Question about Vacuums
Kenmore vacuum model 116.29219
I have checked everything out and it seems fine, this vacuum is a year old and the roller is not working, the vacuum turns on but the roller isn't moving at all
Kazong
  • 152 Answers
SOURCE: roller brush of vacuum not rotating
u might need 2 change the belt on the attachement there r 2 screws on top take em out after u take off cover there is a plastic cover over the belt take off c if the belt broke the rest is easy
Posted on Mar 02, 2008
galati2k
  • 281 Answers
SOURCE: Eureka the boss 5893A brush roller will not work
is there anything jammed underneath.can you turn the brush roller by hand.if not then take it back where you bought it.sounds like you have a defective brush roller
Posted on Apr 23, 2009
VacuumRepair
  • 438 Answers
SOURCE: Model 116 Kenmore vacuum cleaner. 20+ years old,
Greetings,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Posted on Mar 21, 2010
VacuumRepair
  • 438 Answers
SOURCE: agitator doesnt turn
There is actually a reset button on the agitator, I would try pushing this switch first to see if this fixes it. The button is located on one of the sides of the agitator housing, I'm not sure if it's the left or the right side, or on the top of it.
Look on the sides of the part of the vacuum that is on the floor and see if you can see a small red pole on either side. If you can't find it here, look on the top of the part of the vacuum that touches the floor for a brush overload reset switch.
Try pushing that poll whenever you find it. This switch is a protection mechanism that will shut the brushes down to protect them if something gets vacuum up inside of the brush, it will automatically shut itself off to prevent any damage.
Simply push this overload switch down, and this should hopefully fix your problem.
If this didn't, please let me know and I can walk you through some more advanced troubleshooting.
If this was helpful, please be so kind and rate my repair, or leave feedback.
Thank you!
Chris Jones
GoVacuum.com
Posted on May 18, 2010
Testimonial: "I actually tried pushing this before I posted my question. When I tried again, I realized it was stuck pushed in. I used a pair of tweezers to pull it back out and the agitator is working great. Thanks a million! So thankful not to have to buy a new vacuum!!"
SOURCE: Kenmore Powermate power head not working
I've got the same problem. Try checking out the electrical connection where the hose attaches to the canister. The hot male terminal is corroded and the female socket is burned out. Its an unfortunate design flaw that every time you open the vacuum to replace the bag the electrical connection disconnects and reconnects. Not sure if I can find replacement parts for a 10 year old vacuum or if a home-made re-wiring job is in order. Will find out tomorrow.
Posted on May 02, 2011
Roller with brushes is not rotating although light is on and sucking sound is there. Is this a belt problem?Detached from floor part, the hand part is working fine. New filter. new bag.
Hi, it's Allie from Crucial Vacuum!
Your Kenmore vacuum brushroll is connected to the motor by two different sized geared belts. Over time, the belt's gears wear down and stretch out losing the grooves and tension that turn the roller. Another cause could be there is debris stuck on the roller and/or bearings. Changing the belts may be the solution to your problem.
Checking your unit's brushroll and clearing it of any tangled hair strands or debris that my be blocking the airway will be helpful. Follow by checking the internal hose for any blockages.
You can purchase direct your replacement, roller brush, filters and belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/kenmore.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 13, 2014 | Kenmore Vacuums
My Kenmore Progressive Whisper Belt canister vacuum is not "whispering." In fact, it makes excessive noise during operation - much more than the older Kenmore model that it replaced. I have replaced the...
Probably either bearings in the roller brush, a damaged fan blade, or the bearings in the motor. Take the roller brush off completely, and run the VAC without it. If it's much more silent, then the problem is with the bearings in the roller brush. If it's still noisy, then look closely at the fan that produces the suction, if you can. If you see any damaged blades, then you'll have to replace it. If it seems fine, then it's most likely bearings in the main motor that will have to be replaced. The bearings and the fan blade are NOT expensive parts, but the labor at a shop to change the main bearings would be kinda pricey.
Oct 18, 2013 | Kenmore Vacuums
My upright model 36933503 is making a horrible squeal. I've cleaned out everything that I can find to clean out. It seems to be worse when I turn on the Inteliclean mode. Any suggestions? It still...
A squell usually means a belt slippage, versus a broken belt. You might want to check for rubber fragments around the beater bar. But it could also mean that the rollers on the end of the beater bar are froze up.
Jul 27, 2011 | Kenmore Vacuums
Roller brush on Kenmore model: 116.31199100 won't turn
Refer to Larryclare1's solution at http://www.fixya.com/support/t1095798-kenmore_model_116_powermate_jr_stopped It worked great for me. Replace the belt, which you can get at Sears Parts store/online and clean out the hair as per Larryclare's instructions.
Feb 27, 2010 | Kenmore Vacuums
Ken 116 31912100
open the bottom and you will see where the belt goes.clean off the motor shaft before putting on the new belt .the old belt might have left some rubber on the motor shaft.clean the shaft or your new belt won't last very long
Apr 07, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore vacuum- no suction, brush wont turn
Sounds to me like you have a plugged vacuum. Check all the way through.
Jan 29, 2009 | Kenmore 22812 Bagged Canister Vacuum
The brush rollers on my hoover mach 5 won't turn. I've cleaned everything and checked the belts and everything checks out fine. I had the vacuum for about a year.
I had the same problem. The problem is the small v-belt for the roller brush (Hoover part# 38528034). Although it looks in good shape, it's been stretched too large for the idler to keep good tension. The tension on that belt varies with the handle geometry so if you slam handle all the way down the belt gets stretched a little bit each time.
Oct 06, 2008 | Hoover Vacuums
BEATER BAR
The newer models have plastic end caps that will melt when the bearing heats up. This will cause the cap to go "off-centre" and the roller will vibrate badly. If this is the case, you will have to replace the roller.
If the belt is a geared drive, check the belt for any missing teeth.
Jan 30, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
