Question about Garden
Pressure washer Won't hold pressure
    New Friend:
    Problem Solver:
  • 5 Answers
Have you tried turning the black knob to see if the presure increses?
Posted on Apr 28, 2013
jj505
  • 195 Answers
SOURCE: pressure washer won`t pressure up
Have you tried adding 30 wheight pump oil,under 1 qrt usually
Posted on Mar 19, 2009
  • 92 Answers
SOURCE: Pressure washer lacks pressure initially?
Dear allbusiness9,
This problem is most probably due to a faulty Spill Valve( also called Control Valve). When the gun is released the spill valve is compressed and it either closes a micro switch or just opens from the bottom and keeps the water circulating. All spill valves keep the water circulating from the bottom part. Now when the gun is pulled (opened)...the spill valve extends and closes the bottom part, and thus water goes out of the nozzel. When you work with no nozzel, there is enough water flow to close the bottom part of the spill valve. So when the nozzel is placed back there is no chance that the bottom part leaks water. When the gun is started with the nozzel....the bottom part of a FAULTY spill valve,..will colapse and pressure drops. So to fix the fault you must change the Spill Valve. In some occasions, I also found that suction valves give this problem. A faulty sucktion valve will colapse under high pressure, and lets water pass the other way round.
But in my opinion and experience, your problem is in the Spill Valve.
Regards,
Fulltech.
Posted on Apr 23, 2009
  • 92 Answers
Dear rustrick281,
It seems that your pump needs a good service. The sucktion and delivery valves got faulty. The high pressure seals and the low pressure seals must be renewed. The pistons must be checked for corrosion and cracks. Also the pistons or one of the pistons got stuck due to oncorrect lubrication. The swash plate that drives the pistons could have got loose. So the motor turns and the pump stays dead. So a good examination and service must be done to the pump. To renew all the parts I have mentioned, you must buy a PUMP KIT for you model. The pistons are not included in the pump kit....but hopefuly the pistons are still good. Also the oil inside the pump must be renewed.
Regards,
Fulltech.
Posted on May 07, 2009
  • 112 Answers
SOURCE: 1750 psi Electric Pressure Washer: My pressure washer is losing pressure and is pulsa...
I have d'same problem before. replace the head component with the 3 little cylinders,springs etc.. its a 1 piece part.
Posted on May 06, 2010
  • 553 Answers
SOURCE: low pressure on the pressure washer
Most likely your "O" rings or seals have gotten hard and are leaking. Sorry I don't know your equipment well enough to tell you how to change them but you can most likely find the info at your manufactures web site.
Posted on May 26, 2010
Pressure washer won't pump
You didn't indicate what make or model pressure washer you have but if you didn't drain the water out of the unit and run conditioner through it before storing it, it's highly likely some of the check valves (there are six in most pressure washers) are frozen shut. If water was left in the pump and it got cold enough to get a hard freeze, it's possible the seals were damaged or even the case may have cracked. The only way to know what's damaged is to take the pump apart and go through it.
Aug 31, 2012 | Garden
Graco x9 won't hold pressure
If it comes up to pressure but won't hold it when the motor stops, you have either damaged packings or a bad check ball-to-seat seal. If it's the check ball(s) not seating properly a real good cleaning should take care of it. If it's the packings the only remedy is to replace them.
Aug 11, 2012 | GRACO INC Magnum Pro X9 Electric Airless...
Craftsman 2400psi 6.0hp briggs & stratton pressure washer won't start
try and start it with starting fluid if so rebuild the carb
Aug 07, 2012 | Garden
Detergent won't go through siphoning tube
it will only draw detergent with the large black nozzle or the nozzle wide open with not draw with high pressure
May 20, 2012 | Honda Black Max 2600 PSI Pressure Washer
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
Pressure washer won't start. It has gas, oil and I turned the switch to turtle and to rabbit position. Does it matter if water is on first or not? It won't start either way.
Turn the water on, hold trigger down and let water run thru the hose to prime the air out of the hose. If it still will not start check the spark plug and clean it or replace it. A bad spark plug will keep it from starting
Aug 22, 2011 | Briggs Stratton 020273 Elite Series...
Got spark and gas can't get it running what is the conpression supposed to be
i have a honda power washer EXHA2424, I replace new spark plug, new gas., cleans the cabureetor, and it still won't start please advice me what to do
May 21, 2011 | Devilbliss DeVILBISS Devap DVH2600...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
