Question about Toshiba Satellite Computers & Internet
Replacing dvd/rw in a toshiba
My dvd/rw came out of my computer, how do I put it back in
  • Toshiba Master
  • 5,660 Answers
Post the model number of the Toshiba Satellite Notebook PC
This can be found on the Bottom of the laptop.
Optical drives for laptops usually just slide out to remove, or silde in. There is an Interface 'block' on the motherboard they plug into.
Usually just one Philips head screw, on the bottom of the laptop; is what holds them in.
Awaiting model number, to give more specific info
While waiting, one example,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/remove-laptop-motherboard-1.htm
Step 5
Regards,
joecoolvette
Posted on Apr 28, 2013
4 Suggested Answers
freddygon66
  • 93 Answers
SOURCE: DVR K17LF Insert a disc
Hi, according to what I understand the unit works for some situations especially but you cannot visualize the content, in this case the problem that you one presents shows off to be Cd-DVD's unit that this trumping, if the equipment this one even in guarantee, you must come to an CAS or Center of Authorized Service, in order that they diagnose and replace the unit
Posted on Jan 16, 2009
byteguy
  • 2229 Answers
SOURCE: Replacement for toshiba satellite A105-S4244 dvd r/rw drive
Sure--the best one is e-bay!
Whenever I need something like this, I find it on e-bay. But if you really need to contact a company, try Spare Parts Wearhouse at 877-253-8898. National Parts Depot at 800-524-8338 may carry Toshiba parts.
I'd almost bet that the part you need is not made by Toshiba, though. Take it out and when looking for a replacement look for the mfg. name and the model.
Posted on Feb 09, 2009
  • 253 Answers
SOURCE: replace cd rom with a dvd+rw cd rom in a toshiba satellite
You should be able to, there is usually only one screw holding the drive in, if you hold the replacement up to where the instlled one is, you should see the approximate location of the screw ( may be under another panel, Memory,hard drive etc.., the drive will just slide out, then make sure the connectors are the same, and swap or place the mounting bracket on the new one, and slide it back in place, replacing any screws removed
Posted on Mar 30, 2009
Dvd/rw in a toshiba fell out
Dear Erica,
Greetings from New Zealand! First thing: NEVER MOVE YOUR COMPUTER WHILE IT IS GOING! The Hard-drive read/write heads are less than a hair's breadth from the surface of the disks & any movement while the HDD disks are spinning will cause a "head-crash" which can destroy your HDDrive.
Turn comp. OFF.Wait 30x sec. Covering the dvd/rw - GENTLY lift box & shake - if you hear a rattling inside, then the dvd/rw mount screws have come loose inside the box. Make sure that the power switch on the wall is OFF, but still plugged into socket, OPEN box & "earth" your body by touching some bare metal inside to discharge any damaging "static electricity" - [your body can hold up to 50,000xVolts] - & retreive them. {It is preferable for you to purchase - $5ish - an "anti-static strap" & wear that anytime you open a computer case...} Note the type of screws that the dvd/rw is mounted with & get suitable screw-driver. Gently slide dvd/rw into place & line up screw holes...screw in screws - (not TOO tight! - replace cover & you should be 'good-to-go'!
There are a few cases that do not use screws - they rely on moveable levers to clamp devices into place. If so just align dvd/rw unit flush with the front of the case & clamp.
Replace side entry panel of computer box. Place box in preferred position & reboot. I hope that this helps!? - Kind regards GBU! - Bruce.
Apr 28, 2013 | Toshiba Satellite Computers & Internet
L305D-S5930 dvd wont burn documents to a dvd disc
You need a program, like nero.
if that doesn't work then put a DVD in the drive & see if the computer picks it up in the my computer.
the first thing that goes in a CD/DVD-RW drive is the DVD heads, thats if your drive is a CD/DVD-RW.
Have a look on the front of the drive tray, if it say CD-RW DVD ROM then it doesn't burn DVD's it only plays them.
Jan 30, 2012 | Toshiba Computers & Internet
Is it possible that a cdrw/dvd of Toshiba Tecra M1 be replaced with a dvdrw?
Yes, it is possible to replace CD, DVD with DVD+RW on Tecra M1. Generally, it is possible to upgrade optical drive on almost all the laptops.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 27, 2011 | Toshiba Tecra M1 Notebook
Toshiba SD-R2312 Upgrade to DVD Writer
If your current device is CD-RW/DVD-ROM, then any CD-RW/DVD-RW device that you can purchase will _physically_ replace and will fit into the space occupied by your current device.
Apr 23, 2010 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Hi i have a toshiba satellite pro a60 laptop i want to cange the dvd rom/ cd/rw drive to a dvd rw drive what the the problems with this
There should be no problems at all. Just go to the Toshiba web site, confirm that your computer can accept the new hardware and purchase a new dvdrom RW drive.
The drives are easy to remove and replace.
Hope this helps.
Oct 28, 2009 | Televison & Video
Will burn cd-r but kicks the disk out whe I put in a blank DVD-r
Sorry but your burner is a CD-RW/DVD-ROM
this means you can burn CDs and play DVD
you cannot Burn DVD with this device.
info link here
http://www.cdrinfo.com/Sections/News/Details.aspx?NewsId=7470
Please don't forget to rate me : )
Oct 01, 2009 | Toshiba SD R1312 CD-RW/DVD-ROM Burner
Dec 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Can not burn pictures taken from a canon or kodak camera to a dvd
THIS IS COMMON PROBLEM - BECAUSE THERE IS NO INBUILT JPEG SOFTWARE WHEN WE BUY LAPTOPS- IT HAS TO BE DOWNLOADED FOR MP3, JPEG AND DVD BURNING PURPOSE
VNRao
Dec 27, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite Pro L20 fitting DVD Writer
Try to find the correct driver from Toshiba for the driver, your current one wont work for the dvd.
Mar 27, 2008 | Computers & Internet
Problem with cd-r/dvd rom
does the light come on on the drive ? have you tried straightening a paper clip an putting it in to the little hole to push the draw open this may make it work if its stuck or try right clicking the drive in explorer and choosing eject from there
good luck
Jan 23, 2008 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Computers & Internet Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
