Question about Garden
Toro snowblower 824 wiring schematic
I get no spark at the plug
  • 7,482 Answers
Hi Joseph
I hope this helps
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Posted on Apr 30, 2013
boscia
  • 163 Answers
SOURCE: What is the spark plug gap setting
.030 inch
Posted on Nov 29, 2008
  • 37 Answers
SOURCE: toro 421 snowblower won't start
check to see if in line fuel shut off valve is open.If so,sounds like carb is gummed up.
Posted on Jan 28, 2009
  • 127 Answers
SOURCE: I have installed a bigger motor on a toro riding
gap the coil with a business card right at the magnet on the flywheel then retighten
Posted on Sep 06, 2009
2strokeJim
  • 577 Answers
SOURCE: Parts may missing need schematic
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225
Posted on Nov 18, 2011
Why I have a toro snowblower model#38272 that started a couple weeks ago and now will not start
Check wires for insulation damage. Spray Carb Starter Fluid into manifold and see if that gets the machine to turn over.
Feb 03, 2015 | Toro Garden
Have no spark to plugs
Those sensors have no effect on spark. Did you replace the plug, if not remove it hold it against the engine, have someone pull cord, watch for spark. If you have spark then you have a fuel problem. If no spark then after replacing plug, then remove stop wire from magneto side. Pull cord an watch for spark. If no spark then remove housing an flywheel, measure gap between mag an flywheel. Check to make sure magnets are still on flywheel. Call some shop or check a service manual on gap setting. If no spark still you will need to replace the magneto. This is rare an its is more likely a plug that needs replacing. Toro snowblowers are nice machines, this is not a hard fix. Really to tackle this is starting with the plug.
Mar 16, 2014 | Toro Snowblower 826 Oxe 38624w With 3 Year...
What spark plug wrench is used to remove the spark plug on a TORO 38624w snowblower?
it is prob a 13/16 this is the most common most of the time you cannot get a wrench on a plug but a socket , if it is smaller then it is a 5/8 lefty loosie righty tighty do not over tighten the plug
Jan 20, 2014 | Toro 826OXE 2-Stage Snowblower 38624W
Garden Logo
113 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
