Question about Garden
Craftsman Rider Starting Issues
Hello I have a Craftsman Lawn Tractor Model # 917.289244 that has starting issues. When trying start the mower it turns over but it acts like the battery is weak. I have replaced said battery. The battery was tested and it had 12.6 volts and 220 cca. I have 12 volts to the solenoid. I have tried to jump the solenoid with a screw driver and get the same results acts like the battery is dying. I have pulled the starter off and bench tested it with said battery and it engages just fine with no issues. If I jump the mower off the battery in my truck it turns over and starts with no issues. It just will not start/turn over under its own power.
  • Garden Master
  • 2,478 Answers
If you turn engine over by hand, is it hard to turn at the start? If yes, adjust the valves.
Posted on Apr 28, 2013
  • 24 Answers
SOURCE: craftsman zero turn model# 107.27774
If you are jumping the solenoid and it cranks but wont start leave the key in the on position and give it a try. Try replacing the solenoid and the wires conecting it to the battery.
Posted on Apr 24, 2009
libaredneck
  • 119 Answers
SOURCE: Won't start
it sounds like the battery doesnt have enough crankinc amps. thats a pretty big engine and should have probably have atleast 250 cranking amps. its possible the starter is going bad also
Posted on May 05, 2009
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
panilling9
  • 284 Answers
SOURCE: craftsman model 917.272950 lawn tractor won't start
OPERATOR PRESENCE SYSTEM
Be sure operator presence and interlock
systems are working properly, If your
tractor does not function as described,
repair the problem immediately.
• The engine should not start unless the
clutch/brake pedal is fully depressed
and attachement clutch control is in the
disengaged position.
• When the engine is running, any
attempt by the operator to leave the
seat without first setting the parking
brake should shut off the engine.
• When the engine is running and the
attachment clutch is engaged, any
seat should shut off the engine.
• The attachment clutch should never
operate unless the operator is in the
seat.
Check your seat switch and clutch switch wires be sure that the connection to each switch is making contact and the mechanism that activates the switch is actually activateing them in other words be sure the clutch is pushing the switch in and your seat switch is occupied and be sure all grounding wires a intack
especially from your battery negative to the frame.You also could have a neutral safety switch which requires your transmission to be in neural.
try these things and let us know how we can further help from more of your input.
Posted on Jun 08, 2009
97F350diesel
  • 1326 Answers
SOURCE: starter problems with sears lawn tractor
COuld be the motor or combo of motor and solenoid. They're could also be a ground/positive cable loose or have a bad connnections not allowing the full current to get to the battery. These are fairly simply systems shold be easy to diagnose...
Posted on Nov 03, 2009
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding lawn tractor shuts off when coming off the brake
There is a safety switch in the seat that shuts the mower off if there is no rider. The mower stays running when the rider gets up ONLY if the brake is set. The switch under your seat is broken and cannot sense that a rider is on the seat. Therefore, the engine can only run when the brake is set. Depending on the mower, the two wires need to be connected (or disconnected) when a rider is in place. I do't know what mode your mower needs but it shouldn't take long for you to figure it out.. The safest thing is to confirm the seat switch is the issue then change the seat if replacements are available. Good luck Please rate me Mark
Jun 04, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
21 hp electric start Craftsman lawn tractor, B&...
Have your mechanic set your intake/exhaust valves at .004 when piston is 1/4 inch past top dead center on compression stroke.
May 19, 2010 | Garden
20 Hp 42" Deck Lawn Tractor: I have a craftsman rider that starts idels and dri...
sounds like one of the pullies is locked up . check all the pullies for free movement the plastic pullies are junk. replace with metal ones if you find a bad one.
May 17, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I was using my sears craftsman riding mower yesterday and it was working fine...no issues whatsoever. I stopped the engine to get something and when I went to re-start it, the engine turned over just fine,...
You should check the seat safety switch,it may have stuck or is unplugged or it needs to be replaced.Any other safety switch that is unplugged or defective would keep it from starting.
May 12, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Sears craftsman rider mower model #917.276815 will not start. ran out of gas and after re-fueling,would not start what to do? also don''t know how to change the spark plug inthat unit - can''t find it
WHAT U NEED TO DO IS GET A CAN OF SPRAY STARTING FLUID (ANY AUTO PARTS STORE, VERY CHEAP) AND SPRAY IT INTO THE AIR INTAKE OF THE ENGINE, CHANGING THE SPARK PLUG ISN'T GOING TO HELP HERE, SPRAY THE STARTING FLUID AND ONCE IT IS RUNNING THE PROBLEM WILL CLEAR UP MOST LIKELY.
Apr 05, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 550 brand new mower wont start
SONDS LIKE A FULE PROBLEM IT MAY NEED THE CARB CLEAND MAY HAVE BAD GAS
Oct 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lt1000 rider 42 in deck is stuck in gear and wont go into neutral. so i cant get it started.
this happens when lawnmower is cut off in gear try this mash clutch and shake mower forward and backwards while trying to shift into neutral
Sep 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
