Question about Whirlpool Washing Machines
L1961 quartz control pp2
Pcb faulty
  • 3 Answers
Pcp power on E1 error
Posted on Feb 06, 2014
Image runner getting this error code E261-0000 / how do i fix it
Code
E261-0000
Description
The intervals of zero-cross signals deviate from the tolerance range while the fixing heater is supplied with power
Causes
The wiring is faulty (short circuit, open circuit). The main power supply PCB is faulty. The DC controller PCB is faulty.
Remedy
1. Connectors Are the connector J205 on the main power supply PCB and the connector J308B on the DC controller PCB securely connected? (zero-cross signal: J205-7 <-> J308B-1) NO: Connect the connectors securely. 2. Main power supply PCB, Main controller PCB Try replacing the main power supply PCB. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.
Best Regards
Jul 24, 2016 | Office Equipment & Supplies
Image runner getting this error code (E261-0000) / how do i fix it
Code
E261-0000
Description
Causes
Remedy
1. Connectors Are the connector J205 on the main power supply PCB and the connector J308B on the DC controller PCB securely connected? (zero-cross signal: J205-7 <-> J308B-1) NO: Connect the connectors securely. 2. Main power supply PCB, Main controller PCB Try replacing the main power supply PCB. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.?
Best Regards
COST OF L1961 Quartz control pp6
Fixya does not sell parts. Check with a local appliance parts supplier.
Jun 18, 2016 | Whirlpool Washing Machines
How to solve error 100-0001
Code E100-0001 Description The BD signal is not detected 10 times or more within 10 msec in 5 msec after the generation of the laser drive signal Causes The wiring is faulty (short circuit, open circuit). The BD PCB is faulty. The laser scanner unit is faulty. The DC controller PCB is faulty. Remedy 1. BD PCB Try replacing the BD PCB. Is the problem corrected? YES: End. 2. Laser scanner unit, DC controller PCB Try replacing the laser scanner unit. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.
Dec 05, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
Whirlpool washing machine control circuit L1961 Quartz control pp2
whirlpool washing machine control pcp L1961 p1 conector details
Feb 24, 2013 | Whirlpool Washing Machines
Canon ir 3300 error code e000803-0000
Similar to Description The 24V output from the composite main power supply PCB is absent for 1 sec or more Causes The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty. Remedy 1. Connectors Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely? NO: Connect the connectors securely. 2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller PCB (J300)? (J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3, J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3) NO: Replace the main power supply PCB. YES: Replace the DC controller PCB.
Aug 21, 2012 | Canon Ir 3300 Black & White Copier
What does the eror code E064 means on ir2800
E064: The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer has deviated from a specific level of voltage.)Main causeThe contact has poor connection. The wiring is faulty. The composite powersupply PCB is faulty. The DC controller PCB is faulty.Main cause: The contact has poor connection. The wiring is faulty. The composite powersupply PCB is faulty. The DC controller PCB is faulty.look here
Mar 05, 2012 | Office Equipment & Supplies
Giving an erro E220(IR3300)
E220
0001 A fault is detected on the inverter PCB for the scanning lamp.
Main cause The inverter PCB is faulty. The reader controller PCB is faulty.
Action
1. Wiring
Is the wiring from the scanning lamp to the reader controller PCB normal?
NO: Connect the connector firmly, and correct or replace the wiring.
2. Inverter PCB, Reader controller PCB
Try replacing the lamp inverter PCB. Is the problem corrected?
YES: End.
NO: Replace the reader controller PCB.
Aug 02, 2010 | Canon imageRUNNER 2200
Como soluciono un E302 en una IR3300
E302
0001 During shading, the shading processing does not end on the reader controller
PCB after 1 sec.
0002 During stream reading, the edge white addition processing does not end on
the rear controller PCB after 10 sec.
Main cause The CCD PCB is faulty. The wiring is faulty (short circuit, open circuit).
Action
1. Connector
Are the connectors (J6001/J6002) on the CCD PCB and the connectors
(J5002/J5003) on the reader controller PCB connected securely?
2. CCD unit
Try replacing the CCD unit. Is the problem corrected?
YES: End
3. Reader controller PCB, Main controller PCB
Try replacing the reader controller PCB. Is the problem corrected?
YES: End.
NO: Check the wiring; if normal, replace the main controller PCB.
i hope it will be help full to u.
Mar 06, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Error261 in canon copier
E261
0000 The intervals of zero-cross signals deviate from the tolerance range while
the fixing heater is supplied with power.
Main cause The wiring is faulty (short circuit, open circuit). The main power supply
Making Corrections
1. Connectors
J205-7 <-> J308B-1)
YES: End.
Feb 22, 2009 | Canon NP 7130 Black and White Copier
Washing Machines Logo
176 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
