Question about Freezers
253.9239712 where is the thermostate located
Freezer gets to cold
HI
If your thermostat cannot control your motor automatically for on and off then you should change it as it is the only unit that can cause this problem.
Feb 13, 2014 | Frigidaire Freezers
Freezer gets cold but dont freeze the food
its not cold enough, it may be low on freon, if its a chest freezer it may not be economicle to repair it. or the thermostate may be set to high... to tell the difference, if the unit cycles the compressor on and off at least every few hours (or more) then its the thermostate, if the unit runs continualy then its freon
Feb 02, 2013 | Freezers
Where is the thermostate(sensor) located that controls the compressor - or is it the same as the sensor located by the door which show the temp on the outside indicator Thanks
The thermostat sensor is located in the top rear of the interior of the unit, if you locate the dial to change temps on the inside of the unit, the sensor is attached to it, you may have to pull your fridge apart to get to it, but it can be done.
Regards Russ
Mar 07, 2011 | Nor-Lake Freezer Norlake Refrigeration 6'...
Thermostate need replacing
Good day,
I see you're not from the states. You'll have to google to find the thermostat. Isn't there an appliance parts house in your area?
Two, generally replacing a tstat is a nuts and bolts proceedure.
Once you have it in hand, it will be far easier to understand.
Jan 13, 2010 | Whirlpool Freezers
Fridge freezer is not workink,light is on freezer but no sound,freezer is in a cold room is it possible the room is to cold and problem with thermostate?
It could be a compressor problem, or the cold control. If your room is above freezing, the freezer should still run.
Jan 07, 2010 | Freezers
Freezer unit won't shut down
yes the thermostat could be the problem. or depending on the model contol board.rarely the compressor may need to be checked for proper freon levels
Sep 16, 2009 | Freezers
The freezer is making a loud buzzing sound when the switch is turned on. Also it is not freezing any longer.
check the compressor,and its base bolt.check the current drawn by the unit,and cross check with the rated amps.check the thermostate and its correct funtion
Jun 03, 2009 | Freezers
Freezers Logo
15 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
