900+
Posted on Sep 26, 2009
  • 54 Answers
SOURCE: a single handle delta shower control lets water
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
  • 129 Answers
SOURCE: I have a Delta 1400 single handle tub/shower valve
You might have to replace the tub spout, because the divirter is not closing all the way. A new one will stop water from getting by it.
Posted on Sep 30, 2009
I just installed a new shower with no tub. I have water to my delta fixture but no water out the head. I used shark bite connectors and did not solder the fittings
Are your walls still open? I assume they are as you'd be unlikely to close them up without having had tested your water flow. Here is what I would do.
1.) use the orange plastic C shaped release tool to depress the white plastic ring on the shark bite fitting that you have on the delta side of the Delta-ShowerHead connection.
2.) Carefully and slowly turn water on and see if water is exiting the fixture where you expect it to.
IF yes, water is coming out of the delta fixture then you know the flow problem is somewhere between the delta fixture and your shower head.
IF no, water is not coming out the delta fixture then you need to re-access how you connected the supply lines to the delta fixture.
Oct 24, 2014 | Delta & Single Handle Shower Faucet
How do I take apart a Delta Monitor Shower Handle
Take a look at this link:
http://www.ehow.com/how_6155493_replace-delta-shower-valves.html
Your valve may vary somewhat but this should give you a good start.
Apr 02, 2011 | Delta & Single Handle Shower Faucet
When delta shower faucet turned on the water comes out of tub spout as well as the shower head, rough in valve is installed correctly with the word up, up
Sounds like the delta people forgot to install the diverter piece inside of valve body,small white plastic piece screwed into valve. If you take out valve you should see it up inside body
Jan 28, 2011 | Delta & Single Handle Shower Faucet
Cartridge not fittingn into the valve body
It looks like a Delta Monitor valve. Is it a Delta part or generic? Generic cartridges are junk and could be the problem, or maybe solder or trash or a valve seat is stuck in the valve body. There is also a possibility it is upside-down. It does take some force to push the cartridge in, line up the grooves and push
Sep 03, 2010 | Delta & Single Handle Shower Faucet
Home Logo
609 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
