Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Saeco Primea reset internal counter - Saeco Primea Cappuccino Touch Plus Coffee Maker
  • 5 Answers
SOURCE: Saeco Primea Touch
Hi there
You can run a diagnostic check from the Service Menu.
To enter the Service Menus please see 0505's post on the Saeco threads here.
Paul
Posted on Jul 31, 2008
SOURCE: My saeco primea touch plus cappucino grinds coffebeans, but no co
At the extreme top left of the brew group, above the last filter (mentioned in another response), there is a spring loaded tip that I assume is pushed open by the pressure of the brewed coffee, before the coffee streams to the dispenser nozzles. When I dis-assembled this (2 philips screws) the tip seemed very sticky (slightly jammed?). I pushed the ip several times against a hard surface and freed it up. Re-assembled everything (plus cleaned the last fliter). Works fine again.
Posted on Jul 25, 2009
  • 20 Answers
SOURCE: error 1 on saeco primea touch plus
The grinder motor is not working,,better to take it to the service center to replace a new one under warranty if the machine is new.
Posted on Dec 16, 2009
  • 20 Answers
SOURCE: Hi, I have the Saeco Primea
Need to prime the machine. The new water filter is causing the air lock in the system.Remove the filter and startup the machine it should prime by itself, when it's ready,fit the filter back and press hot water until the water flows steady. Hope it helps.
SOURCE: milk is not dispensing hot enough from saeco
If you use cold milk, I don't think it has enough heating power to make it hot enough. What I find works best is using long life milk from a carton which is room temperature, or making the milk room temperature warm in the microwave first before pouring into the milk containter
Posted on May 08, 2010
My Saeco Primea Touch Plus every time I turn it on says to add detergent at the milk conteiner. After I give the comand it tryes to wash the milk conteiner and when this is finished says to turn of the...
From what the User Manual indicates, the prompt to clean the milk circuit is based on the number of days since the last time this was done. The counter which keeps track of this is probably only reset at the completion of the wash cycle. You might be missing a step.
The User Manual is available here, see page 28. There are 16 steps plus the "perform another rinse cycle" (page 27):
https://www.seattlecoffeegear.com/assets/user-manuals/saeco/saeco-primea-touch-plus-user-manual.pdf
Jan 14, 2018 | Saeco Primea Cappuccino Touch Plus Coffee...
My Saeco Primea Cappuccino has stopped dispensing milk but no error is displayed
If you don't perform the milk cleaning process for 21 days, the machine will blocked you from dispensing milk product.
Apr 16, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Error 1 on saeco primea touch plus
Oct 24, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Hi, I have the Saeco Primea Cappucino Touch Plus , and it syddenly gives the error code 5 - Call assistance. I have just changed the primea Water Filter - same way as always ! What can I do ?
Sep 05, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Touch Plus flow problem
In the bean hopoer there is a little screw. Remove this screw and the cover and you will see an adjustment alan key. You need to push down and rotate the adjuster counter clockwise to make it finer and clockwise to make it bigger. Make sure you only rotate the grinder a little at a time, 1/4 turns at a time recommended. Make 2 cups then readjust if necessary.
Saeco Authorized Sales & Service of Espresso Machines
www.CeriniCoffee.com
Nov 30, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Ring stuck on warming up
Hi
I had the same problem and could solve it but i had take the machine apart.
Under boiler you have 2 thermo fuses that can be resetted. After reset i have checked if boiler get 220volt, It did for a short while but the fuses goes off again.
That means boiler is ok, it gets hot but fuses goes of due to temperature reach over 170 degrees celcius. That means that the power is olways on to the heater and doesnt stop to heat.
In diagnostic i could see that the temperature sensor does show the high temperature. That means that temp. sensor is ok which leads to the controller of the power to boiler. On the board i found big heatsink and a triac atached to it. I soldered it out and measure that it was spoiled.
Ordered new one for 3 euro. Soldered new one on the board and the problem was solved.
Original was BTA16-700CW but they didnt have it so i replaced it with BTA16-600CW, difference is that original one can handle 700volt the new one 600, but there is only 220volt it will controll anyway so that was ok.
I atach a picture.
Regards, Pawel
Nov 18, 2008 | Saeco Vienna Espresso Machine
Saeco primea Ring
What i know there will not be any dvd or cd, it´s only on paper:-(
/Mirran
Sep 03, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker fill water tank
The Primea do not have a float, it have a magnet and inside the machine there are a printed circuit card, this send a signal to the powerboard.
Jun 20, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
121 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
