Question about Kenmore 24032\24036 Top Load Washer
How to clean washer filter
After completion of washer full cycle all my dark load had white,cotton color dust peach on it,like we found it dryer filter.
    President:
  • Kenmore Master
  • 662 Answers
Check for blocked pipes below tub and exit drain hose, after disconnecting mains; no filter as such. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Posted on Apr 30, 2013
freetek
  • 5568 Answers
SOURCE: Kenmore washer leaves dark streaks on light colored clothes
I suggest you first take a clean, white cloth wetted with a stronger solvent such as 'Oops,' carburator or brake cleaner (with these two, DON"T overspray, they will damage plastic and paint) and wipe the drum inside to make sure there is not some gunk adhering that is gradually depositing itself with each wash cycle.
If you have a shade-tree mechanic in the family, they may have gotten a gob of grease on clothing that transfered to the inside of your machine.
If you don't find enough on the cloth to have caused the problem, I think you have lost a seal on the drum-side of the transmission.
Posted on Jul 01, 2008
  • 92 Answers
SOURCE: washer not completing cycle
try checking the motor bushes,this is normaly the case with your problem.
Posted on Jul 08, 2009
graemevm
  • 519 Answers
SOURCE: Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Posted on Apr 18, 2010
  • 4088 Answers
SOURCE: Rough, uneven Cotton Load spin cycle
Make sure the washer sits level on the floor and that the machine can't be rocked around due to uneven foot adjustment. The feet usually have rubber cups that cover the metal bottoms--one of the cups may be damaged or missing entirely. Hope this helps!
Posted on Jul 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: Blue stains in the Kenmore Oasis
check for a pen in the drain trap.
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
The washer faults during drain cycle. I have cleaned the filter. It is pumping fine with plenty of water flow but still faults out.
Maybe a short or oxidation.It could use other programm's drain cycle instead of the pre-set.You are washing cotton and it drains syntetics.
Mar 20, 2015 | Whirlpool Duet WFW9150WW 4.0 Cu. Ft. Front...
Washer leaves white lint like spots all over dark clothes.
This happens to me as well but only when I overload my washer or when my washer needs to be ran thru its cleaning cycle.
Mar 10, 2014 | Whirlpool Cabrio Washing Machines
My Kenmore 22642 washer is leaving lint all over the clothes. If i run them through the dryer, that will remove the lint... but some of my clothes don't go through the dryer. I can't seem to determine if...
Wash clothes separately whites and light colors together. Darks with liquid detergent. No lint filter on the machine. I have found some powder detergents do not dissolve completely.
Dec 26, 2010 | Kenmore 22642 Top Load Washer
We have a combo dryer and washer. Washer is A2444330KH. Leaves lint on cotton shirts, have cleaned the filter no help. Any ideas? David
Dryer lint not only presents a problem by cluttering up your clothes with white specks, but it can also lead to a dryer fire. While it is impossible to completely eliminate dryer lint, you can take action to drastically reduce lint and the potential problems that come along with excess dryer lint. If your clothes take more than one cycle to dry, you see no lint on the lint screen, the clothes are very hot after drying or you find excess lint on the clothes after drying, you probably have a problem with accumulation of dryer lint in the dryer vent.
Use a dryer vent cleaning brush and clean the dryer vent, or hire a professional to clean the exhaust vent behind your dryer. If your dryer vent is clogged, it will create excess dust in the dryer and on the clothes. The excess lint can eventually catch on fire given the heat load of the dryer.
Dec 05, 2010 | Maytag Washing Machines
All our whites are now greys washing with our GE WCVH6260
graying of clothes is usualy caused by / serveral things . too much soap / washer not rinsing properly / and gas dryers. change your dergt. use one with a bleach in it . and use 2nd rinse ( cold water ) make sure washer drains wash water completly . do this by cking the drain pump clean out .. if cloged it will slow the drain cycle and you will be rinsing with the wash water . also use H E dergt. . if dergt is still in clothes when drying this turns nylon yellow and whites gray .. .also seperate colors . and whites .. **** ..
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaves marks on whites
This means that the machine drum needs cleaning. A suggested method of doing so follows;
To keep the machine clean of waste build up and to keep any bad odours away
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Oct 02, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
Oct 02, 2009 | Bosch Washing Machines
The pump on the Bosch WFB 2000 front loading washing machine doesnt seem to be pumping all the water out, it leaves about 40mm of water in the drum. It though pumps and seems to be working, as it does pump...
  1. Check the filter is clean.
  2. Check that the outlet pipe is completely clear of debris and soap / detergent scum.
If this does not cure the problem then it may be there is soimething trapped in the water pump or thst the pump is actually defective which will mean a new pump is required.
To keep the machine clean of waste build up and to keep any bad odors away
Sep 12, 2009 | Bosch Axxis WFL 2060 Front Load Washer
I just had my washer-dryer repaired by CandyHoover. They replaced the tub and drum. I put it through the half hour cycle yesterday, then today I put a couple pairs of jeans in it on the 40C cotton
hi i had the same problem clean the door seal then use some disilled malt vinegar on a 90 wash then clean your filter out then use some bleach with your washing powder on 90 wash clean your filter then you should be all good then as that worked for me
May 23, 2009 | Candy CNW136 Front Load Washer/Dryer
Washer cycle completes but clothes don't clean!
HEATING ELEMENT NOT HEATING, IF IT DOSE NOT HEAT IT CAN,T MOVE ON
Oct 19, 2006 | Zanussi WJS1397W Front Load Washer / Dryer
Kenmore 24032\24036 Top Load Washer Logo
32 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
